Results 1 to 11 of 11
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    interior noise...
    Inside of my 2000 A6 is very noisy.
    Lots of wind noise and maybe tire noise also.
    It's horrible with the roof racks on.
    It is because my car's old...?
    My buddy has 2001 S4, and it's dead quiet compare to mine.
    Is it prob with seals on doors getting old, or liners and pads supposed to soak up noise getting old? No seals are cracking or ripped.
    I read some articles about sound proofing materials.
    Will they really help?
    I have no idea where the sounds are coming in from.
    I feel like it got worse after I got coilovers with stiffer damping.
    Has anyone ever had issue I'm having right now?
    C5, Giac, 2Bennet , UUC, snub, 034, piggies, RS6 SE catback, rear S4 BBK, RNS-E, JHM, darintakes, K&N, forge, samco, rs6 reps, OZ Ultraleggera, phat box, 4.2 blades, clear corners, LED tails, tinted - SOLD
    Rolling on AR 402, H-sports, Milltek Turboback, O.CT tune, LWFW w/RS4, Stoptech ST-40 332mm fitted in stock 17", hyperboost BPV, Quad-xenon
    Apr 18 2007
    ny
    Re: interior noise...
    Roof rack? That would make noise, check your sun roof seal also.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Apr 01 2008
    Massachusetts
    It's not the seals...they are fine...
    I'm going to try sound proofing materials...fatmat or B-quiet...
    I'll see how they work...
    Apr 18 2007
    ny
    ^^^ Before you add sound proofing material, check to see if all of your windows close tight and that nothing is obstructing them.
    SOLD
    Greg
    C5UNION
    Apr 01 2008
    Massachusetts
    They are all nice and tight...
    Am I the only person having this issue?
    Established Member Two Rings Snowhere's Avatar
    Mar 20 2008
    2001 A6Q Avant, 90 G60 Corrado
    Buena Vista Colorado
    What tires are you running? Many snows can be real noisy. I have I-pikes on the Avant and they are noticeable, but not too noisy. Way quieter then Blizzacks I have run in the past. My rocket box also is noticeable, but once again it is not bad. Racks, tires, seals pretty much cover the culprits. My rado is the only car I have had where the rack lessened the noise of my leaky moonroof seal.
    Apr 01 2008
    Massachusetts
    currently, i'm running yokohama allseason on 16's for the winter which sucks on snow...
    had same issue with summer tires on 18's...
    And without roofrack, it's still pretty bad...
    Veteran Member Four Rings MYDWAGON's Avatar
    Jul 08 2007
    Ohio
    My allroad picks up tire noise more than anyother car I've owned.I went with Michelin Primacy MXV4.Super quite.Can you swap rim/tires with some one for a test
    Apr 01 2008
    Massachusetts
    I'm going back to summers as soon as snow stops...they are some what little better, but not much different.
    I'm gonna try fatmat and see how it works.
    My car will be in shop for clutch, control arms, and brakes...hope that gives enough time to take all the seats and carpet out and put the sound deadening materials here and there.
    Has anyone done this???
    How do you take the panel off the roof???
    btw, good looking Allroad!
    Jul 08 2007
    Ohio
    Quote Originally Posted by mike's machine View Post
    Thanks.I've heard of people using roofing underlayment with great results.It's suppose to be a lot cheaper
    http://www.graceathome.com/pages/roofingprod.htm
    04 4.2 Allroad w/H-Sports-Full Tint-Armorcoat- RS6 Exhaust/Gutted Kitty-Flaps-Michelin Pilot Sport A/S Plus-Thule Box-OEM Trailer Hitch-226k
    Apr 01 2008
    Massachusetts
    Hmm...yea they should be some what similar in material.
    But how do you take the roof panel off???
