Results 1 to 15 of 15
    Senior Member Two Rings DonnieD's Avatar
    May 19 2008
    2001.5 Pearl White Audi S4
    Cruise control button broken?
    Yeah, title says it all. I don't think it's a problem with the cruise control because if I press the button enough (and at wierd angles) I am able to get it to kick in. I really wouldn't care but I am getting the APR chip soon and I know it relies on the SET button working.
    Anyone ever have this problem? Cost to replace?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Cruise control button broken?
    You sure it's the button and not a pedal issue? Does it come on consistently when you hit the button at the same weird angle?
    08 S4- Stock SOLD
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    My cruise control doesn't work. Not sure what happened.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    May 19 2008
    What do you mean by pedal issue? And no, I havent been able to get it to come back on in a few days :(. Not even at a wierd angle. It seems completely non-responsive now. I think Im doing everything right. I have the slider button obviously on the ON position and I am still supplying some throttle as Im pushing SET.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by DonnieD View Post
    There are switches on the pedals that tell the cruise control to disengage if the clutch or brake is pressed. They sometimes flake out.
    08 S4- Stock SOLD
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Mine has never worked.
    Senior Member Three Rings Iosilver's Avatar
    Sep 20 2007
    2001.5 Slow4
    Winter Park
    Merv Grazinski set his Winnebago on cruise control, slid away from the wheel and went back to fix a cup of coffee.
    You can guess what happened next: The rudderless, driverless Winnebago crashed.
    Grazinski blamed the manufacturer for not warning against such a maneuver in the owner’s manual. He sued and won $1.75 million.
    His jackpot would seem to erase any doubt that the legal system has lost its mind. Indeed, the Grazinski case has been cited often as evidence of the need to limit lawsuits and jury awards.
    My cruise control never worked till I put my fuse back inn. That story ^^ is fake but makes me laugh everytime I hear it.
    EMpTy WaLLeT
    STaGe: ToTaLeD
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    Mine is flaky. Sometimes it works and sometimes it doesn't. The resume doesn't work at all. When I use it to accell it disengages the cruise. I brought it in when under warranty and they could not find a problem and now I am out of warranty.
    Veteran Member Three Rings hoosierchemist's Avatar
    Apr 12 2008
    2000 Nogaro S4
    Indiana
    Quote Originally Posted by wheel366 View Post
    Generally, if you report a problem before the warranty expires, they are still obligated to fix the problem, even if you are no longer covered.
    If you get it fixed, be sure to let us know what it was, I have the same issues with my cc.
    Sep 19 2008
    Toronto, Canada
    If you have the 6spd, there should be no reason to use it anyways.
    Jan 17 2005
    New Jersey
    Quote Originally Posted by hoosierchemist View Post
    If you get it fixed, be sure to let us know what it was, I have the same issues with me cc.
    I'm way out of warranty. Ended in July 2006. I just deal with it now. Can't justify getting it fixed at the moment even though I use it all the time.
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    When I disconnected my battery and needed to put the code back in for the APR chip, it didnt work. Even though I tried every way and then found the info online. My cel also came on when I used the CC more than 3 times. Then after a few days it would go away. It would work 75% of the time, but some times it didnt. I fixed it by putting in a new CC stalk.
    But you said you have to hold the gas a little longer. I would see if you could clean the contacts and or connectors that are on the pedals. Just to rule out that it isnt a problem.
    As for price I got it for 105 but I have some connections at home. I think its 180 from the stealership.
    Apr 18 2007
    ny
    get a new stalk
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Also, the cruise control switch is a common problem. there is a DIY on AW to open it up and clean the contacts. I guess based on the design, they get corroded or dirty and have intermitten contact issues. good luck
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Apr 12 2008
    2000 Nogaro S4
    Indiana
    Quote Originally Posted by obijohn22 View Post
    i couldn't find the aw tech article... do you have a link?
