Page 1 of 5 123 ... LastLast
Results 1 to 40 of 180
    May 21 2007
    Florida
    Ultimate Avic-d3/double Din Navi/dvd Install Thread!
    The following is information ive put together to help ease the installation of my avic-d3. i am posting it here for you, so you dont have to do the endless searching that i have been doing for the past 4 days.
    DISCLAIMER********
    The following information was gathered by me, myself, and I, but was in no way shape or form written by me. I give all credit to the people and websites I got this information from. I gathered this for installing a Pioneer Avic-D3 navi/dvd double din aftermarket radio, but I would assume that this will work for all double din units(except the bypassing the motion sensor part). I am not held responsible for any of your mistakes. Whether that be messing up your unit, messing up your car, or you ordering parts that are incorrect. Remember, these are the parts I used/will be using for my Avic-D3 install. If you are not installing a D3 than you may want to do a bit more research just to be positive these are the parts you need for your unit.
    Parts needed:
    -Metra 70-1787 wiring harness
    -Metra 99-9102 dash kit (cut the bar in the middle with a dremel to fit your double din radio) OR Scoshe double din dash kit (which seems to fit better, can get on scoshe.com)
    -Pioneer adt-va133 mounting bracket (or if youre handy, make your own)
    -Metra 40vw53 antenna adapter (if you have an amplified antenna)
    -Stereo removal keys
    All of the above is available on enfigcarstereo.com except the mounting bracket which can be purchased on bestbuy.com.
    -DummptyHummpty’s audio thread located here.
    Removing factory radio:
    -Tdiclub.com
    (not and audi radio but same process, lock the keys in the slots and pull)
    Metra wiring harness (a4 96-up):
    See what other models these directions can be used by here.
    Non-Bose:
    Use the White, White/Black, Gray, and
    Gray/Black speaker wire for the front speaker
    output and use the Green and Purple
    RCA’s for the rear speaker outputs. Be sure
    to connect the Blue/White wire to the aftermarket
    radio’s amp turn-on wire. The White
    and Gray RCA’s will not be used.
    Bose:
    Use the White and Gray RCA’s for the front
    speaker output and use the Green and
    Purple RCA’s for the rear speaker outputs.
    Be sure to connect the Blue/White wire to
    the aftermarket radio’s amp turn-on wire.
    The White, White/Black, Gray, and Gray/Black
    speaker wires will not be used.
    For all models with power antennas:
    Plug the Blue wire (supplied) in the position
    above the Yellow wire. Be sure to connect
    the Blue wire to the aftermarket radio’s
    antenna turn-on wire.
    -Metraonline.com (search for wiring harness part #, then click ‘factory instructions’)
    Mounting the GPS antenna:
    “Right above the fuse box there is a great place to stick it. The GPS antenna is magnetic so just slap it on the metal support bracket for the dashboard.
    I have mine there and it always gets 5-7 satellites”
    -Greg@DTH on audizine
    Or you can mount it in the trunk as seen here.
    -nav-plus.com
    Bypassing avic-d3 motion sensor(to play dvd’s while driving):
    On the RCA harness (the one with all the component connections), Take the yellow/black wire & pin out and move it to the hole directly above it. Ground that wire along with the green parking brake wire and you’re done.
    -avic411.com
    Creating a remote turn on/ignition wire:
    You can either tap your actual ignition wire or run a wire to the fuse box to a turned on ignition lead. If you don’t use homelink, you can tap into that. Or you can tap into the stock radio power lead. I’m sure there are others but those are the two examples I was given.
    -Condo and 3.0LAudiA4 on audizine
    Also, check out this tech article for the b5 platform on audiworld.com
    -Link provided by Scorneil of audizine.
    i plan on adding more install pictures and information from doing my install. this wont be for a week or two until i get everything shipped to me. ill keep you posted!
    2018 Navarro Blue Q5
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    Re: Ultimate Avic-d3/double Din Navi/dvd Install Thread!
    this is consistent with what I've learned.
    what is the remote turn on / ignition wire for (do you just mean switched power?), and where does that connect to the D3 (if something other than switched power)? i haven't seen that in any other instructions...
    hope you get the install done and the pics up before i do mine (i think mine will be Dec-22ish)
    PS - the trim ring that comes with the D3 does not fit the metra dash kit, nor does it really fit the D3 that well (there's a big gap). will need to do some custom work here (some peeps have trimmed the D3 supplied ring to fit into the metra kit and ignored the gap, others have had a custom ring either made for them or made one themselves). i'm checking prices next week from a shop to see what they would charge to custom make a ring.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Ok hold up....
    So the Avic-D3 will work for Bose equipped cars?
    I want to go the D3 route badly but do not want to touch my stereo (which I love and is BOSE)
    -Sami-
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    Yeah itll work, ive had a D1 installed in my Bose equipped car for almost 2 years now...
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    what about pics of it installed?
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by jon102034050 View Post
    So why does every car installer and pioneer.com say otherwise?
    I believe you....just asking
    -Sami-
    May 21 2007
    Florida
    not sure. those directions i got directly from the metra website, and they say you can hook it up to bose. so ill believe them. i know some bose systems(like in my old nissan) have amps on the speakers, which means the aftermarket HU sends a amplified signal, then the speaker amplifies it even more, and you get static crap. i had to wire it all crazy to bypass this. but our audis apparently have an amp under the seat or something that power the speakers instead. maybe that is the determining factor to your question.
    Quote Originally Posted by vdubstreets View Post
    i will have pics after i install it. if any members want to add picture of theirs, feel free!
    May 21 2007
    Florida
    Quote Originally Posted by scorneil View Post
    that would be the wire that makes it so the D3 turns on only when the ignition/car is on. it goes to the wiring harness, not the d3 itself.
    May 31 2007
    Montreal
    Quote Originally Posted by doublezero30 View Post
    sorry if I missunderstood.
    With the Symphony II, I was able to turn on the radio without turning on the ignition. Now with the D3 I must turn the ignition/car on. Is there a way to have the D3 work like the Symphony?
    Veteran Member Four Rings dummptyhummpty's Avatar
    Sep 17 2004
    Los Angeles, California
    doublezero30,
    Nice thread. It's kind of like the one in my signature. Feel free to copy any relevant info from that thread to here. I have some info about keeping the steering wheel controls. Now that winter break is coming up I will add more info about using the OEM GPS/Sat antenna.
    Quote Originally Posted by 3.0 Rider View Post
    Nope
    Ok hold up....
    Yes.
    If you need to contact me, send a PM.
    1965 Corvette Stingray
    2003 Audi A4 1.8tq (RIP: 2/10/04)
    2004.5 Audi A4 3.0q (Sold: 8/15/09)
    2003.5 BMW M3
    2013 Ford Edge Sport AWD
    A4 Stereo Information Thread
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Great job for that ^^^^ Good job on the DIY!!!
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    thanks a lot! i've been waiting on a z2 for some install instructions. now i can get it! w00t!
    Oct 27 2007
    I know dummptyhummpty said no, but i'm not sure about that. the d3 harness has wires for both switched (red wire) and constant (yellow wire) power.
    Sep 17 2004
    Yeah your right, I should have been more clear. You probably could wire up a switch that connects the switched to the constant so at times you can have it on with out the key in.
    2003.5 BMW M3
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    yes the d3 works with bose i have it with bluetooth there is some ground noise but its not bad unless your an audiopile
    Registered Member Two Rings wunder wagon's Avatar
    Nov 04 2007
    03 A4 1.8T 5MT Avant quattro
    Arkansas
    I'd like to see some "installed" pics of any of the AVIC series headunits.
    1.8T Avant quattro| Official AR Thread | Deviant:Speed
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Apr 04 2007
    2003 A4 1.8TM, 1987 325, 1987 528
    Columbia/Nashville, TN
    These threads NEED to be linked in one of the stickys up top. We are posting a lot of good info, but I still see a thread a week asking about this stuff.
    Robbie
    2003 A4 1.8TM
    Motor F21 Turbo, FMIC, Green Tops, Meth Injection, Motoza Tune, Carbonio, Forge DV, Ecode Test Pipe, Neuspeed Catback, 034 Motorsport Solid Mounts
    Suspension Statis SS, Antera Type 309 18x8
    Interior/Audio Pioneer D/D Head, JL 450/4, JL 500/1, JL ZR650's, 2 - 8 JL 8W7's
    May 21 2007
    Florida
    Quote Originally Posted by Condo View Post
    do you know what dashkit that is? looks amazing.
    Quote Originally Posted by LavaSurfer View Post
    i agree.
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    I think it's still the same dash kit with a different trim ring. I sent a PM asking how he got it to sit flush like that and never heard back. I guess he just made some custom brackets.
    Here is another post with the D3 sitting flush:
    http://audizine.com/forum/showpost.p...7&postcount=15
    He had a custom install done and mentioned that epoxy was used.
    Registered Member Two Rings moo5e's Avatar
    Nov 20 2006
    durham region, ont
    any idea of the autotoys kit is the same as the metra kit in terms of needing a custom trim ring and looks?
    If it rides on rails, u're not going fast enough
    Oct 27 2007
    Quote Originally Posted by moo5e View Post
    i am pretty sure the autotoys kit shown here http://www.autotoys.com/x/product.php?productid=2465 IS the metra kit
    Sep 17 2004
    Same with the one in my signature. These questions are always coming up.
    2003.5 BMW M3
    Registered Member One Ring Dafljigga's Avatar
    Oct 09 2007
    2004 Audi A4, 2006 Range Rover
    Franklin Lakes, NJ
    Question what is easiier to use a Avic D2 mount or the Pioneer adt-va133 ??
    Sep 17 2004
    Quote Originally Posted by Dafljigga View Post
    I heard that the D2 mount fits better.
    2003.5 BMW M3
    Oct 29 2005
    10speed
    San Francisco, CA
    3 Things
    1. How the hell do the rear speakers hook up? Where do you put those RCA outputs?
    2. My D3 only turns on when both the 12V wire and yellow wire are connected to each other. Am I missing some way to turn it on with the accessory?
    3. Im missing the North East Disk can anyone burn that and send it to me? I can paypal!
    - Clint
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    1. Do you have the Bose system? What you hook up depends on what system you have.
    2. You have to run a separate ACC wire. I ran mine to the homelink fuse in the fusebox.
    3. There isn't a Northeast disc. Just East and West. Are you missing the East?
    Oct 29 2005
    10speed
    San Francisco, CA
    1. Non-Bose
    2. So I dont hook up the yellow wires from the harness to the D3?
    3. Affirmative
    - Clint
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    1. I don't think you use the RCA connections if you have non-bose. I'm not 100% sure because I have the bose system.
    2. Connect the yellow wire from the D3 to an ACC connection at the fuseblock. The homelink fuse works for sure.
    3. Check ebay for the discs.
    Sep 17 2004
    3 Things
    1. I'm kind of tired, but I believe there is an amp for the rear speakers on the non-bose system so it should hook up the same way as the Bose system, assuming you have the right harness. Which harness do you have?
    2. Don't know much about this I used the PAC SWI-X which takes care of turn on for me.
    3. PM Me and I can probably help you out.
    2003.5 BMW M3
    Oct 27 2007
    You definitely use the RCA to hook up the rear speakers even without Bose.
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    May 21 2007
    Florida
    man! READ MY ORIGINAL POST!
    Non-Bose:
    RCA’s for the rear
    also, i used the ignition wire for my turn on wire. theres a picture of it in the A4mods.com turbo timer writeup. drop the kneebolster and its wrapped up with a bunch of wires on the right kinda above the clutch pedal(assuming your upside down under the dash, and that you have a clutch). unwrap the tape on the wires and spread them, its the really thick black wire.
    Apr 04 2007
    Goto the link below and about 3/4 I have posted pictures on how you can hook up your head unit with and with out bose if you do not want to buy a premade harness.
    clicky click click
    Robbie
    2003 A4 1.8TM
    Oct 29 2005
    10speed
    San Francisco, CA
    dude wtf does that mean? Where do I put the green and purple RCAs?
    - Clint
    Oct 29 2005
    10speed
    San Francisco, CA
    bump for my confusion I have the right harness
    - Clint
    May 21 2007
    Florida
    green and purple from the metra harness go to the back of the D3 to the RCA's marked "rear speakers". i take it youve never installed a car stereo before?
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    It certainly doesn't help that they don't tell you left from right, positive from negative for the green and purple RCA's on the instructions for the Audi amp harness. I had to plug them in and test and then switch them and test to make sure it was right. Did my Avic last night and it came out well, but DAMN there were some wires to cram back there! Took a long time, but I don't regret it AT ALL! This is one hell of a HU!
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Oct 29 2005
    10speed
    San Francisco, CA
    haha Ive done plenty of them but they usually come with 4 wires that you just connect up. I dont like this RCA business
    - Clint
    Apr 04 2007
    Actually, they usually don't come with instructions because all you have to do it match the colors up.....
    Robbie
    2003 A4 1.8TM
    Mar 05 2007
    San Antonio, Tx
    Yeah cause green = red and purple = white...or is the other way around.
