View Poll Results: Which Chip is Better???
Voters
57. You may not vote on this poll
  • APR
    15 26.32%
  • GIAC
    20 35.09%
  • Revo
    2 3.51%
  • Custom Tune
    20 35.09%
Results 1 to 18 of 18
    Apr 18 2007
    ny
    After I throw my new wheels on the next step is chip that bitch. I want to get as much feedback as possible in order to make the right decision on which company to go with. Thanx guys.
    03' A6 2.7t Tip
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Which Chip is Better???
    ohgezus... here we go again
    just to give you some insight as to what you will see for posts;
    "giac = more aggressive, apr=less aggressive, vast is awesome blah blah blah"
    my suggestion; since they all do the same thing on stock turbos go with what you can get cheapest
    *edit* wait.. your sig says you already have apr
    Apr 18 2007
    ny
    Quote Originally Posted by ThirdStrike View Post
    Read my whole sig.
    SOLD
    Greg
    C5UNION
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    OOPS i fail at reading my bad
    Apr 18 2007
    ny
    It's all good.
    SOLD
    Greg
    C5UNION
    Senior Member Three Rings jblinga's Avatar
    Jul 24 2008
    '01.5 S4, '96 Maxima
    Mor_onville U.S.A.
    '01.5 S4 6MT 2+
    '96 Maxima (DD)
    Dec 06 2006
    09 Subaru Outback XT, JD Tractor, EZ Go,
    Middletown, Ohio
    Doritos
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by tschmale View Post
    Doritos
    ROR
    sunchips>doritos all day
    Senior Member Three Rings Iosilver's Avatar
    Sep 20 2007
    2001.5 Slow4
    Winter Park
    I concur ^^^
    EMpTy WaLLeT
    STaGe: ToTaLeD
    Registered Member Two Rings
    Dec 02 2008
    canada
    i have the revo chip stage 2
    very excellent you can tune it with the sps3 ,timing.fuel,boost
    anti theft too
    Apr 18 2007
    ny
    Quote Originally Posted by jblinga View Post
    SOLD
    Greg
    C5UNION
    Senior Member Two Rings joeS407's Avatar
    Dec 20 2007
    2000(B5) S4 Hibiscus red
    naperville
    i did the unitronics stage 1+ its about 340hp and 365 torque, its a learning chip so the more of a jackass you drive the more boost and hp it gives and then stays like that, mine spikes at 20lbs of boost and tapers to 17-18 to redline
    Apr 18 2007
    ny
    I ran the same poll in the C5 section and it is interesting to see how many more people are voting for the custom tune rather than apr or giac.
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Doritos are the weaksauce. I had Doritos once, and pulled timing like you wouldn't believe (even on C16)
    "Obsessed" is a word that the lazy use to describe the committed.
    Sep 11 2007
    00 S4 M6, 03 RS6
    Washington State
    Like someone stated above. APR to be safe, GIAC if you just don't car about those stock turbos, etc. etc. I have an APR Ecu, and liked it. Unitronic is doing a custom tune for my single kit, but VAST is very good also obviously. It is all in what you can get and how much you don't mind spending...
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    ^^^^As far as I've heard the new(er) GIAC programs aren't very hard on the turbos compared to the older files with overboost/spike issues. I've used GIAC-X file over 25k Miles and my k03's are as healthy as they've ever been. Just do some research on the various programs, know what your options are for upgrades in the future and also very importantly is to make sure you go to a good quality shop in your area for the install and who can do any future tuning plans you might have for the car.
    Senior Member Two Rings curlyfrieS4's Avatar
    Nov 19 2008
    S4 Twiny Terbs
    San Diego
    GIAC X fosho
    Sold: 2000 S4 Stage II: 17' BBS RGRs. GIAC X. JHM FMIC. Piggie pipes. 710n's. RS4 clutch & flywheel. BORLA Cat Back. UUC Short Shifter. Stasis Coilovers. Need Brembo brake kit!!!!!!!
    Current: 2001 Audi S4. Stock :)
    Senior Member Three Rings therox182's Avatar
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    I'm going to give my biased opinion with GIAC just because that's the only chip I've experienced personally. So yeah, GIAC.
