Results 1 to 11 of 11
    Active Member One Ring samiam's Avatar
    Jun 08 2008
    Golf mk5 2.0tdi 4motion, chipped
    New Zealand
    45 profile snow tyres on allroad
    Here in New Zealand it's nigh on impossible to get 55 profile snow tyres but I can easily (and cheaply) get 225/45x17 for my winter pleasure. I have a spare set of a/r rims to swap over seasonally. A 45 profile tyre is 6.6% smaller than standard. Have any of you experienced living with that much smaller tyre and is it a problem?
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Re: 45 profile snow tyres on allroad
    I run 225/45/17s for winter snows. Wider tire is not your friend in snow. Lower profile is not smart with NJ potholes in winter. 225/45 seems fine for here.
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    what if you move to a wider tire.. same series? Like 245/45?
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    I have had no problems with my snows at 255/40/18.
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    same here, I run Pirelli snowsport 240's 255/40/18. goes through the snow like mad. But I think he's more concerned about the difference in diameter. 45's will work just fine, but expect your speedometer to be fast about 5 mph.
    Apr 01 2008
    2010 Jetta TDI
    There are very separate issues: wider is worse in snow. (1) Even the "optimum" performance width (there's an argument) is not what you want in snow. Somebody may do ok with some wide spec, but narrower will be better than wider in snow. (2) Low profile is problem with poor roads. And (3) aspect ratio (35, 40, 45, etc.) is ratio (%) of sidewall to width. Wide tire with higher aspect = bigger roll diameter and speedo is out of whack.
    Jun 08 2008
    New Zealand
    It is just diameter difference that concerns me and that doesn't sound too much of a problem, from what you guys say. I only drive from home 16km up a mountain to work/ski and back in winter anyway. Too busy to drive anywhere else! Anyway it's summer here now so it's time for another cold beer and a barbeque, or should I go for a swim first....
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    Quote Originally Posted by V8weight View Post
    like he said they will work and the speedo will be off about 5mph or so but all 4 tires need to be the same overall diameter so you dont f up your torsen diff.
    Apr 18 2007
    ny
    Quote Originally Posted by 02alltoad View Post
    You can set your tire size through VagCom so it can compensate.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    May 27 2008
    Arvada, Colorado
    Quote Originally Posted by A62TURBO View Post
    would you would have to code it an a6
    Apr 18 2007
    ny
    SOLD
    Greg
    C5UNION
