Results 1 to 40 of 76
    Dec 03 2006
    Singapore
    RS5 MMI Console (with Joystick) with the Alu buttons to be installed in S4
    I have a S4 with the full blown MMI Navigation plus from factory + Keyless entry
    My original S4 MMI console with joystick is as follows:
    8T0 919 609 G - Operating Unit for MMI with Joystick [PR-4F2, 4I3] the PR codes mean "4F2 = Central locking system "Keyless Entry"" and "4I3 = Central locking system "Keyless Entry" without deadlock" respectively
    I would like to install the new RS5 MMI console as it has the nice Aluminium effect buttons.
    In the RS5 ETKA catalog there are two entries with PR-4F2, 4I3:
    They are:
    8T0 919 609 M - MMI Control with joystick for PR-4F2,4I3
    8T0 919 609 K - MMI Control with joystick for PR-4F2,4I3
    Question is what is the difference between "M" and "K" suffix versions?
    ETKA does not tell me anything else.
    You can safely ignore the RS5 part 8T0 919 609 N because it is for Radio "LOW II" (does not apply my car)
    You can safely ignore the RS5 part 8T0 919 609 Q beacuse it is for Radio "HIGH" Japan (does not apply my car)
    Has anyone installed the RS5 MMI control with joystick into the S4 yet??? Love those alu effect buttons!!!
    Is there any difference between the "M" and "K" vesions as the PR codes are exactly the same as the original S4 MMI console.
    beautiful huh!.......and the MMI control console cost a small fortune so one does not wish to buy the wrong part.
    any guidance would be much obliged.
    Thanks a million.
    Active Member Four Rings marty was here's Avatar
    Nov 10 2006
    992TTS 992GT3 RS7
    nnj
    2011 is a different navigation system if im not mistaken. that would be your biggest obstacle to overcome imho
    We have a black president... Racism is dead.
    -JPT
    I have a real sore throat...feels like I've been deepthroating gorillas.
    mister_tu
    Hey, I just read this (and this is crazy), but take your two cents, and fuck off maybe?.
    audia
    Dec 03 2006
    Singapore
    Quote Originally Posted by marty was here View Post
    Nav unit is the same on 2011, its just the updated SW sitting in the harddrive in the MMI control unit. BTW Audi use a custom software made by QNX for MMI.
    QNX is famous for making RTOS (realtime opearting systems) applications that are robust, quick start up, high reliability etc.
    it is strongly encrypted also, even if you remove the HDD and try to clone it, next to impossible.
    The HDD is a Hitachi Endurastar automotive grade HDD
    Quote Originally Posted by DavidB8 View Post
    The only item you have to consider is what are you going to do about the hole where the electric rear spoiler button goes?? Perhaps convert it to a trunk release?
    Hi David
    The spoiler extension button is not an issue as the cut out can be filled up completely by a coin holder for S4/A4. on the RS5 the coin holder slot is a little shorter to accommodate the spoiler extension button. putting in the regular S4/A4 coin holder fills the entire space up so no issue with that
    we are RHD cars here in this region so actually in the picture above my park brake and coin slot are reversed for RHD application.
    Quote Originally Posted by rva View Post
    found this in a german forum:
    • 8T0 919 609 K - with start button
    • 8T0 919 609 N - w/o start button
    thanks for the reply but......
    unfortunately the german forum is wrong
    the item is ETKA is listed as number 13 (MMI console) and includes the items 16,17,18 complete. the start button is (item 21) is a separate for all MMI consoles across the A4/A5/S4/RS5 etc.
    8T0 919 609 N is for it is for Radio "LOW II" PR code cars
    unless my ETKA is wrong....but that's unlikely cos it an updatable version that is licensed.
    BTW...just relalized a typo in the title, it should be RS5 and not RS4!!!!....now fixed
    Sep 29 2009
    Agreed, I want this for mine eventually, since my past experience with the black coated plastic buttons is that they will eventually wear off the black - not to mention the aluminum looks amazing!
    Registered Member One Ring rva's Avatar
    Dec 14 2009
    Zurich, Switzerland
    2010 Audi S4 Avant, phantom black, S-Tronic
    Senior Member Three Rings krunko's Avatar
    May 24 2010
    a broom, old CDs I never listen to, cockroaches
    Los Angeles, CA
    How much do all the parts cost?
    Veteran Member Three Rings ChrisMT79's Avatar
    Oct 13 2009
    2010 S4
    Michigan
    Ill hit Dave up and ask him.
    2010 S4
    19' STaSIS Wheels, Stratmosphere Hyper Shifter, Ecodes, Folding Mirrors, Black optics grille, Body colored front filler plate, Höen Xenonmatch Fogs, LED Licenses Plate Bulbs, Tints, Vagcom.
    Senior Member Two Rings notjoefromnh's Avatar
    Apr 10 2007
    2010 S4, 2007 Chevy 1500, 2011 MXZX 800Etec
    NH
    I want that shifter
    2010 S4 - Sprint Blue, Magma Interior, Prestige, Drive Select, H&R Sport Springs, Smoked 19"s, AWE Exhaust, Strat Intake
    Jul 14 2008
    Hong Kong
    Quote Originally Posted by notjoefromnh View Post
    I want that shifter
    Same here. I think that will be a more impressive upgrade than the silver buttons.
    Senior Member Three Rings guy013's Avatar
    Jan 21 2010
    Singapore
    Quote Originally Posted by vjma View Post
    X3
    soooo sexy.
    C7 A6 3.0T, APR Stage 2+
    VBOX verified times:
    0-60mph 3.63s
    1/4 mile 12.22s @112.4mph
    Veteran Member Three Rings awhk82's Avatar
    Jul 13 2007
    Hong Kong
    I want that shifter
    Me too, the only thing holding me back on getting it is the RS5 badge shown. Anyway, part number for the shifter is 8T1 713 139F NOR
    2012 RS4 Avant - Suzuka Grey
    Capristo Catback, HMS X-pipe
    Before...
    11 TTRS | 10 S5 SB | 08 A4 3.2 | 06 A4 2.0T | 05 A3 SB 2.0T | 04 S4 | 99 A4 2.8
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Hey Chris, got your message so I took a look for you.
    That unit is worth $566 vs your current model which is $688. I know... It was the same with the electric folding mirrors, they are cheaper than non folding.
    Even if the NAV unit has changed (although to my knowledge it's the same) don't worry about it. The buttons are all the same so you can just unscrew the bottom and swap out the board from your old unit. Although I don't think you'll need to.
    The only item you have to consider is what are you going to do about the hole where the electric rear spoiler button goes?? Perhaps convert it to a trunk release? The button is most likely not going to come with the console either. The only buttons that come with the console will be the MMI buttons.
    LHD Spoiler Switch 8K1 927 521 $32.00
    It's a nice piece but I don't think I would be concerned about it fitting as much as the Investment.
    If anyone does decide to buy this and wants custom LED colours let me know.
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at [email protected] I don't frequent this forum very often.
    www.audienthusiasts.com
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Am I missing something? My buttons are all silver like the pic in my S4.
    EDIT: Im dumb. I dont know why I thought my buttons were silver. They are clearly black.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Nov 06 2009
    The thing with the shifter is the logo though. Would you want the RS5 badge?
    In regards to some of the other comments:
    1) QNX uses a custom OS but code is a combination of C/C+ and builds it's applications with a number or technologies including Java and HTML content.
    QNX is also currently under acquisition of another very large very prominent company. I haven't done any research on this and was given this information by a person who works for one of the companies so I am not going to say who or what just in case it's not public.
    2) As far as cloning goes, been done already and not impossible. The only catch is it is set in it's programing (allocation table) to be a specific drive size so upgrading to a larger disk just leaves you with unallocated space.
    3) Hitachi is just one of a few drive suppliers. There is no guarantee that anyone's unit is using that specific drive. I myself have a Toshiba.
    4) There is no coin holder listed for the RS5 that I can find so I am guessing it is built into the switch. Now unless you've ordered the part I'm not sure how you can claim you can just swap the part from the S4. It's not an expensive switch but I certainly wouldn't make claim unless you've had the parts in hand.
    5) RVA is correct in his Post and My ETKA is also up to date and here is the break down down:
    Radio High - All models regardless of Japan or ROW
    8T0 919 616 K For Start Button equipped cars
    8T0 919 616 N Without Start Button
    Radio Low
    8T0 919 616 M For Start Button equipped cars
    8T0 919 616 Q Without Start Button
    Its that simple.
    Now for those that want the shifter:
    LHD 8K1 713 139 F NOR
    RHD 8K2 713 139 F NOR
    Your looking at about $240 US for this part.
    I'm not interested on going back and forth over this. I try not to speculate and provide the information as best I can but I think I have a pretty good background on nailing these things down.
    Dec 03 2006
    Singapore
    Thanks Dave,
    i know exactly which panel to order now......
    the price is Ouch! but hell, it looks great :-)
    Nov 06 2009
    Quote Originally Posted by decksurgeon View Post
    Thanks Dave,
    Well I hope you post some pics and report back on the whole coin slot thing. Your probably right about it fitting but at least everyone will know if they need to order the switch if it doesn't.
    On the plus side and this should go for everyone, you'll probably be able to sell your console for a few hundred lessening the ouch factor.
    Dec 03 2006
    Singapore
    Will definitely do, next thing am gonna look up is the ELSAwin workshop manual to see if this panel when unplugged needs a GECKO online link or similar VAS 5051/5052 procedure......that means a trip to the dealer which im really trying to avoid.
    Veteran Member Three Rings csaudis4's Avatar
    May 10 2010
    Quote Originally Posted by S4.2Avant View Post
    I want the silver AND the shifter!
    Quote Originally Posted by L0U View Post
    i like the shift boot/knob, but perfer the S4 for the rest of it.
    I want that shifter
    LOL, definitely guys, no offense but I think Stronic shift knob in B8 A4/S4 looks uuuuuuuuugly... Lucky I got a manual. This is probably the only factor that makes me feel good about manual.
    But after all, guys, what is that button with letter "A" on it right next to parking break lever? Excuse me for this question if it is obvious to all the others.
    Nov 06 2009
    I've had my MMI controls out of the car more times than I can count. Sometimes for a few days at a time. No issues. No dealer visit.
    Veteran Member Three Rings ACowabunga's Avatar
    Feb 24 2010
    OC, CA
    So let me understand this, it pertains to the NAV? Haha. Thanks for that.
    2010 Audi S5: Meteor Grey || Tuscan Brown
    Veteran Member Three Rings Rabbit222's Avatar
    Jan 22 2010
    2014 SQ5
    South Africa
    Will this shift knob work with our current MMI controls? Is it a simple swop out or is there more to it?
    2015 Sepang Blue S3 sedan / revo2 / Milltek / H&R / BBS CI-R / Forge Motorsport CF Intake system /
    2014 Monsoon Grey SQ5
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Feb 24 2010
    OC, CA
    Hi David, please remind me again what is radio high and low again...
    Nov 06 2009
    basically NAV and Non NAV. High NAV Low Non NAV.
    Established Member Two Rings johntnethk's Avatar
    Aug 24 2009
    '09 A4 2.0t AWD, '11 G37S
    You can get one wiht just the S-tronic logo.
    http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
    APR Stg.1/EuroCode Quadtips/EuroCode HFC/KW V1/StaSiS RSB/VMR 710 19x8.5+Hankook EVO/OEM Black Optic Grill/OEM Blk Plate/OSIR CF Splitter/OSIR CF Valence/Rieger Spoiler/RS6 Steering Wheel
    Shipping: OSIR CF Side Sills, RS6 Pedals
    Jan 21 2010
    Singapore
    Quote Originally Posted by johntnethk View Post
    will that actually fit the B8 S-tronic shifter?
    0-60mph 3.63s
    Jul 13 2007
    Hong Kong
    Quote Originally Posted by guy013 View Post
    That's the exact knob I wanted to find. It requires the shifter core to be modified so that it can adopt to the switch at the 12:00 position as oppose to ours at either 3:00 (RHD) or 9:00 (LHD).
    Anyone can figure out the part number for this shifter?
    Before...
    Oct 04 2009
    Macau
    Quote Originally Posted by awhk82 View Post
    Alex, would it need plenty of work to make it done?
    Jan 22 2010
    2014 SQ5
    South Africa
    That S tronic gear knob looks hot!
    Jul 13 2007
    Hong Kong
    It only require to soften the plastic core of the shifter column with a heat gun or a lighter and twist the hook to 12:00 position. Also, the original shift boot need to be used instead of the A3's. My friend has done this on his TT with a TTS knob. Just need to order the knob and I will let you know how it goes.
    Before...
    Jan 22 2010
    2014 SQ5
    South Africa
    Cheers for the info Alex. Please keep this thread updated.
    Established Member Two Rings S4-Tommy's Avatar
    Nov 02 2009
    S4 Avant 2010
    Vienna/Austria/Europe
    Are the buttons made of plastic and painted silver or are they made of alu?
    MTM Audi S4 Avant, phantomblack, S tronic
    Jul 13 2007
    Hong Kong
    2010 A3 S-tronic Shift knob arrived. Hoping to do the conversion within this week. Will keep you guys updated. (sorry about hijacking this post)
    BTW, the part number of this knob is 8P2 713 139 T YVS.
    Before...
    Sep 30 2009
    b
    ^ You have got to have the best interior mods of any of the B8 guys after that shift knob.
    Jul 13 2007
    Hong Kong
    Couldn't resist so I rushed up to my friend's shop and installed the S-tronic knob. Installation took approx. 1.5 hrs. Sorry about the 3GS pics.
    The white plastic rod with a hole on top in the shifter column is the piece that need to be twisted 90 degrees with either a heat gun or lighter to work with the A3 S-tronic knob with the button located at the 12 o'clock position. (didn't take pic after twisted as I didn't wanna interrupt my friend) It is then mated to my original shift boot.
    Installed...
    Before...
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    Ok that's hot. Nice work.
    Dec 03 2006
    Singapore
    Fresh from factory parts bin, its arrived!!!
    now to find time to get it done together with the JHM Short Shift.....
    .....but wait a minute, in the catalog there is now a new shifter knob from the manual S5 sportback with perforated leather on the knob itself.......
    damm......gotta get that one too ................
    ......the endless path has just begun
    Senior Member Three Rings Reinart's Avatar
    Oct 27 2008
    Oslo, Norway
    Is it possible to just buy this part?
    Reinart > Go to thread
    SOLD - 2010 Audi A4 | Quattro | S-line | Phantom Black | Black Leather-Alcantara | B&O | MMI 3G | Sunroof
    RS6-II 20x9 ET35 | 3,2 grill Blacked out | Tint | Needle sweep | VIM | LED full brightness | Removed seatbelt chime | LED licenseplate lights | Xenon fog lights
    May 24 2010
    Los Angeles, CA
    That looks sexy. So sexy it calls for this...
    http://koti.phnet.fi/santamik/sexophone.swf
    How much did the s-tronic shift knob cost?
    Dec 03 2006
    Singapore
    its done!!!
    Enjoy....sorry for the crappy pic, took at at night after the install
