Results 1 to 15 of 15
    Established Member Two Rings S4Andy's Avatar
    04 Cayenne Turbo, A6 2.7T
    FL
    Question 2.7T Throwing some engine and tranny codes. Can anyone help??
    I just picked up a 2002 2.7t quattro. It's giving me these four engine codes
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 35-10 - - - Intermittent
    17887 - Brake Boost Vacuum System: Mechanical Failure
    P1479 - 35-00 - -
    16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
    P0431 - 35-10 - - - Intermittent
    16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
    P0421 - 35-10 - - - Intermittent
    Also the transmission is giving me this one P0741.
    I already checked the Ross Tech website for explanations, but don't know exactly what parts should be replaced (what's a warm up catalyst)?
    Any help would be greatly appreciated!
    Regards,
    Andy
    2004 Porsche Cayenne Turbo some mods.
    2002 Audi A6 2.7t Quattro Fully Loaded.
    2007 RS4 Daytona Gray w/ premium pkg.**SOLD**
    2004 S4 W/Milltek catback exhaust. CPO'd.**SOLD**
    Apr 18 2007
    ny
    Re: 2.7T Throwing some engine and tranny codes. Can anyone help??
    VAG1551 Scan Tool Display
    VAG1551 scan tool
    Possible cause
    Corrective action
    17125 P0741
    ATF level not OK
    Faulty or incorrect converter
    Check ATF level
    => Repair Manual, 5 Spd. Automatic Transmission 01V, Repair Group 37; ATF-level checking and topping off
    Check converter code
    Clutch for bridging converter
    no power transfer
    Pressure control valve 4 -N218- 1) is mechanically faulty
    Problems in the ATF-line to pressure control valve 4 -N218- 1)
    Converter pressure valve faulty
    Torque converter valve faulty
    Continuation ▼
    Read measuring value block => Page AUDI-C5-AT02-01-012-0101-196; Display group number 007 2) check clutch TC (closed) and permissible torque converter slip
    Replace pressure control valve 4 -N218- or valve body
    => Repair Manual, 5 Spd. Automatic Transmission 01V, Repair Group 38; Oil pan, oil strainer and valve body, removing and installing; valve body removing and installing
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Apr 18 2007
    ny
    P1479
    17887
    Brake vacuum system
    Mechanical malfunction
    Perform output Diagnostic Test Mode (DTM) in Engine Control Module (ECM) to check whether the vacuum pump runs or is activated
    Check hose setup to pump or from the pump to brake booster
    Perform a short trip in Engine Control Module (ECM) (basic setting; display group 8 with ignition on and selector lever in "P" or "N")
    SOLD
    Greg
    C5UNION
    Apr 18 2007
    ny
    You need new cats?
    SOLD
    Greg
    C5UNION
    Apr 18 2007
    ny
    Did you try clearing the DTC's to see which come back??
    SOLD
    Greg
    C5UNION
    FL
    Thanks for your replies buddy...For the brake vaccuum can I perform the diagnostics myself? What tools/equipment would I need?
    Can the cats be hollowed out?
    I haven't cleared any codes yet because I wasn't sure how to do that.
    Thank you for your help.
    Andy
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    I read the title and was worried you were going to say P0741.
    Sorry to tell you but you need a new torque converter most likely. I would say its probably a 75%+ chance. Some try to change fluid, as did I, but just wasted 500 bucks.
    There is a TON on here and AW about this just search 'P0741'
    I know you will ask cost so
    - 10-12 hours labor
    - 500-850 for the part
    - total TC replacement 1400-1800
    - dealer prices will be higher
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Apr 18 2007
    ny
    Quote Originally Posted by 2.slowT View Post
    - 10-12 hours labor
    +1 Mine was changed about 6 months ago, thank God I was still covered under CPO
    SOLD
    Greg
    C5UNION
    FL
    Quote Originally Posted by A62TURBO View Post
    Thanks guys.
    Despite all these codes, the car idles, runs and shifts smooth. I'm not too worried. What bothers me the most is the cats rattling. Does this have pre and post cats? Has anyone ever hollowed theirs out?
    Do you guys know how hard it is to change the coolant temp sensor?
    Thanks again,
    Andy
    Apr 18 2007
    ny
    Quote Originally Posted by S4Andy View Post
    Thanks guys.
    Thanks again,
    Andy
    Trust me, I would be more concerned about the P0741 which means you need a new torque converter, I wouldn't drive the car until a new torque converter is installed because it will lead to needing a new tranny. Worry about this one first and then take care of the rest.
    SOLD
    Greg
    C5UNION
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    x2 to that. I love when the common response it im not worried becasue it drives fine.
    It will drive fine but your clutches inside the TC are not locking up therefore wearing down, therefore releasing metal parts and such into and throughout your transmission.....
    Do you want to fix a TC or TC & Transmission??
    Do research and you will be enlightened.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    Senior Member Two Rings Eyerate's Avatar
    Aug 19 2007
    Did you also replace the Converter pressure valve? Or just need a new TC?
    I'm getting the same code on mine
    thanks
    Established Member Two Rings sideways's Avatar
    Aug 22 2008
    Middletown Ct
    I just replaced the torque converter, flushed out the old slug out of the trany and put new ATF from the audi dealer. Its about 5k miles now without any issues.. it seems like this is a common issue for the a6 click here.
    Your precats are out. you can replace the cats or try the fouler techniques. I tried the spark plug fouler and it was hitting the fire wall. The schmidt wayne angled foulers are the way to go.
    The diode and resistor methods to fool the ecu never works. Another option is to reflash the ecu to ignore the secondary o2 sensors.
    Apr 18 2007
    ny
    Quote Originally Posted by Eyerate View Post
    thanks
    Only the TC got changed as it was the only thing affected.
    SOLD
    Greg
    C5UNION
    Aug 28 2007
    NKY
    P0741...like others have said, you need a new torque converter. I had mine replaced last year, it cost roughly $2000 at my local independent shop. The car will shift just fine, however the transmission isn't catching, if you continue to drive with your current TC you're going to end up ruining your entire transmission.
    Best of luck
    - Jared
    Current: ‘18 Daytona Gray RS3 (Technology Package, Dynamic Package, Black Optics, RS Design Interior)
    Gone: B8 S4 Stage 1 —> C5 A6 2.7T Stage 2+
