Results 1 to 6 of 6
    Established Member Two Rings Talon Load's Avatar
    Jun 23 2008
    '05 M3 Vert, '10 VW TDI Cup, '11 Grand Cherokee
    NC
    Front brakes only?
    Well, it's time. I need to do my brakes. The wear pad sensor hasn't activated yet, but they are due. I'm sure it'll come on now that I said that. With that being said I have a question. The only part of the brakes that really need it are the front brakes. The rears are still good and the pad it still fine as well. How bad is it to just do one set of brakes on these cars? Will it affect the braking any? Never really had to deal with that in VWs.
    Veteran Member Four Rings Slave IV's Avatar
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Re: Front brakes only?
    just replace what you need to...
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    Quote Originally Posted by Slave IV View Post
    I've been through three different sets of pads on the fronts (some of it just switching between track and street use), and still haven't touched the rear pads.
    Just bed the new pads properly and you'll be fine.
    Stg 2 B5 S4
    Established Member Two Rings crosenhahn's Avatar
    Mar 13 2008
    2001 Audi S4
    Colorado Springs
    Just changed my front pads and rotors last week and left the back alone... They wont interfere with eachother by just doing one or the other. Just do what needs to be done. But bed the new pads properly!!!!!
    01 S4 - Stage 2+
    Apr 18 2007
    ny
    I changed my front pads and rotors in Sept. rears will be coming up soon
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Aug 06 2008
    Canadia
    I would do the fronts, but service the rears. change the fluid too.
    the B5 S4 is like the mafia... there is only one way out!
