So I fixed the speakers popping, it was the ground behind the head unit. There is still alternator humming, and I am almost positive it is from the power wire behind the steering wheel. So question number one is where else can I tap into power that turns off and on with the car...The other situation is I am only getting 4 volts of power to the amp..I tested the battery, before, and after the fuse, and everything is normal. I just figured it was a bad ground, so I sanded down part of the frame and put a bolt through it nice and tight...still only 4 volts (my friend was testing on the allen bolts that crimp down the power wire on the amp.)
