Results 1 to 11 of 11
    New Big Brake Options for your A6 !
    Rotora has just released a new front BBK for the A6 including Quattro C6 in either 14" 2 piece rotor, 6 piston caliper fitment. Or the monster 15" 2 piece rotor 8 piston fitment for extreme applications. This is a complete bolt-on fitment with everything needed for installation included. With caliper color options of red or blue and rotor choices of slotted or drilled/slotted, the kit can be tailored to your taste at no additional cost. Of course, wheel fitment would need to be reviewed at the time of purchase.
    Key Features:
    Rotora billet aluminum alloy 8 piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
    Rotora billet aluminum hat with "floating" disc assembly to reduce heat related stress and unsprung weight.
    Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (380x34mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
    Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
    Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
    Retail priced at just $2425 for the 14" and $3325 on the 15", feel free to contact me for forum pricing, availability, and fitment.
    [IMG][/IMG]
    [IMG][/IMG]
    Senior Member Three Rings MartyinCO's Avatar
    Sep 21 2008
    Ducati Monster 900
    Thornton Colorado
    Re: New Big Brake Options for your A6 !
    Damn! Looks sweet, also, very cool to see some more ish for the A6's
    It's so much easier to suggest solutions when you don't know too much about the problem.
    Malcolm Forbes
    Apr 18 2007
    ny
    You guys need to fix your website, it is not car specific at all. I entered my car info and it showed me things for a Cadillac CTS
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Oct 09 2008
    Wish the blue set was darker but nice brakes.
    Active Member Four Rings HOFFY11's Avatar
    Aug 01 2008
    Audi A6 4.2L Quattro
    forked river, NJ
    i wish brakes were cheaper, its just not worth it unless you have a 9 second car to slow down..=/..but you want them just to have them...so for most of us a6 guys, i feel those brakes would only value at 600 bucks worth of use lol
    the mods..GIAC ECU chip, GIAC TIP chip, rear lip spoiler,mirror covers, H&R coilovers, Cold air intake, fog light grills painted to match and centers black, Debadged,19" EXE rims w/ falken tires, 2 10" polk subs in custom box,vinyled window trim, dynomat, painted calipers,custom cat back exhaust, cupra r splitter, window tint.....Full Widebody-installed ..soon to come tinted tails, maybe tinted headlights..Oh SO FRRESHHH
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    if i had a c6, id buy these right now
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Responses coming...
    As far as the website, it is simple, you select your make, let it load, then select model, and let it load. If you get all jumping and start pressing buttons, it wont filter.
    Quote Originally Posted by KiloByte View Post
    Brakes can be color matched to you preference for an additional fee, let me know if you'd like to get a set painted and I'll be sure to take care of you.
    Established Member Two Rings RS2urq's Avatar
    Feb 17 2009
    Alpina, Ruf 930, 83 RS2urq +
    Vienna, VA
    It's all about what you want. I would categorically disagree with comments that BBk are not worth it. Audi is known for building great cars with untapped potential. Add boost, suspension, etc. and the HP2's start to just adequate with no reserve.
    I put a set of StopTech 332x32 brake set and they are significantly superior to stock.
    Do I need it? Well, I may track the S6 as a car to give student rides. They work much better on the street, I don't feel they are marginal anymore.
    Brakes definitely add to safety margin in normal driving, and I am sure a marked improvement on the track. Pedal modulation with a 4 piston setup is far superior to the sliders on these cars.
    2012 R8V10 R-tronic hypnotic loaded
    2011 B8S4 Ibis Prestige TI, Alu Kreuz, CF OOcarbon,
    Eurocode bars, end-links and OEM H&R springs
    replaces sold supercharged S6 Avant and UrS4
    URS6Avant still a favorite
    RS2URQ 83 urq with all the right stuff
    BMW M635, BMW 2002 Alpina & almost 2 Audis Touaregs V10 &3.0
    BMW 323i race car and BabyGrand R1
    plus support trucks and trailers
    Feb 18 2009
    2005 A6 4.2 S-Line
    Queens, New York
    Bump, has anyone installed these on their C6 yet?
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    What BBK size would fit under the stock A6 17" BBS wheels?
    Audi A6 2.7T : 6MT : 88K Miles : GIAC Chip : 2.5" Catback : Hotchkis F+R Sways : AWE DTS
