Results 41 to 80 of 110
    Senior Member Two Rings eaniemeanie's Avatar
    Feb 22 2009
    MB C300,1971 911E Targa, 05 Pathfinder.
    Temecula, CA
    Updated first post.
    Long gone ->(2009 Audi A4 Premium current odo 95,000)
    Service history 85K miles.:85K miles......
    Oct 02 2006
    Wadsworth,OH
    Nice show and tell, but I had to laugh. Your last line is "piece of cake" and your first picture has a tranny sitting behind your wheels on the ground.
    Feb 22 2009
    Temecula, CA
    You are correct! Piece of Cake compared to the rear main seal, intermediate shaft bearing retrofit, clutch, air/oil seperator bellows repair, throwout bearing fork replacement, and chain-adjustment changeout I have on the 911...... And I thought I was just going in to replace the clutch! I'm three times in what I figured I was going to spend.... ugggg.
    Deactivated Four Rings Kay15's Avatar
    Jun 12 2009
    Audi A6
    Norway
    Yes please and maybe some pictures of tools used? Also how hard was it to get the pads to sit right? I heard you need a special tool to push them in or something?
    Feb 22 2009
    Temecula, CA
    The pads fit right in without adjustment, you can see the hangers they rest on in picture 6 above. The last photo in post 45 shows the spreader that I modified to fit into the small hole on the outside caliper face, leave the old pad in to press the caliper back so that you can fit them on the rotor. All the other tools are basic tools including a torque wrench...
    I don't want to give to much detail since I'm worried that someone uses the DIY and screws up. If you're comfortable in doing the job you should figure out as you go.... it's really simple.
    Jun 12 2009
    Audi A6
    Norway
    Well some more detail may help guys get through it a little easier :) .. that Spreader is the only thing anyone would really need to look into.
    Feb 22 2009
    Temecula, CA
    Right! honestly it's real simple. The spreader was a whole $8 at the auto store. That's $12 in Toronto, $9 in Don Mills and $22 in Oakville..... ;)
    The spreader needed to be modified because it was made to be used on a caliper that had a large opening. The Audi one doesn't have anything more than a small hole (seen in photo 2) So I had to bust off the end of the spreader and funnel it through the hole then attach the black bit on to push against the outer part of the caliper. I've got photos with arrows on the photos for you but they are on the other laptop that the wife is using to shop (damn). I'll put those in when shes not on the comp....
    Ask a question and I'll answer it.
    Established Member Two Rings Ox2gen's Avatar
    Sep 13 2009
    LA
    Quote Originally Posted by eaniemeanie View Post
    I bought one of these spreaders from autozone. How did you bust off the end of the spreader?
    Anyone else use something different to compress the caliper piston?
    ..:B8 A4 2.0T Quattro Brilliant Black:..
    KW V1 | AWE Catback Quads | VMR V713 | Eurocode USS System | Adam's Rotors [Track] | StopTech PosiQuiets | Rieger-Style Rear Lip Spoiler
    Hoen Fogs | Glossy Black Grill | "V-Code" Amber Delete | Blesk LED plate lights | F1 Tint 35%
    Feb 19 2010
    Newbury Park, CA
    Quote Originally Posted by Ox2gen View Post
    I used a spreader from a Harbor Freight kit. Worked okay, but slow.
    - Mike
    2013 Audi Q5 2.0T / 1986 Porsche 911 Turbo (West Coast Editor for Autoblog.com)
    Feb 22 2009
    Temecula, CA
    I'll give you more details later I gots to go to bedz.
    I've put about 500 miles on the new pads and they're great!
    pad release hole
    two bolts
    pad placement
    brake pad sensor area
    Brake pad spreader (modified)
    Jun 02 2009
    San Francisco
    Particularly interested in dust and noise of these pads.
    Feb 22 2009
    Temecula, CA
    I'll be putting on approx 1000+ miles the next few days.....we'll know then!
    Feb 22 2009
    Temecula, CA
    Less dust but at low speed (in a drive through) they did squeek a bit. But they seem to have a linear or smoother braking.
    Mar 15 2009
    what are torque specs for caliper bolts?
    2009 A4 Black 6MT STaSIS Touring #130
    -STaSIS ECU, cat-back Exhaust, STaSIS rear-sway bar (22mm), STaSIS lowering springs, STaSIS braided brake lines, STaSIS / Carbontech AX6 brake pads (front), STaSIS Monolite wheel (19x9)
    -AWE Tuning Sport Pedal Covers (silver)
    -Black Gloss Grille and Black Gloss US License Panel
    -A4L fog surrounds
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    I posted this iny my S5 Brakes thread, but maybe this location is more appropriate.
    Am I getting close to needing new pads? I think it should be ok, but some articles I've read online say when you are near 1/4inch to change the pads.
    Yellow line measures about 3/8 inch and X marks where the wear sensor pin is I think....
    -cW
    2023 X3 M40i Alpine White
    Feb 22 2009
    Temecula, CA
    IMHO I would say that you won't need brake pads until the pad thickness is the same as the metal backing that the pads are built on. You are close. ( See Post #44 Picture#4 for reference)
    I still didn't have the brake wear light come on but changed the pads under the recommendation of the dealer (stealer). It was right before the wear light would have came on after looking at it.
    But I will be pulling these pads off next month since they are becoming a big problem with noise and vibration. I'd rather spend $110+ on stock and live with the dust compared to $180+ and the fricken squeal. (The wife is complaining about it so I'm screwed, add the fact that for a while I've been creeping along on the 91 in traffic and have to deal with the squeal and vibrations every other day... ugg)
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    I ordered some posi-quiet pads to replace my fronts. Only $65.00, seems to have some positive review. No squeak, close to OEM performance and less dust.
    -cW
    Senior Member Two Rings simplicity's Avatar
    Aug 24 2011
    SF Bay Area
    Anyone has the torque specs on the 2 front caliper bolts?
    2011 Brilliant Black A4 Sedan Quattro | 8 speed tiptronic | P+ | Sports Package
    APR Stage 1, EuroCode Alu Kreuz, Hotchkis F&R Sway Bar, Blesk license plate LED, Hoen Endurance fogs, Reiger Style Trunk Spoiler, RS4 Replica Grill, Podi Boost Gauge
    Feb 22 2009
    Temecula, CA
    Quote Originally Posted by simplicity View Post
    Call sunset parts in Oregon, they'll tell you.
    Aug 24 2011
    SF Bay Area
    Assuming we're talking about the same bolts, it should be torqued to 42 ft-lb correction: 140 ft-lb.
    http://www.audizine.com/forum/showth...Tech-ST-60-BBK
    May 13 2009
    2014 Q5 TDI - Current; 2009 A4 2.0T - Sold
    Bergen County NJ
    this might be a dumb question, but is there a measurement (in MM) where the brake pad can go up to until it is required to be changed?
    i.e. if i have about 3MM left on my brake pad, should they be changed?
    Aug 24 2011
    SF Bay Area
    Quote Originally Posted by martian421 View Post
    There should brake sensors to tell you if they need to be changed but that being said a rule I go by is to check if the pad material is less than the thickness of the pad back plate then it's about time to change....this way I dont need to replace the brake sensor.
    May 13 2009
    Bergen County NJ
    does the same rule apply for rotors?
    Feb 19 2010
    Newbury Park, CA
    +1
    I replace when the material is just a little thinner than the backing plate. You want to try to save the sensor (to keep costs down).
    I only replace rotors when they are heavily scored or they measure too thin (with calipers).
    - Mike
    Aug 24 2011
    SF Bay Area
    No, you can measure the caliper or replace it every other pad change....
    Oct 28 2009
    2010 A4 2.0T; 2010 Jetta Wolfsburg
    San Antonio, TX
    Assuming we're talking about the same bolts, it should be torqued to 42 ft-lb.
    Are you sure? That thread said 150 something. And it felt like way more than 42 when I was removing the caliper
    Sent from my DROID BIONIC using Tapatalk
    To Do: Drop
    Done: Bi-Xenons, StaSIS Exhaust, 19x9.5 Avant Garde M310s, tint
    Aug 24 2011
    SF Bay Area
    Quote Originally Posted by Smeghead View Post
    You are correct, 140 ft-lb for the caliper bracket bolt.
    Oct 28 2009
    San Antonio, TX
    Damn, what a bitch that was. After 40000 miles everything was seized pretty good. Have nice new brakes on now though, so all's good. Thanks for the write up OP.
    To Do: Drop
    Oct 28 2009
    San Antonio, TX
    One other thing. When I pulled my old pads there was a shim behind the front pad, is that supposed to stay or go? Seems to get in the way of the pad seating properly.
    To Do: Drop
    Feb 19 2010
    Newbury Park, CA
    The answer is... sometimes. I have seen replacement pads with shims (additional metal plates) manufactured into the pad backing... while other times I have to use the shim again. It all depends on whether you are going OEM or aftermarket pads.
    - Mike
    Sep 13 2009
    LA
    Very good DIY writeup. I'm about to attempt a rotor/pad install myself and have some questions about the torque settings...
    I see the two 20mm bolts that holds the caliper in place has to be torqued to 140 ft-lbs per factory spec, are there any other bolt pieces that must be torqued to a certain setting?
    Like the 30-torx for the rotor, any specific torque setting required there?
    My other question is about the "no-brake-squeal" lubricant. Where do you lube up? Just the surface area between the caliper and pad?
    Really looking forward to doing this myself but I'm a noob when it comes to brake replacement and want to do it properly and correctly the first time around.
    Any input would be greatly appreciated
    Feb 19 2010
    Newbury Park, CA
    The small Torx is just used to hold the rotor in place (so it doesn't fall off) before installing the wheel. Hand-tight is fine, and I put some anti-seize on it.
    I use the 'brake lube' where the caliper touches the brake pad. That is where you are most likely to get a vibration (aka squeal).
    - Mike
    Veteran Member Three Rings AdrianLee's Avatar
    Jul 19 2011
    2016 A7 3.0T & 2016 Q5 3.0T (Wife's Daily)
    SW Michigan
    Does anyone know the torque specs for the Carrier to hub bolts, torque spec for the two caliper slide bolts and the torque spec for the 4 torque bolts on the caliper itself? Any info would be much appreciated.
    Jan 29 2012
    Vancouver, BC
    I am doing the front rotors and brakes tomorrow and wanted to know if you can reuse the brake sensor if it hasn't tripped yet, and can we push the piston back with a c-clamp or do I need the special tool. Thanks in advance.
    Jul 20 2012
    Re: Front rotor and pad replacement DIY
    you need the brake tool from pep boys its free to rent...
    Sent from my Nexus 7 using Tapatalk 2
    2009 Audi A4 White // Tint // VMR 718 19x8.5 et35 // Plastidip (Grill and Emblems) // OEM BT Adapter for BT streaming // H&R OE Sport (yet to be installed, sitting on garage floor)
    2005 Toyota 4Runner SR5 4WD // Tint // Toytec Ultimate Lift Kit (3" Lift) // American Racing Mojave Teflons // BFG Muds 265/75/16
    Jul 20 2012
    and yes u can re use the sensor
    Jul 19 2011
    SW Michigan
    Does anyone know the torque specs for the Carrier to hub bolts (Front and Rear), torque spec for the two caliper to carrier bolts (front and rear) and the torque spec for the 4 spline bolts on the caliper itself to connect the halves? Any info would be much appreciated.
    Veteran Member Three Rings gunsmoker's Avatar
    Oct 24 2011
    Mansfield,MA
    Yeah, I also want to know the torque specs for the two pairs of carrier bolts because I'll be switching to S4 carriers. The spec for the carrier to caliper bolt was mentioned as 140, which seems a bit much. I can't imagine what the larget carrier to hub bolt will be speced to.
    2011 A4 2.0TFSI Quattro 6MT, Premium+, 18" Sport Package, Ice Silver, Light Grey, Dark Walnut, AWE Exhaust, STaSIS ECU Tune, Deval CF Splitter, aFe Pro Dry S Filter, ECode Turbo Inlet Hose, Alu Kreuz, Osir CF Valance, R8 Coil Packs, ECS Two-piece S4 Rotors, H&R Rear Sway Bar, 034 Trans Mount, RS5 Pedals, Ultra Racing Strut Bar
    Established Member Two Rings Tineo's Avatar
    Jul 08 2013
    Dairy Land, Asturias - Spain
    Quote Originally Posted by gunsmoker View Post
    ...I'll be switching to S4 carriers. The spec for the carrier to caliper bolt was mentioned as 140, which seems a bit much. ....
    hi gunsmoker, i will upgrade to s4 calipers too.
    30 Nm is the torque spec for this bolts
    2008 A4 B8 3.0tdi Quattro Sedan 6MT EuroSpecs
    Ibisweiss | TLR remap to 301hp | S-Line interior | Rotor 19" rims | S4 front & rear brakes | Depo taillight LEDs w/ fulldynamic LED turn signals | 80mm exhaust tips | S4 blackgloss grill with blackgloss valence | S4 pedals | RSNAV 8.8" ...and more
    Oct 24 2011
    Mansfield,MA
    Quote Originally Posted by Tineo View Post
    It looks like it's 196 Nm. 30 Nm is the carrier-to-caliper bolts torque. I also ordered replacement bolts for the carrier-to-hub-housing bolt as AdrianLee says.
    It has a locking washer so it makes sense to replace it.
