Results 1 to 9 of 9
    Veteran Member Three Rings Coors's Avatar
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    Throttle body issue?
    If the car is idling and I go to rev it up, depressing the accelerator pretty abruptly, I get a ping just as soon as the R's rev up. There is no hesitation, just a ping. If I ease in to it or tap it normally its completly fine. Just when I tap it very quickly and with some force. I run 93 octane as I have the GIAC program.
    Could the timing be off? Or could this be more of a throttle body issue?
    Or do I just have an engine troll?
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    Re: Throttle body issue?
    So many possibilities, so little time. If you could check it with a VAG tool it would certainly narrow the possibilities.
    Apr 18 2007
    ny
    How many miles does she have?
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    No CEL. If i did, I wouldn't have posted
    Scan= clean bill of health
    70k miles
    Side Bar: Just swapped out spark plugs a few thousand ago. Its not plugs
    Apr 18 2007
    ny
    You might need a TB done
    SOLD
    Greg
    C5UNION
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    Quote Originally Posted by A62TURBO View Post
    done at 65k
    Apr 18 2007
    ny
    Quote Originally Posted by Coors View Post
    done at 65k
    Maybe you can take some video so we can hear it exactly
    SOLD
    Greg
    C5UNION
    Apr 05 2006
    I did not anticipate a CEL from your original post. I was thinking that when you looked at each cylinder you would be able to see mis-fires. When I take mine in for service the mechanic can see mis-fires that I have never noticed.
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    is there a way I can monitor the ignition system or combustion rate of each cylinder, via the vag-com; with hopes of ruling out a misfire?
    honestly, I have my doubts that its missing. the car pulls very hard through all the gears and is smooth as silk when doing so and also smooth when at idle.
    it's not affecting performance it's just bothering the hell out of me. I always need something to worry about with this car. otherwise, I wouldn't be a true enthusiast.
    if you guys know a way to monitor the combustion rate or something similar of the sorts i'm all ears. i'm searching vag com's procedure manual now. I may even contact vag-com, their office is minutes from my house.
