I have an AWE OTS Stage 3 tune, PJ Ko4s and thought I got bit by the turbo bug this weekend. Obviously, whenever something is wrong, this is the first thought.
Ive had a few different symptoms and I'm at a bit of a loss.
*Car starting loosing boost, only hits 17lbs and tapers to 15, as opposed to 21 to 19. This is consistent. I did a leak test and found a leak. Reclamped, system was good.
*Went to change the oil the same day. Had a bit of oil on the bottom of the oil pan and scattered throughout the bottom of the engine. Not alot, but oil nonetheless. Pulled off my IC hoses, found a very small amount.
I always have a CEL for O2 sensors, since Im running AWE DPs and Test Pipes. I just pulled the codes today to see if there were additional codes and found the following:
17530 - Oxygen (Lambda) Sensor Heating; B2 S2: Open Circuit P1122 - 35-00 - -
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit P1118 - 35-00 - -
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High P1114 - 35-00 - -
17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High P1140 - 35-00 - -
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground P1454 - 35-10 - - - Intermittent
17866 - Exhaust Gas Temp Sensor 2 (G236): Short to Ground P1458 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
16685 - Cylinder 1: Misfire Detected P0301 -
16688 - Cylinder 4: Misfire Detected P0304 -
I am going to replace the EGTs. This does not explain the oil. No whine, little smoke out of the exhaust, which has been relevant since owning.
Any thoughts?
