Results 1 to 9 of 9
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Wooshing air sound at 5500rpm, when I'm on it
    I am a noob when it comes to the 2.7t
    80k, 2002.
    What can it be?
    Jul 26 2008
    Jersey
    Re: Wooshing air sound at 5500rpm, when I'm on it
    Vag your car and see if you have any codes.
    There's no way anyone is going to be able to diagnose your issue via the net with just the symptom of a "wooshing sound".
    Mar 11 2008
    Pierceton, Indiana
    Already did, no codes.
    I just need to know what a boost leak sounds like, and stuff like that on a turbo motor..
    Apr 18 2007
    ny
    DV's are probably shot.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Jul 26 2008
    Jersey
    usually DV's woosh when you let off and start to sound like a blow off valve, but it is possible!
    Boost leaks sound like all sorts of different stuff - depends on where the leak is.
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    video needed to diagnose
    could be dv's, boost leak, darintake, mbc venting, etc
    B5 S4 AWE Stage 3 - sold
    Apr 18 2007
    ny
    Quote Originally Posted by Rajan147 View Post
    +1 make a video already
    SOLD
    Greg
    C5UNION
    Nov 02 2006
    Alot of junk
    MD
    Definitely a muffler bearing
    But sriously, its very hard to diagnose something when all you're told is the car makes a wooshing sound
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    make or buy a pressure tester and get a spray bottle fill it with the little bit of soap and water, spray it around the DV's and then underneath your fog light trim piece there will be your lower IC hoses do the same to those if you get bubbles somewhere then its a boost leak, check your throttlebody boot too
    '00 Nogaro Blue S4
