Results 1 to 30 of 30
    Veteran Member Four Rings GQ//S4's Avatar
    Jul 25 2007
    Today?
    North of Seattle in trees, WA
    What do I need to make OEM S4 BBS CH wheels fit?
    Besides duct tape, what will I need to get to make these clear the brakes and mount properly?
    Thanks all
    - Michael
    Fact: I'm Awesome
    Former: '92 911 C2, 01.5 S4 Stg 3, 00 S4
    I always dreamed of walking on clouds, so I drive on air
    My logic is infallible. Always.
    Grammar Nazi #1
    "I'm too close for missiles, I'm switching to guns!!!"
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    Re: What do I need to make OEM S4 BBS CH wheels fit?
    i believe just lugs and hub rings...u can call BBS directly and get 20 lugs and 4 hub rings for $40 + shipping.
    Jul 25 2007
    Today?
    I ask because I don't think they will clear the front brakes....
    - Michael
    Fact: I'm Awesome
    Grammar Nazi #1
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    have u test fit them? what is the offset and width of the wheel?
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Nov 11 2006
    Tri-State
    im in the process of actually picking up OEM BBS CH's for my b5 s4 this weekend. The seller assured me that spacers werent needed. But I dont know from experience.
    edit: ^ That's the seller
    Jul 25 2007
    Today?
    Quote Originally Posted by DxC View Post
    I didnt, another B5 s4 did, and they didn't fit over the front brakes.
    As they are the OEM CH's from the 06 S4, I assume I will need spacers, but I'm not sure how much "space" I will need.
    I don't actually know the offset, was hoping someone on here could help me with that as well.
    - Michael
    Fact: I'm Awesome
    Grammar Nazi #1
    Nov 16 2006
    Boston
    hm offset is prop +40something
    dont worryaudixs4x01 - mine definitely fit with no spacers. et35 .... err i think ill double check the specs again
    1999 Black A4 Avant
    Nov 16 2006
    Boston
    nice random pic
    heres a random teaser pic
    1999 Black A4 Avant
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    The OEM wheels are 18x8 with an ET43.
    If they fit over the B7 s4 brakes it shouldnt be a problem on a B5.
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by MOFSTEEL View Post
    except that b5 s4 brakes are bigger.....so they really might not fit....
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by ///M3 TO S4 View Post
    Correct me if im wrong but arent the stock frt B5 s4 rotors 321x30
    The stock frt B7 s4 rotors are 345x30.
    Are the B5's calipers that much larger?
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    no way b5's brakes are bigger than b6/b7's :)
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Apr 18 2007
    ny
    A big rotor doesn't necessarily mean you have a big caliper.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by A62TURBO View Post
    thats ture. but b5's caliper is smaller than b7's
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    For a second there I thought you were Captain Obvious.
    If you read what my post I asked ..
    "Are the B5's calipers that much larger?"
    Thx Eugune... I didnt think they were.
    Apr 18 2007
    ny
    Quote Originally Posted by aaaudiprotein View Post
    It's tough to decifer "bigger", some people mean wider and some people mean thicker.
    SOLD
    Greg
    C5UNION
    Apr 27 2008
    Wittering, england
    Look in the back of the wheels to find the offset, somewhere stamped into the back will be "et..", the number that follows will be the offset. The 19" CHs I had on mine were et50 and I ran 15mm spacers to make them et35, they were close to the brakes and suspension but cleared just fine. So whatever offset they are I'd say to find the spacer width you require you need to minus 35 off the offset number in the back and that will leave you with what size spacer you'll need. So for example if they say they're et40, 40-5=35, so a 5mm spacer should do it. Failing that take some thick cardboard cut into spacer size circles and layer them up with test fittinf to see when theyre thick enough to clear the brakes, then measure the thickness of what you've made and get some spacers in that width. Hope this helps!
    Looking at the centres where the bolt holes are on your CHs they look deeper than mine, so probably already closer to the offset you need.
    Audi S4. Noggy Blue. MRC remap. FK Coilovers. 18" Compomotive MO's. Vredestein Ultracs. Labree downpipes. Vibrant cat-back. Carbon goodies. Cayenne BBK. Hotchkis ARBs. Dietrich RS4 front end. Recaro Pole positions. R8 steering wheel.
    Jul 25 2007
    Today?
    So if OEM is ET43, and B5 S4's require ET35 (Correct?) than I will need an 8mm spacer?
    - Michael
    Fact: I'm Awesome
    Grammar Nazi #1
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: nice random pic
    The wheels below are NOT OEM s4 wheels.
    Apr 18 2007
    ny
    Quote Originally Posted by GQ//s4 View Post
    It all depends on the width of the wheel. An ET35 on an 8" wheel is different than an ET35 on an 8.5" or 9" etc.
    SOLD
    Greg
    C5UNION
    Jul 25 2007
    Today?
    Ok, so what width are oem ch's?
    - Michael
    Fact: I'm Awesome
    Grammar Nazi #1
    Apr 18 2007
    ny
    I have no clue, do some research ya lazy bum.....lol jk
    SOLD
    Greg
    C5UNION
    Jul 25 2007
    Today?
    Thats what this is supposed to be!!!
    - Michael
    Fact: I'm Awesome
    Grammar Nazi #1
    Apr 18 2007
    ny
    ^^^ Maybe someone that knows the OEM width can chime in. Did you try Google?
    SOLD
    Greg
    C5UNION
    Nov 11 2006
    Tri-State
    Re: nice random pic
    No, they aren't OEM S4 wheels, they are Original BBS CH's.
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    FYI, if they say "Motorsport" on them, they are CH's and are forged. 18x8.5, et35
    If they don't, they are oe Audi BBS CO's and are cast. 18x8, et43
    My Ch's don't need spacers. I have been told that CO's do.
    "Obsessed" is a word that the lazy use to describe the committed.
    Apr 27 2008
    Wittering, england
    My 19" CHs were 8" wide and ran them at et35, worked for me. Again on the back of the wheel it'll have the width stamped in it. "..J" So my 8" wheels had 8J stamped in them, Can't say what width yours are without looking or measuring, they made 18s and 19s from 8" wide up to 10".
    Veteran Member Three Rings lsc2g's Avatar
    Jan 07 2006
    S3%2C%20Q8
    Calgary, Alberta, CANADA
    regular CH's are NOT forged lol.. the RE's are forged CH's are cast
    the b7 s4 CH's to my knowledge do NOT fit our cars.. you need spacers.. maybe 5mm up front..
    www.eurodrivers.ca
    Calgary Canada Euro Club
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    first of all.. their not ch's, if anything they would be CO's.
    Secondly, you will need 5 mm spacers on the front, and your fine on the rear, but I would do 5 mm on the rear as well just so its even..
    I did 10mm on mine just to give it a nice stance. No I dont have pics with them on the car just in case you ask. lol
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    You will need spacers and new lugs, but not hubcentric rings.
