Results 1 to 16 of 16
Thread: Battery Cover
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Battery Cover
    Part number and price would be helpful. I decided to not put mine back on after jumping my girlfriend's car, and well lets just say, it's broken...
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Battery Cover
    Quote Originally Posted by sambrody44 View Post
    http://www.ecstuning.com/stage/edpd/...ro&engine=1.8T
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Re: Battery Cover
    isn't it bad for the ECU to be boosting other peoples' cars?
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Jan 24 2007
    Re: Battery Cover
    Quote Originally Posted by mattman View Post
    i think you got it mixed up. I think what he meant was he was jumping his gf's car due to her battery died. What is jumping battery will effect ECU??
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Re: Battery Cover
    I remember reading something in the manual about not jumping cars. I jumped somebodies car once and noticed significant power loss after, but it fixed itself
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Battery Cover
    He means....that if u jump another audi.........it can damage the ECU
    Oct 23 2007
    Ontario, Canada
    Re: Battery Cover
    I dunno i just thought I herd you cannot jump or be jumped because of the way its grounded or something like that.
    Meet Shanice...
    For Sale:
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Battery Cover
    Quote Originally Posted by Molotov View Post
    I just jumped someone last week, and I noticed my MPG went crazy high - the ECU said I was getting 30MPG in the city. The next day everything was back to normal. I might not jump anyone else. I kind of had to do this one though - it was the senior partner at my firm, and he was too cheap to call roadside assistance to the parking garage.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Deactivated Four Rings
    Sep 30 2008
    n/a
    Re: Battery Cover
    Yea Sam mine is broken too and my battery needs to be replaced tomorrow. Is it ok to run the car with out that whole cowl area. I've seen a couple cars without it but I don't know if it's ok I might take mine off tomorrow.
    Established Member Two Rings Plasticar's Avatar
    Jul 08 2008
    B6 A4Avant, B5.5 Passat 4mot
    West Bloomfield, MI
    Re: Battery Cover
    The 2005 models came without the battery cover from the factory. To me, it looks weird, but apparently is OK. The engine compartment has weather sealing, so it keeps pretty dry. Most other cars don't have covers over the battery.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Battery Cover
    yea so if u have an Audi....Do not jump other people or dont get jumped EVER...it can ruin ure whole ECU
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: Battery Cover
    Where are you getting this from?
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Jan 24 2007
    Re: Battery Cover
    Quote Originally Posted by illaudiill View Post
    yeah where are you getting this information???
    Sep 30 2008
    n/a
    Re: Battery Cover
    Hey Sam. I just replaced my battery today and removed that whole plastic cowl over the battery and cabin filter and I think the master cylinder. I think it looks a lot better.
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: Battery Cover
    Hmm...
    I might look into that... My cowling got cracked when I did my coil over install and forgot to put it back on then preceded to step on it...
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    May 03 2008
    Orlando
    Re: Battery Cover
    I would like to remove the cowl, but my passenger wiper arm is apparently welded on. I can only remove the driver's side - to get to the ECU requires flexible shafts, steady hands, skinny wrists, and luck.
    Kevin W.
