Results 1 to 17 of 17
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    2.8 not running so well
    99 a6 avant 2.8tip, i have an occasional backfire and at low rpms in gear it stumbles and occasionally there is a decent amount of jerking and bucking but if i downshift to a lower gear its all gone, car stil hauls ass and gets 17mpg, i pulled codes though a cheap vag-com and got a random misfire detected cant remember exact # PO300 something. i cleared them and they will come back in about a week, when car is cold(under 160oil temp) it runs great and no problems and it seems a decent amount faster when cold, i had a cone filter intake and thought it was getting heat soaked so i switched over to the stock box and felt very little difference in how well it ran, what would it be? im thinking maf possibly, and ideas would be awesome
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Apr 18 2007
    ny
    Re: 2.8 not running so well
    coil packs are usually the first thing to look at with miss fires.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Established Member Two Rings _a6_'s Avatar
    Jul 21 2007
    00' Audi A6 2.8
    St. Paul/vermont
    from what your describing i agree a62turbo i think its the coilpacks that would explain the jerking
    Gone: 2000 Audi A6 2.8 quattro
    Current: 2003 GMC Yukon XL
    C5 Union
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    the 99 2.8 uses spark plug wires, so it is likely not the coilpacks like newer A6s have.
    Have you changed your spark plugs? wires? cleaned maf? cleaned throttle body? cleaned air filter? checked vac lines?
    It's probably one of those... but by now, being 10 years old, I'm sure the car can gain from all the things I listed.
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Apr 18 2007
    ny
    Quote Originally Posted by oc-drop View Post
    shit, I didn't know that. you learn something new everyday.
    SOLD
    Greg
    C5UNION
    Jul 21 2007
    00' Audi A6 2.8
    St. Paul/vermont
    do you know when they started using coilpacks? because i have a 2000 and when i went the dealership because my car was bucking they thought it was the coilpacks
    C5 Union
    Veteran Member Four Rings 2001A6's Avatar
    Sep 17 2008
    Stuff
    St. Charles, MO.
    The 2.8 has coil packs. 3, with 2 wires each. they are in front of the intake manifold under the plastic cover. Then, it has wires running to the plugs.
    ~Matt.
    - PES Supercharged 01 A6 2.8Q
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    plugs havnt been changed yet but i will be, which ones? plug wires look original but ill test the resistance in them to make sure, vacuum leaks very doubtful, i have cleaned the maf and way to test it i really think it it but still not sure, new air filter
    99 A4 1.8TQM:
    00 B5 S4
    Jul 21 2007
    00' Audi A6 2.8
    St. Paul/vermont
    i have a question, my cats went out and im quickly trying to find replacements as my gas mileage has gone to hell and i was wondering if you guy knew if these would fit or not
    http://www.performancepeddler.com/se...4605&x=15&y=12
    really sorry about thread jacking
    C5 Union
    Nov 20 2005
    Quote Originally Posted by _a6_ View Post
    94605 sounds right...
    you can go to magnaflow.com to double check.
    is it 4:20 yet?
    Jan 09 2008
    88'90quattro 98'passat quattro 05. Usp a4 571whp 97 a8 00 TT 99 Passat 2.8l 5 speed 99 Passat 1.8.
    haverstraw ny
    you cant just go looking for the problem like that. you have to know which cylinder is misfiring, then see what causes it ...
    Jul 21 2007
    00' Audi A6 2.8
    St. Paul/vermont
    i searched with the part number and didnt find anything
    C5 Union
    Nov 20 2005
    search by model/make
    is it 4:20 yet?
    Veteran Member Three Rings idrinkv8's Avatar
    Nov 01 2008
    It wouldnt hurt to throw some injector and fuel system cleaner through the system.
    Jul 21 2007
    00' Audi A6 2.8
    St. Paul/vermont
    2.25 inlet and outlet is the right size right?
    C5 Union
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    which plugs do i need, already used injector clean several several times
    99 A4 1.8TQM:
    00 B5 S4
    Feb 05 2009
    Montreal
    So did you find the problem yet? I actually have a 01 2.7T 6spd and it seems to be doing exactly the same. I changed the maf, spark plugs, air filter, we checked all the coilpacks which seems to be working. injectors maybe??
