Results 1 to 13 of 13
    Senior Member Two Rings supersweet's Avatar
    Dec 16 2008
    Santa cruz, Ca
    Hose Off Engine/ Wash?
    besides the intake and a few wires, can i wash out my s4 engine with that orange degreaser without expecting problems... ??
    Apr 18 2007
    ny
    Re: Hose Off Engine/ Wash?
    I wouldn't take that chance, just use a wet rag to get the heavy dirt and then a dry rag to clean the rest.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Oct 31 2005
    Ashburn
    I have, just make sure you cover up the intake if it's an open element. I usually make sure the car is hot so the water dries quicker.
    I've done it many times, never had a problem......So i think
    - Instagram: @Sinister_rs5-
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by supersweet View Post
    Yes. You will be fine. Just protect exactly what you mentioned.
    08 S4- Stock SOLD
    Veteran Member Three Rings seadoo4563's Avatar
    Aug 10 2007
    Annapolis,MD
    I wouldnt chance it. we get so many cars here in the shop where the dealer sprays the engine bay or someone does it themselves and they mess something up. use a rag and do it by hand like mentioned before
    Senior Member Three Rings lonestar22's Avatar
    Aug 19 2008
    DFW
    theres so much going on under a B5 S4's hood, id be afraid to wash it
    SGM 330i 6MT/RD PLATE LIGHTS/RES DELETE
    STAGE 1 B5 S4, CAN YOU SAY SLAMMED?
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Heres what you do... I do/did it all the time...
    1) Cover up the intake (open element)
    2) Use the orange degreaser and spray all over the engine bay, scrub all the real dirty areas...
    3) Then make sure your hose is set to "mist" and just slowly rinse all the degreaser/dirt off.. be sure not to spray water directly into any electrical connections and such..
    4) Repeat steps 1 and 2 as many times as it takes to get the engine clean..
    5) I then start the engine up and let the heat it produce dry most of the water out.
    6) I then get Meguires engine detailer and shine up all the plastics.
    Everyone may have there own way of doing this... I do it my way all the time and never had any problems what so ever... just take your time and dont go crazy with the water and you'll be fine....
    Disclaimer ---- I have to throw this in... do this at your own risk.... your car may have an uninsulated/unprotected electrical connection/wire and shorts circuits/electrical problems could possible occur...
    Aug 10 2007
    Annapolis,MD
    Quote Originally Posted by SilverSurferS4 View Post
    lol
    Dec 16 2008
    Santa cruz, Ca
    sounds pretty 50/50
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    ive been always told to
    - Cover intake, battery, and tape up some wires so they are not getting direct contact with water and degreaser
    - Use the Degrease product
    - Spray down engine with water some what
    - Start Engine
    - Continue to rinse off the engine and listen for sputters ( if you here any , stop using so much water)
    - Dry Off
    - Remove all cover up
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Senior Member Two Rings FrnkWhte's Avatar
    Jan 23 2009
    2000 S4
    MA
    I've worked at a detailing shop for some years in the past.. We always covered up the mentioned items listed above. Start the car, rinse/mist motor and surroundings, spray degreaser and scrub the stubborn areas, rinse and dry with compressor hose. I always had the engine running.. As I said this is what I did but any car could have different reactions so do it at your own risk!
    Veteran Member Three Rings B501S4's Avatar
    Sep 09 2007
    01.5 B5S4 Stg III RS6's Built Longblock, Cherokee Classic 4x4
    Raleigh, NC
    i was told by the audi tech that i bought my car from to always wash it out when the motor was running and take it for a spin after washing to get any standing water out that could be sitting in there. i use a pressure washer set on low and i have never used chemicals unless i was just spot wiping but i dont think it would be a problem. i make sure to do this about every 3k miles and i have had no problems and it keeps everything clean.
    Dec 16 2008
    Santa cruz, Ca
    sweet sounds way better. thanks
