Results 1 to 24 of 24
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    What have i done wrong now?
    My car seems to have a big vacuume leak that i cant find. I can hear it but dont see it. It's comming from the spyder hose area and when i take my oil dipstick out it sucks air in. When i put my finger on it it sucks it in. weird huh?
    I tried to take my oil cap off and it took some really good force to take it off, once it came off car idles lil rough and if you put your hand on it that ****** would suck it in.
    What gives? Have i switched some hoses around or what??
    btw. i just got done installing my stage 3 last night and this is the first time car has been started. I also did headgaskets, intake mani gaskets and some other ods in that area. Spyder hose is also new.
    THANKS
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Re: What have i done wrong now?
    I would just take a flash light and start going through every hose in the rear area of the engine(between the engine and the firewall). When we finished jeremys install we had hooked a hose up to the wrong conection causing the engine to rev up about 1,500RPM's every 30 or so seconds. Found the hose and fixed it and it was good. Sorry I cant help you with the exact hose but that was my experience.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Spray soapy water where you hear the leak. It will start to bubble.
    Jan 03 2008
    Iowa
    I'mm make a vid. It's kinda strange.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    It doesn't seem right that you have a vacuum leak and there is significant vacuum in the crankcase. I'm really worried about the headgasket or something. Do you have a boost/vacuum guage? It seems to me that you should never have that kind of vacuum in the dipstick tube.....hmm. keep us posted on this one. good luck. It's almost like the PCV system is not hooked up correctly or something.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Jan 03 2008
    Iowa
    There is alot of vacuum in the crankcase. All the crankcase hoses look ok and you cant really mess up the spyder hoses. WTF? this sucks. I took the car around the block and barely got into boost and car seems to pull nice.
    I wonder if i go and drive it for a lil it might seal it self lol The leak i heard is comming from the purge valve or whatever you call it that connects to the y pipe. It's probably because the vaccum is so strong.
    here is a quick vid i made.
    Apr 18 2007
    ny
    ^^^ I wouldn't drive it like that, get someone who knows what they're doing to check it out.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Jan 03 2008
    Iowa
    I hope it's a simple fix because this sucks and i really dont have time to be pulling this motor again.
    Jan 28 2008
    central ny
    check your pcv valve. this happens on the 2.0t's too when the crankcase breather valve goes bad. you cant take your oil cap off is the number one indication of this. that's where I would start. good luck
    Jan 03 2008
    Iowa
    Quote Originally Posted by GTAnimal View Post
    It's brand new from ECS. What's the chance of it being bad?
    Dec 31 2008
    PA
    the fact that you have vaccum on the crankcase...
    is the PVC hoses and valve OK?
    try pulling & plugging it and see if the vaccum on the crank goes away...
    Jan 03 2008
    Iowa
    Quote Originally Posted by ArthurPE View Post
    PVC hose and valve is all new bought and put on when the motor was out. This is really stupid. Now im wondering if the PCV valve could be bad even though it's new.
    Jan 03 2008
    Iowa
    Anyone have any clue what to look for? Im about to go to the garage and look things over.
    Dec 02 2007
    michigan
    do you still have the original PCV valve? If so try that... I'm stumped without being there and trying to look it over in person.
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    Quote Originally Posted by GetAwayFromMe View Post
    is the valve reversed?
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    i would go with the pvc valve. If its new then double check to make sure everything is hooked up correctly. If not then try another pvc valve and if that doesnt work well then you got me...
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    you definitely have a clogged pcv. the valve isnt the only part in the system.
    Jan 03 2008
    Iowa
    Quote Originally Posted by offroader1006 View Post
    It's brand new and if it's bad that sucks. When i disconnect the hose that connects to the y pipe i can ntell it's sucking up air. Wouldnt that be good?? I have my old one sitting here and i can blow air through it no problem in and out.
    Jan 28 2008
    central ny
    check all your vacuum and breather lines those could be clogged as well not just your pcv. grab a can of brake cleaner and start spraying the vac lines and pcv hoses and if their leaking you'll notice a change in idle. do you have any oil leaks? have you scanned it for codes yet? good luck! haha bosanac?
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    i think its the breather filter valve thing... connected to the y pipe its like a 2 inch diameter circle black thing..
    thats the only reason i would see it sucking vac through the oil dipstick
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Jan 03 2008
    Iowa
    hehe Bosanac all the way.
    Jan 03 2008
    Iowa
    I will go through everything in the morning again. The black thing you talking about is the regulator valve, what's the chance of it being bad since it's brand new?
    I wish you could just replace the valve alone but you have to replece the whole stupid spyder hose. I guess i can cut it off and put my old one in just to see if it helps.
    Jan 03 2008
    Iowa
    Still havent figured out this leak. Today i unhooked the F hose and that ****** is sucking up air like crazy so i know it's comming up from the intake mani. Is there some kind of a regulator someplace? to slow down vacuum.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Cross post this thread on audiworld. There's a good amount of shop owners that frequent that forum a bit more than here and they shoudl be able to answer your question or give you a good idea of whats going on.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
