Results 1 to 17 of 17
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    Lowering my car in Montreal? Recommendations?
    Do you guys think it is worth it to lower my car here in Montreal?
    The roads here are ridiculous potholes everywhere
    Will I completely screw up my suspension if I were to lower my car say 1.4" in the front and 1.3" in the back?
    Eibach pro lowering kit & Bilstein shocks are what I would use if I did do this.
    The car will only be used in the summer
    what models of each should i be looking for?
    Veteran Member Three Rings Antoinebourdeau's Avatar
    Jul 17 2008
    2005 Audi A4 1.8t Quaslow
    Ottawa Canada
    Re: Lowering my car in Montreal? Recommendations?
    I think you will be fine if you lower your car. just don't lower it to the extreme.
    I say 25 to 25 1/2" from the ground to fender should give you plenty of clearance while eliminating the fender gap.
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    what do you mean 25 to 25?
    Veteran Member Four Rings deucescorner's Avatar
    Aug 26 2008
    None
    None
    You'll be fine. I lowered my previous car 1.5" front and 1.6 in the back on low pro tires and i never had a problem. I was using eibachs with kyb shocks
    On my current car i'm slammed and no problems at all. I'm using H&R coilovers.
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    nothing ever happened to the suspension?
    how much did it cost you to do it?
    what exactly do I need to do it
    shocks and springs only?
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    Springs should do it but it's best to change both the shocks and springs at the same time.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Jul 17 2008
    Ottawa Canada
    Quote Originally Posted by anthony911 View Post
    I mean lowering it to be between 25" and 25 1/2" from the ground to the top of the fender.. so like 2"(?) lower then stock non-sport?
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    Ok so what am i looking at
    eibach springs
    billstein shocks?
    any models in particular i should be looking at
    what would this cost me..labour and all
    Mar 19 2004
    Give Rombotis Tuning or High Performance Autosport a call. They should be able to help you out.
    Senior Member Three Rings 1blka4's Avatar
    Oct 27 2007
    A4-Harley Nightster
    Montreal
    droppin ur car depends on quiet a few things. are u looking for comfort, or just stiff ? also the size of ur rims and tires. these i believe make the best ingredients. in montreal, i've been driving with stock shocks and h&r springs for about 2 years and i use to have a reiger kit. very tricky with pot holes, corners and some streets where they dont care about our lowered cars. so the best thing at the end is wat u r looking for, if its comfort get some coilovers cuz eventually u'll get them(do the best work). but if u jus want a drop regardless of feel then spring it with some shocks. good luck
    Trapped in a Maze...
    Veteran Member Four Rings headshok2002's Avatar
    Jan 22 2005
    2010 VW Passat Highline wagon
    Sudbury, ON
    Umm, not exactly. You don't need to go coilovers to compete with a good spring/shock setup.
    If you get adjustable shocks, you have as much control over "feel" as you do with coils, really... you just don't have height adjustment with a spring/shock combo.
    Some coils are such a PITA to adjust that you're better off buying a pre-set shock and spring combo because they usually feel good out of the box.
    I used to ride FK Koenigsports and they felt alright... they were too soft for the first year I owned them, and it took that long to work up the nerve and patience to rip them out to adjust the dampening.
    Currently I have bilstein sport shocks and neuspeed sport springs, and I love the setup. A bit stiffer than OEM, but definitely very nice ride and improved handling.
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    I'm looking for a nice look but I don't want to sacrafice all the comfort the car has. I want it to stay a decent smooth ride. I was thinking about getting H&R or Billstein shocks with Eibach springs I wasn't sure if I should get the coilovers
    I'm looking to drop it about 1.3 inches
    My tires are 235/40/18 my rims are 18x8 ET35
    the car is a 99 A6 2.8 Quattro
    thats the info that I think could best answer this thread
    I don't want to drive and feel like I have no shocks I would like the drive to stay as smooth as it can with a dropped car.
    Mar 19 2004
    Billstein shocks with Eibach springs will give you what your looking for. H&R springs are a bit more stiffer. The choice is yours.
    Veteran Member Three Rings joeporto's Avatar
    Mar 06 2009
    MTL, QC
    you'll be fine in mtl with a lowered car "everything you heard is a myth"
    you just need to drive it accordingly, i mean it wasent a suv to start with.
    i know somebody with bilstein hd's on a benz and it's real smooth but high
    and i know somebody with bilstein sport on a audi and it' a bit stiffer them oem but much lower.
    Jan 22 2005
    Sudbury, ON
    Quote Originally Posted by joeporto View Post
    Well the shocks obviously have no effect on ride height... they do have a real impact on ride quality, though. Again, my bilstein sport/neuspeed sport combo is quite comfortable, but it is a lot lower than I thought it would be (quite a bit lower than neuspeed quotes, I think).
    Mar 06 2009
    MTL, QC
    yeah true, i forgot about that
    Jun 22 2009
    Monterrey, Mexico
    I install this past weekend the Bilstein sport - Eibach combo and I feel softer than the standard OE suspension, but the lowering is exactly that I looking for , not too much
    Feel softer with this combo is normal??
