Originally Posted by
AudiA4Turbo22
And Lee i'm glad u figured it out please tell me what u did as i'd like to know myself and enlighten myself on LED knowledge.
I'm just trying to make it so it doesn't look like CF stick-on tape or something.
As for the LED's, they're wired parallel, which means that they all get +/- from the leads that were the DRL on E-Codes. The other option, which wouldn't work in this instance (because there are too many LED in each housing and the first in the series would be brighter than the last) is in "series". Which means each LED's "+" gets connected to the next LED's "-" . In parallel, I'm using a small fuse-block type thing so each LED get's it's own 12v supply from the DRL wires instead of trying to splice 13 LED "+" wires in to one "+" wire for the DRL.
Each LED in my case has it's own resistor. The LED flexible "strips" have a resistor every three LED's. So on those cheap "strips", you can only cut the strip after every third LED and if one burns out, the other two won't work, either. On mine, each LED is replacable and don't affect each other when one burns.
As for the relay it's a single-pole, double-throw standard coil relay with a quashing diode built in to keep any voltage spikes from occuring when switching. $5 each on eBay and small enough to fit inside of headlight housing.
The main +/- for the coil relay are coming from the headlights. The only function of them, however, is to switch the coil between normally open and normally closed. They do not supply power to the LED. The other "in" + terminal comes from the + of the DRL.
There are two + "outs" (double throw), and each gets it's power from the + in of the DRL. The coil switches between the two depending on whether the headlights are on or off. When the headlights are off, it runs straight through the single + in from the DRL and right out to the LED's, which makes them be on at full bright. When the headlight turns on, it switches the coil and then runs the second + out, which in turn runs through one single resistor (.99 cents at Radio Shack) before heading to the the same + on the small fuse block. The single resistor cuts voltage as a whole to all of the LED's, which in turn dims them.
My only concern is heat from this single resistor when the headlights are on. So far, it has only gotten warm. I may set it up on the outside of the housing so it will stay cooler. We'll see.
Here is a very crude diagram showing how the relay and resistor are set up for LED dimming.
*I forgot to draw in the "ground" wire to the LED's on the bottom of the pic on the right. And also, remember this single resistor is only for dimming purposes. Each LED has it's own resistor down the line to keep 12v from burning them out, as an LED only uses like 3.5v to work.
I'm trying to take as many pictures as I can. It's hard though to think of taking a pic when I'm doing twenty project at the same time, from designing, wiring, CF overlaying, and, oh yeah, pulling my block for the build.
I hope to have a DIY at some point, but trust me, this ain't no project that anyone should expect to have done in a few weekends.
