Results 1 to 13 of 13
    Active Member Two Rings actac95's Avatar
    Feb 26 2008
    '02 Ducati Monster 620
    Kansas City
    Overhauled Secondary Air Pump and...
    I had a strange consequence to my recent DIY overhaul of my SAP. For the last couple of months my CEL light has been coming on every other day or so and I just use my ODBII to keep turning it off until I get it repaired. Codes are for Exhaust gas temperature sensor. So, my SAP recently started doing the jet engine/dentist drill. I found an awesome DIY step by step on here to overhaul it so did that this past weekend. In the process I found a cracked hose (vacuum) somewhere underneath the coolant reservoir. Wasn't a liquid carrying hose and was pretty short, looked specialty, so I did a duct tape job on it. I finished by air pump DIY and voila, no more noise. Also, no more CEL after I had consistently been getting one every other day, sometimes once a day. Now, I'm not sure if it was related to the SAP or the cracked hose I 'patched'. How would those be related to the exhaust gas temp sensor. I'm glad it seems to be fixed, but just thought someone might know why.
    Tom
    Veteran Member Three Rings djez016's Avatar
    Sep 01 2008
    04 toureg /94 sliverado /98 e320
    Delaware
    Re: Overhauled Secondary Air Pump and...
    where did you find the DIY??
    .....GAVE YOUR GIRL 4 RINGS NOW SHE AUDI.....
    http://www.cardomain.com/ride/3083923
    Feb 26 2008
    Kansas City
    My mistake, it was on a different forum that I found the DIY. Audiworld
    Nov 18 2005
    Pair of (. )( .)
    can you post the link?
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Feb 26 2008
    Kansas City
    Apr 18 2007
    ny
    That's a great write up
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Feb 26 2008
    Kansas City
    I agree, I'm somewhat mechanically inclined but had really never been in the engine bay of my 2.7T since I got it last Feb. This write up was a great road map for me and it worked!!! I will say I spent a good hour trying to loosen the 10mm nut that is on the right side down about 6 inches......I think my 10mm wrench was about the same length. :(
    Veteran Member Four Rings A4edwin's Avatar
    Dec 07 2008
    01 a6 4.2 sport, 92vw cabriolet, 03 Tahoe, 03 Ford Explorer sport.
    New York
    ac what noise was it making?
    Veteran Member Three Rings RAUDIS6's Avatar
    Oct 09 2006
    Stage 3 B5 S4, LS460, Mini S Countryman
    Usually 9/10 times it is a hose that throws the CEL and not the secondary air injection pump itself.
    Feb 26 2008
    Kansas City
    The noise the air pump was making was like a high pitched whining sound, like a dentist drill I noticed about two weeks before I overhauled it. But it wasn't constant, would come and go when the SAP came on for the first 90 seconds or so upon startup. From what I researched, it would have gotten worse and eventually seize up.
    I figured my patch job was the solution to the CEL since the light has been on and off for the past 6 mos or so and the SAP noise just started recently.
    Apr 18 2007
    ny
    For what it's worth, I would just replace it with a new one for $200 since you have to remove the intake manifold. If it were something easier to access I would say rebuild it.
    SOLD
    Greg
    C5UNION
    Feb 26 2008
    Kansas City
    Not for $800-$1000 the dealership or anyone else was going to charge! Even if you are doing it yourself it is $400+ for a new pump, not $200. And removing the Y pipe isn't that hard. Definitely worth trying an overhaul to anyone out there having the same problem.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Quote Originally Posted by RAUDIS6 View Post
    QFT
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
