Results 1 to 8 of 8
    Registered Member Two Rings b6-sr20det's Avatar
    Dec 27 2007
    Odd fuel pump noise only when realy cold!
    So since this winter when i first start the car the fuel pump makes some pretty weird noises only if its like 18 degrees or colder! The first time it did this i ended up getting a ride to work from my buddy because i thought the fuel pump was going to die! But after work when the temps were in the mid to high 20's it did not do this? It also happed again this morning when it was 16 degrees out .Anybody have any thoughts on this weird problem? im probably changing the filter soon anyway but i hope my pump isnt bad!
    2002 b6 a4 1.8t - daily driver
    1994 240sx convertible - track/drift weapon!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Odd fuel pump noise only when realy cold!
    How many miles are on your car? When was the last time you replaced the fuel filter?
    -Doug
    Dec 27 2007
    I bought the car with 61,000 miles 2 and a half years ago! I now have about 97,000 miles. They said all maintenance stuff was done but the dealer was also super terrible and extremely shady!!! So im guessing its the original. Ill probably replace it this weekend! No biggie but why does it do this when its real cold? and not all when its above 20 degrees
    Dec 27 2007
    Update - just started my car to leave work and no noises at all? its now like 33 degrees out! weird!
    Senior Member Three Rings Kodymfk's Avatar
    Jun 07 2012
    Black B6 A4 416whp e85 5 spd, Black AllRoad Static (tip)
    Lansing Michigan
    I have the same noise. Only when it's really cold like 10 degrees in the a.m. It goes away after it warms up and I shut my car off then turn it back on at a light. It's kinda hard ti pin point the noise where it's coming from though. My guess was fuel pump straining from the cold temps. The first time I heard it I pulled into my shop to warm up. It went away, It still comes from time to time though on really cold mornings. Someone said something about replacing the fuel filter. I'm going to try that this weekend when I change the oil to see if that stops it. Has there been any other solutions for this problem since the last post about it?
    e85, meth, 30psi, 1.8T All the Way Check my build out! http://www.audizine.com/forum/showth...-build-on-methI'm also on the FB Kody K
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    Mine does the same. The sound I hear is the gas passing through the lines in a semi-high pitched tone. I changed my filter with an OEM one last earlier this year, so I know for sure it's not my filter. The sound is either "normal" or our fuel pumps get worked out in the cold.
    Brilliant Red B6 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Grey B6 A4 1.8T quattro
    Brilliant Red B7 A4 2.0T quattro
    May 24 2008
    cornish,me
    My 2004 1.8 started making a high pitched noise as well when then temp was in the low teens as well that appears to be coming from the fuel pump. I guess I won't panic just yet the temps are supposed to recover to the 30's in a couple of days. I know my fuel filter should be replaced anyways the car has 170000 mi on it sure hope its not the fuel pump.
    Established Member Two Rings lucasharrington's Avatar
    Aug 07 2013
    Monmouth County NJ
    Quote Originally Posted by refueler View Post
    Do the filter asap I heard the squeeling while the car would warm up for about three months and never got around to changing the filter so the added stress on the pump caused it to go.
