Results 1 to 24 of 24
    Veteran Member Four Rings KareemA4's Avatar
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Forge 004 install
    I'm thinking about getting the Forge 004 BOV and wanted to know how easy was the install?
    Was it long?
    Or should I just take it to my shop?
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: Forge 004 install
    Hardest part of the whole thing is the one time clamps...
    if your prepared for that, then its a piece of cake
    Senior Member Three Rings edwardabodnar's Avatar
    Mar 08 2008
    Miami
    dont do it
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    yeah, i guess the shop will be easier
    btw how long do you think ittl take to install?
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    it took me like a half hour. lifted the front end up, took the belly pan off, ended up using a dremel to cut off those stupid one time clamps since there is like no space to get to the stock dv. But once u get it off, the install is pretty simple.
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    cool
    thanks man, and how did it sound?
    Veteran Member Three Rings dextrek's Avatar
    Aug 26 2008
    B7 S4
    Detroit
    dremel FTW!
    -Ben-
    B7 S4 Dolphine Grey
    B6 A4 USP Moro Blue *Sold*
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Quote Originally Posted by eurogruppe View Post
    x2 - except it took me about an hour or so - even with the dremel I couldn't get one of the clamps - had to use a combination of a dremel and tin snips. The clamps are easy to pop off if you can get a screwdriver under the tab, but one of mine was oriented behind the hose form my angle, so I couldn't pop it.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Quote Originally Posted by KareemA4 View Post
    cool
    i actually replaced it with a Forge 007. its alright, i kinda want a BOV now
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    why'd you replace it?
    Denim Blue FWD
    Power = REVO K04, VMR Test Pipe, Forge 004 BOV, TT225 Injectors and Custom Novitech-Tuning FMIC, Magnaflow Turbo-Back Exhaust, Podi, Zimmerman Rotors, Hawks HPS pads
    WHP??
    Looks = Top and bottom Blackout grills, Yellow fogs, ASA Rims
    Suspension = 02 sport suspension and riding low
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by kwimberly View Post
    Same thing here, mine were oriented in the most ridiculous ways that I couldn't get a screw driver anywhere near where it had to be. Guy at the local shop charged me $30 and it was done in about 5 minutes.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    how did it sound on a tip?
    Denim Blue FWD
    WHP??
    Mar 09 2008
    is full of crap.
    Boston, MA
    I have the 007, not the 004, so I can't really comment. You can still hear mine slightly, so I'm assuming the 004 will be a lot louder.
    -Nick
    Veteran Member Four Rings VAG_4ever's Avatar
    May 27 2008
    IL
    You boys need to learn how to man-handle those one time clamps..
    Com'on if a little girl can rip them off with a screwdriver.. You can!
    Yes I am talking mad shit right now!!! Haha anyway!! I have the splitter- its the hybrid between bov and dv! you should think about that..
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Quote Originally Posted by A4_ever View Post
    Thats awesome.......shes getting on ure case guys
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    seriously if you plan on modding this car get used to taking a screw driver to those 1 time clamps. After a couple you'll be able to do it in 5 seconds max
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    May 03 2008
    Orlando
    I guess if I had little girly hands I could have reached around behind the hose to snap the tab. But, since I don't have magic Princess Power I just had to "man-handle" them as you appropriately call it...
    Kevin W.
    May 27 2008
    IL
    haha finally someone stands up.. touche
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    If anyone needs a 007 or a 004 let me know!
    And install is plug and play after you get that clamp off.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    yeah, plug and play for Forge 004, had it for 6 months before switched back to 007
    Established Member Two Rings da1nonlymikeo's Avatar
    Feb 02 2009
    mn
    Quote Originally Posted by aaaudiprotein View Post
    why did you switch back to the 007?
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by da1nonlymikeo View Post
    i got a vacuum leak, but before i found out about that i thought that my 004 was causing some problems. It was fine though.
    i think i got one in a trunk, let me know if u ar interested.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    those one time clamps were a bitch!
    lovin my splitter though
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Get your knuckles dirty and scratched up and do it yourself! Pair of pliers and twist those puppies off. Takes 30 minutes and you'll appreciate it a lot more when you do it yourself. Hybrid DV/BOV is next for me. Love my 007 BUT i would occasionally like some sound!
