Doing a mid-winter oil change & decided to pull the coil packs and plugs for a look see. When i pulled the CPs there was oil in the plug recesses, worse all the way in the front plug near the oil fill, but also back farther where it would be hard for a sloppy tech to spill oil in there. The only one without oil is the rearmost plug.
I'm hoping the tech that did the 50k service just made a mess, but otherwise, does this mean anything? Car runs great, burns almost no oil, the only fault I've had was when I let it sit for 10 days while the weather was bad...
