Results 41 to 80 of 116
Hybrid View
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Re: Install coming home feature?
    Bische! get the DIY up for this ishh ASAP!
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    I was reading on my manual and this feature requires a timer and other crap. It seems complicated but I'm sure some of you guys can hack the system on the convenience module and get it done.
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Nov 15 2009
    Tacoma
    How would I find out what module I have?
    Senior Member Two Rings al3x's Avatar
    Oct 08 2007
    Norway
    Quote Originally Posted by dannyn View Post
    You could locate the module it self and check the part number, or go to the Central Electronics (number 09) tab in vagcom and read out the part number there. Should end with an F to make it easiest.
    Aug 16 2009
    In the OK Corral
    There's a post on the thread that refers to it.
    Oct 08 2007
    Norway
    There, probably some mistakes with spelling and so on but Enligsh is only my second language.
    Click me :)
    Senior Member Two Rings SilvA4Q's Avatar
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    thats a great write up. honestly! since my car has the E control module, I need to look for the F, correct? Is it referred to as the ignition control module? I tried looking online (ebay) and that was basically all that came up with module and notations of E or F.
    Current:
    '14 S4 Premium Plus
    ll S Tronic ll Glacier White ll Bang & Olufsen ll Sports Differential ll Black Optics ll APR Stage 1 ll CR-15 ll H&R Front and Rear Sways ll AWE Touring Exhaust ll Afe Cold Air Intake ll
    Veteran Member Four Rings Bische's Avatar
    Jun 03 2009
    2002 Big Block Avant
    Sweden, north
    Quote Originally Posted by SilvA4Q View Post
    I think its called comfort module.
    Oct 08 2007
    Norway
    That's right! You need to switch it with the F module :)
    Oct 16 2006
    Naperville
    Quote Originally Posted by al3x View Post
    Do you specifically need an F module or any module after that sequence. I have an N module from a b7.
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by manguyen View Post
    From what i have read, as long as its not an "e" module its doable.
    "E" is the "lowline" module and the rest is "highline", and you need a "highline" to get the OEM cominghome.
    Aug 26 2005
    No, the module is the Central Electric Control Module
    Established Member Two Rings charkey's Avatar
    Jul 08 2009
    '06 Kona Coiler Supreme
    Houston, TX
    Re: Install coming home feature? *Video teaser*
    Quote Originally Posted by Bische View Post
    I tried to search but found 0.
    Can you install coming home? Just need the switch + vagcom?
    switch
    What does the second knob control? The one that has 0,1,2,3 as options. I have CH on my 05 1.8T USP, but I don't have that other knob.
    2005 A4 1.8TQ USP 6MT Dolphin Grey
    - APR STG1+
    - Milltek Exhaust
    Oct 08 2007
    Norway
    Quote Originally Posted by charkey View Post
    It's for halogen headlights, height adjustment.
    Oct 16 2006
    Naperville
    can someone actually post up the part number for the said module.... it might help out alot of users.
    Established Member Two Rings fastfastcorrado's Avatar
    Jul 17 2008
    1993 Corrado SLC, 2018 Audi SQ5 Prestige, 2018 BMW X1 M Sport, 2010 VW Tiguan Wolfsburg
    Grand Rapids, Mi
    This is the part number a recent VAG log shows me from my car.
    8E0 907 279 F
    I don't have the coming home feature and now think I would like it. I looked to see if by chance the wiring is there already but I could not find it. If I follow the wires from the light switch to where they runs behind the relays, there appears to be something wrapped up inside that cloth tape, because the diameter of the bunch about doubles.. I just can't reach in there to unwrap it so see if it is what I need. It would sure make it easier than running new wires.
    Oct 08 2007
    Norway
    Quote Originally Posted by fastfastcorrado View Post
    8E0 907 279 F
    My connector was tied up to the light switch cables with zip ties and covered in black tape. Was lying just above the fuse box.
    Helps to lower the cover underneath the steering wheel!
    Jul 17 2008
    Grand Rapids, Mi
    That sounds just about what I am seeing. It appears to be further into the foot well for mine though. Just out of my reach. The wrapped group of wires branches out just as it comes from around the relays. There is a set that goes to what looks like a sensor or thermostat in the dash vent, another to the light that illuminates the vent icons and the rest continues on to the light switch.
    But before all that - the wrapped set is really thick like something is tucked away in there. So I'll investigate a little more.
    thanks al3x for that tip. If I have the connector and wires then it looks like I just need to get a switch!
    (ps. I think I have a light sensor, I have retrofitted a compass mirror from another A4 that had the coming home feature, just VAG doesn't recognize it, compass and autodim work though).
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    do you or anyone else have a picture of the cable? i have the highline module as well as all the DIS features (fuel consumption, bulb out warnings, etc.) but i cannot find the hidden connector for the life of me. any idea of where this is hidden? if anyone has a picture of the connector that goes to the Coming Home switch and where the wires originally come from behind the headlight switch, it would be greatly appreciated.
    Current:
    '14 S4 Premium Plus
    Jul 17 2008
    Grand Rapids, Mi
    I have a cell phone picture of it, I will email it to you if you would like. I would post it up but I haven't figured that out yet. The picture is of a factory installed plug. The plug pig tails out of the main light switch harness about 8 to 10 inches down so you shouldn't have to look very far. Mine car did not have it. I spent 45 minutes unwrapping the harness before I gave up and decided to look at the control module plug to see if pin #24 was connected. It wasn't so I knew right then I need to make my own. I ended up making a connector from a plug that goes to a PC motherboard.
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Can you upload the pdf again...?
    The first ever "Matte Denim Blue B6 A4" ...
    GT2871R Eliminator Installed
    And........I'm back in love with the car!
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    I'd like to do this as well, and went to grab the PDF and Rapidshare has a 10 download limit. If you need somewhere to host the file, PM me and I will put it on my server.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Oct 16 2006
    Naperville
    anyone ever see if they could retrofit the range adjusting switch also?
    Aug 26 2005
    Sure, you can buy the harness from Kufatec.
    Aug 26 2005
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    Has anyone ever followed this DIY for the auto headlights? Im just wondering if because it is a C5 A6 the pin configuration on the module and headlights will be different. I tried comparing it to the coming home DIY write up by al3x and it matches up for the most part but there are extra pins being added to the headlights and comfort module and some pins dont run to the same connections in the different write-ups, leading me to believe that there are differences with the C5 A6 and our B6's.
    Any insight would be greatly appreciated, I would love to be able to add the auto headlights now that I have the coming home as well as the auto dimming rearview that has the light sensor.
    Current:
    '14 S4 Premium Plus
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    its surprising no one has retro fitted auto headlights, I've ran searches to see if there are any write ups on how to do it and no one has made one other than the write up for the C5 A6, hopefully I'll be able to pick up a used auto headlight switch soon and try it out.
    Current:
    '14 S4 Premium Plus
    Jul 17 2008
    Grand Rapids, Mi
    I did, when I wired up the coming home feature.. but I never got a switch to try it out.. I lost on ebay.. I think it works though becuase if I turn the headlights off and stop on the parking lights selection, the headlights stay on for about 5 seconds..
    May 07 2010
    woodbridge, Ontario
    I just went out with the VAG COM and found out that the part number on my module end with an ( E ) I do have factory HID's and the have the height adjustment on them when going down hills and up hills.
    could I simply add to this using OEM parts to have the coming home feature with all the parking lights coming on with unlocking ? I really didnt want to go the relay route and only have the fogs come on. I would rather have the lights all the way around light up.
    Oct 16 2006
    Naperville
    im sure you'll need the sensors. the switch works if you leave it on auto, the headlights will turn on when you start the car and vice versa. but this is not truely auto headlights where its light sensitive.
    Oct 08 2007
    Norway
    Sorry guys. I've lost the file, hard drive crashed the other day.
    But if someone who downloaded the file could re-upload it that would be great.
    If not I guess I'll have to translate it again.
    Nov 15 2009
    Tacoma
    http://translate.google.com/#
    It can be your friend if you let it :)
    Jul 17 2008
    Grand Rapids, Mi
    I have a copy of the DIY from al3x... I just don't know how to upload it.
    MikeWire, PM me with your email and I'll forward it to you so you can post it for everyone else.
    Mar 08 2007
    Air and water
    SATX
    PM sent
    -Mike
    @countdowngarage
    Jul 17 2008
    Grand Rapids, Mi
    Check your email!
    Mar 08 2007
    Air and water
    SATX
    -Mike
    @countdowngarage
    Jun 03 2009
    Sweden, north
    So im progressing finally, sorry for being lazy as hell but ive had tons of work on my table past months
    I have completed the harness:
    Next is to install into the car and test it, then write down how i did it for you
    Senior Member Two Rings ChrisFurlong's Avatar
    Mar 25 2009
    2005 Audi A6 3.2 Quattro S-Line
    UK
    I'm really looking forward to seeing if this works, but you might want to shrink the image a little bit :)
    2005 Audi A6 3.2FSI S-Line Quattro Stratos Blue
    19x9 S6 / Half Leather Interior / Memory Seats / Black Headlining / S6 Paddle Wheel / S6 Exhaust
    Front & Rear Parking Sensors / TPMS / Adaptive Xenons / Actuated Boot Lid / Bose / Sat Nav / Bluetooth / Sunroof
    Double Glazing / Auto Dimming Interior & Exterior Folding Mirrors / Storage Pack / Lighting Pack
    Jun 03 2009
    Sweden, north
    Quote Originally Posted by ChrisFurlong View Post
    Uhm on my screen its resized, maybe thats firefox...
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    Any progress on the write-up Bische?
    Current:
    '14 S4 Premium Plus
