Results 1 to 40 of 74
Thread: 0w30 vs 0w40
    Veteran Member Three Rings Avant Fetish's Avatar
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    0w30 vs 0w40
    Most people in here seem to prefer Mobile 1 0w40. Its getting very difficult to find around my area.
    The Audi manual recommends 0w30...which I can find Mobile 1 easily.
    Is there a big difference between the two? I live in So Cal and the motor is stock.
    Thx...
    Aug 06 2008
    Canadia
    Re: 0w30 vs 0w40
    not what i would use in that climate, a 0W oil is what you typically run in very cold climates, like the arctic. I know audi says it OK to run mobil1 0W-40 but thats the only zero weight oil they say is OK, every other brand is 5W40, and if you ask me even that is a bit thin.
    If i was you i would stay away from the zero weights, and worry more about the summer time number (the second one) than the winter weight. if you can get mobil1 5W-50 run that, for me i'm going to try out 15W-50 mobil1 next summer.
    the B5 S4 is like the mafia... there is only one way out!
    Jan 11 2007
    Salt Lake City, Utah
    Re: 0w30 vs 0w40
    I usually get my Mobil1 from walmart, not sure which weights they stock. I now run rotella T instead though.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Established Member Two Rings crosenhahn's Avatar
    Mar 13 2008
    2001 Audi S4
    Colorado Springs
    Re: 0w30 vs 0w40
    Royal Purple - 5w-40 is what I have been running for 60k+ miles.. live in CO so our winters are cold and our summers are 90+
    01 S4 - Stage 2+
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: 0w30 vs 0w40
    year round in CT with 0W/40 no problem sat all an di don't use any oil at all. used it for 35 k so far
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    Re: 0w30 vs 0w40
    So nobody uses the recommended 0w30?
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    Re: 0w30 vs 0w40
    I went to a jiffy lube and they filled me with 0w-40.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: 0w30 vs 0w40
    Mobil has a nice locator on their website that shows you stores as well as shops that carry or can get specific weights. Might want to try that if it's the only reason you want to switch.
    08 S4- Stock SOLD
    Jan 16 2007
    Wetzlar
    Re: 0w30 vs 0w40
    I use Castrol 0w30 in my VW w/ 1.8T - all year around in NYC area - no problems
    In my Audi I use now Motul X-lite 0w30, next oil change will be Total 0w30.
    0w30 is not really cold climate oil but energy effiecient oil.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: 0w30 vs 0w40
    imo pentosin is the only way to go, since thats the first oil that your crankcase sees. i kinda agree with macdaddy tho. 0w oil is good for winter months. high heat environments and you could go with a 5w..
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: 0w30 vs 0w40
    I would suggest 5w30 or 5w40 since you're in socal. You really don't need 0w if you're in a warmer climate. Any of those will be just fine for your car. Get what's readily avail. and stick with it.
    --Adam
    Have questions? E-mail me.
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    Re: 0w30 vs 0w40
    Quote Originally Posted by Ianxcom View Post
    thats just asking for trouble...
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: 0w30 vs 0w40
    Quote Originally Posted by Klum00 View Post
    Jiffy lube had to buy my mom a new turbo and engine rebuild when they left the oil filter and drain plug loose and the fill cap off..
    08 S4- Stock SOLD
    Nov 27 2006
    Baltimore, MD
    Re: 0w30 vs 0w40
    i think being a moron is a pre-requisite for working at that place.
    Quattro Kings
    @quattroking
    Jul 30 2008
    Socal/Denver
    Re: 0w30 vs 0w40
    Quote Originally Posted by mholme View Post
    Yeah my girlfriend took her mitsu eclipse there and they put the wrong oil pan plug back in and the thing leaked. Totally stripped the hell out of it.
    I decided to take my chance there though that time.
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: 0w30 vs 0w40
    WOW No local indi shop that would have been better? sometims you get what you pay for, I allways change my owen
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: 0w30 vs 0w40
    Quote Originally Posted by Avant Fetish View Post
    i use 0w30 german castrol in my car all the time from autozone
    Veteran Member Three Rings CheesmoS4's Avatar
    Aug 24 2005
    Silver 01.5 Audi S4
    Northeastern OHIO
    Re: 0w30 vs 0w40
    i use 0w-30 castrl german (european ) blend all year round. And i am oh ohio
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    Re: 0w30 vs 0w40
    Quote Originally Posted by 1997gtx View Post
    --Adam
    I'm going to go to my local Autozone and see if theres a 5w40 available.
    Going to check if they have the 0w30 German Castrol too.
    I ran Mobile 1 10w40 in my SC'd VR6.
    I'd do 5k between oil changes.
    Jan 11 2007
    Re: 0w30 vs 0w40
    Interesting that nobody else uses the 5w-40 Rotella T heavy duty synthetic. I've heard nothing but rave reviews and it's like $15 for 4 quarts at walmart. I also use it in my dirtbikes.
    LOOKING FOR:
    Apr 18 2007
    ny
    Re: 0w30 vs 0w40
    I stick with Mobil 1 5w30, a lot of people confuse the first and second numbers with winter and summer but the first number "5w" is the viscosity of the oil at startup and the second number "30" is the viscosity of the oil at normal operating temp.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    Re: 0w30 vs 0w40
    Quote Originally Posted by jibberjive View Post
    Is this what your using now?
    I'm just a bit confused about the Xw40 that people use vs the 30 that the manual recommends...but I guess that might be a bit confusing too...since they said that if you can't find the 0w30...you can run either 5w30 or 5w40.
    Sep 14 2006
    14 GLI
    Re: 0w30 vs 0w40
    How many of you have gotten your oil tested?
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    Re: 0w30 vs 0w40
    Not all manuals say the same thing. Mine says 5w40
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Sep 14 2006
    14 GLI
    Re: 0w30 vs 0w40
    ^ Updated oil lines FTW
    Aug 06 2008
    Canadia
    Re: 0w30 vs 0w40
    I was going to, i ordered the oil from shell and they sent the store some old ass rotella T from the 90's with a rating that was SH or something. Not only is that oil over 10 years out of date and expried (shelf life is only 3 years for oil) it won't meet the requirments of the audi's engine.
    and whats with everyone saying "no problems with my brand-X thin engine oil" you really don't know if they are any "problems" unless you pull apart your engine and inspect it for wear or your engine 5 years down the road when your engine is worn out. I'M not saying use a bottle of thick-ass lucas, but if your running an oil which is designed to lubricate upto 100 degrees centigrade and your engine operates at 110-120 degrees centigrade your eventually going to wear out your engine. I've put ATF into crankcases of some really dirty engines to free seized rings, and the engine seemed to run just fine, but if you ask me if i think the engine would be OK running ATF for the rest of its life my answer is no.
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Re: 0w30 vs 0w40
    I use 10w-30 most of the year. Stay away from the 0w in hot times.
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    Re: 0w30 vs 0w40
    I use Amsoil 5w-40 all year round. It is one of the viscosities that is recommended in my manual and it meets the VW specs. It may not have officially passed the VW spec but it meets it and that is good enough for me. Never had a problem with it and I use their EaO filter and an secondary oil cooler too.
    Jan 17 2005
    New Jersey
    Re: 0w30 vs 0w40
    I used Mobil 1 0W-30 once then switched to 0w-40 for a little while before changing to Amsoil.
    Jan 11 2007
    Re: 0w30 vs 0w40
    Quote Originally Posted by MacDaddy View Post
    Are you saying the bottle in particular that you got was old and expired etc., or that Shell Rotella T in general is an old oil that doesn't meet Audi's requirements?
    I've heard nothing but rave things about this Rotella T heavy duty synthetic, though I'm sure it's not on Audi's list of approved oils (though I'm not sure cause I haven't cared to check.) Maybe I'll dig up some of the specs and reviews from when I was doing research.
    LOOKING FOR:
    Veteran Member Four Rings Slave IV's Avatar
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Re: 0w30 vs 0w40
    0W30 German Castrol...it seems to be better than 0w40 M1 from the reports I've seen. I've only used it once and so far so good.
    Aug 06 2008
    Canadia
    Re: 0w30 vs 0w40
    yeah, old ass bottle with their old logo they don't use anymore. I looked up the new rotella-T synthetic and it meets all current API standards for gas and diesel.
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    Re: 0w30 vs 0w40
    I checked out the Rotella heavy duty...its for diesels?
    Its 19.00 for a gallon (3.78L).
    Jan 11 2007
    Re: 0w30 vs 0w40
    Yeah, I think it's marketed to diesels or something. I've heard nothing but rave reviews about it though, and I think it's a couple bucks less than that at my local walmart.
    LOOKING FOR:
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Re: 0w30 vs 0w40
    Mobil 1 and Valvoline have a line of racing oil that supposedly have more anti-wear chemicals (2x more than normal oil according to Mobile 1). There is a FAQ on it in their site. I was wondering about this oil because I saw a quart at NAPA (Valvoline Racing Oil) but it has "off-road use only" on the label. I might try this out next change.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    Re: 0w30 vs 0w40
    Walmart is where I saw it. I think I'll give it a shot.
    Thanks to everyone for their replys.
    Sep 27 2007
    Columbia, SC
    Re: 0w30 vs 0w40
    Motor Oil Bible PDF
    Edit:
    I just realized this is 170 pages worth of oil information.
    Definitely throne material.
    96 Soarer GT - Gone
    Jan 17 2005
    New Jersey
    Re: 0w30 vs 0w40
    Quote Originally Posted by Dimcorner View Post
    I read about the Mobil 1 version of the racing oils. It has more Zinc/Phosphorus that is not supposed to be used everyday do to it affecting the environment. I guess they can affect emmission control equipment.
    Apr 01 2005
    one wagon one truck
    Michigan
    Re: 0w30 vs 0w40
    I've been using Rotella T synthetic for about 4 oil changes now and it has been working just fine and cost less then mobile one.
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Re: 0w30 vs 0w40
    What dirtbike you ridin ?
