Guys,
I've had my S4 for almost a year now and about three months ago, I started to get an oil leak. My initial assessment was that the drivers side turbo is leaking, however after some digging while the car was on the lift last night it looks like the leak is coming from somewhere above the turbos. I'm almost positive that it's not the valve cover seals, since they were replaced about a month ago. I've got oil all over the inlet pipes, turbo, and etc. This was all observed while looking up into the engine by from the bottom of the car while on the lift. I thought I found the leak, but the hose that I thought was leaking, was a coolant hose. From the top of the engine bay I wasn't able to really tell where the leak was coming from, due to the plastic covers. I'm going to try and take some of the covers off after work to get a better look.
My question to the forum is if anyone is aware of any oil lines that are in that area? Any reference to diagrams or drawings would be great. I'm not losing tons of oil, but enough to have to carry several quarts and top off every fill up. TIA, it's getting cold and significant other can't stand the smell when the heat is on.
Thanks everyone.
