Results 1 to 28 of 28
    Nov 10 2008
    San Diego
    10W30 engine oil??
    I went to jiffylube and they told me that since my car has over 100k on it, it'll be better for the engine if I put thicker engine oil so they put in 10W30 instead of 5W30. Is this true??
    But I saw somewhere that 10W30 is not good for very low temperature. I'll be going to Toronto where it easily gets down to -20 degrees Celsius. Will this be ok? or should i change it to 5W30 again...
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    Re: 10W30 engine oil??
    0-40 Is What I Have In Mine...
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    i use 5w40 and live abouts an hour away from toronto. i havent used any other type of oil since i took ownership of the car.
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Veteran Member Three Rings rbj325's Avatar
    Aug 12 2008
    Rochester, NY
    Quote Originally Posted by audirs View Post
    ^^same here in Rochester, NY with 120k miles....
    Most people run 0w40 so 5w40 is a thicker oil for high mileage.
    Apr 18 2007
    ny
    If you're driving a turbo car, only use 5w30 because 10w30 is too thick at startup which starves the turbos and 0w40 is too thin at normal temp which is killer on the turbos bearings.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    0w40 for me
    2004 Audi A6 2.7T
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Quote Originally Posted by jceezy View Post
    I went to jiffylube
    Never go to Jiffy Lube. Pretty much everyone there doesn't care at all about your car. I've heard a LOT of negative experiences from them. As another user said 10W30 may be too thick for startup. Personally, I have Mobil 1 5W30 running in my engine right now.
    Apr 18 2007
    ny
    Quote Originally Posted by FrankA6 View Post
    0w40 for me
    I would stay away from 0w40, bro my rear main seal started to leak after I used that. Thank god for CPO, obviously I didn't tell them I used that oil, but if I were you I would stick to 5w30.
    SOLD
    Greg
    C5UNION
    Oct 16 2007
    Brooklyn NY
    Quote Originally Posted by Stone825 View Post
    i was going to post that as well.. i hate jiffy Lube or any type of oil change place...
    buy a 30 dollar jack stand kit and do oil yourself...
    well there is one brand of oil i heard is pretty good as well.. call Lubro Moly, and it's all 5-40..
    http://www.worldimpex.com/parts/lubr...-1l_68562.html
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    0w40 is an audi recommended oil... and why would a different oil grade cause your rear main seal to leak?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    1st thing, dont listen to Jiffy Lube.. 2nd thing, dont listen to Jiffy Lube.
    I use 040 and 100k. Good stuff in summer and winter.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    BTW, are you even using synthetic?? I hope so.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    0-40! synthetic! go change your oil and don't take advice from jiffy lube ever again oer we'll contact the authorities, maybe even take your car away from you!
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    What motor does he have? a 2.8/3.0/4.2 doesn't really need synthetic
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Registered Member Two Rings banditoamigo's Avatar
    Nov 02 2004
    2002 allroad MT6
    Minneapolis
    Quote Originally Posted by A62TURBO View Post
    You probably would have been okay telling them that you had used the oil the manual tells you to use.
    2002 allroad MT6
    Black/Tan, 3rd row seat
    Stage 3 - EPL tuned
    Apr 01 2008
    2010 Jetta TDI
    Oil didn't cause you to have a bad seal. There is a reason mechanics and manufacturer say 0-40.
    Aug 27 2008
    lincoln nebraska
    i used to use 0w40 mobil, but after reading about there change of oil grades i use 0w40 royal purple.
    Oct 16 2007
    Brooklyn NY
    Quote Originally Posted by kelvinb View Post
    you got facts to back that up?? it would help a lot.. i just bought two case of that stuff from autozone.....
    might change to royal Purple if it's true....
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    ko3's dont have bearings and 0w40 is not too thin at opperating temp its thicker than 5w30. Oil weight, or viscosity, refers to how thick or thin the oil is. The temperature requirements set for oil by the Society of Automotive Engineers (SAE) is 0 degrees F (low) and 210 degrees F (high).
    Oils meeting the SAE's low temperature requirements have a "W" after the viscosity rating (example: 10W), and oils that meet the high ratings have no letter (example SAE 30). An oil is rated for viscosity by heating it to a specified temperature, and then allowing it to flow out of a specifically sized hole. Its viscosity rating is determined by the length of time it takes to flow out of the hole. If it flows quickly, it gets a low rating. If it flows slowly, it gets a high rating.
    Hope this helps. i also found this,
    Mobil 1 0W-40 meets key industry and car builder specifications for:
    Mercedes MB 229.5
    BMW Longlife 01
    Porsche Approval List 2002
    VW 502.00/505.00/503.01
    GM-LL-A-025 (gasoline)
    GM-LL-B-025 (diesel)
    ACEA A3, B3/B4
    API SM/CF
    Mobil 1 0W-40 provides the widest range of protection -- providing the extreme cold start protection of an 0W grade and the high temperature protection of an SAE 40 grade.
    oh btw i use 0w40 in all 3 of my audis.
    May 27 2008
    Arvada, Colorado
    check this out http://www.mobiloil.com/USA-English/...px?videoID=006 watch the vid and tell me that a 2.8/3.0/4.2 wouldnt benifit with syn oil
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    If you are talking strictly from a cold stand point, then yes you are right. So yeah if he is going to toronto, I guess he would need it. If he has a 2.7t, he should be running it no matter what. I say it more from the standpoint that I have seen cars with over 100k develop oil leaks when they make the switch to synthetic at that mileage.
    Synthetic definitely is a better oil and has its benefits. Usually in my experience, its better to have had the car on it for most of its life.
    Village Idiot!!!
    (\__/)
    (")_(")
    May 27 2008
    Arvada, Colorado
    Quote Originally Posted by Stampy View Post
    i agree 100%
    Apr 18 2007
    ny
    Quote Originally Posted by 02alltoad View Post
    Mercedes MB 229.5
    BMW Longlife 01
    ACEA A3, B3/B4
    API SM/CF
    You sure about that?
    SOLD
    Greg
    C5UNION
    May 27 2008
    Arvada, Colorado
    yes they have a brass bushing i can post a few picks of turbos that i have taken apart it you want to see?
    Apr 18 2007
    ny
    lol It's not called a bushing, it's called a bearing. You probably think I'm talking about ball bearings.
    SOLD
    Greg
    C5UNION
    May 27 2008
    Arvada, Colorado
    Bushings are a sleeve, usually made or a soft, semiporous material like bronze or brass. They are semiporous to hold lubricant. Bearings come in different varieties and are usually made of a hard material, like stainless steel or iron. A bearing has 3 main parts, the race (inner piece) the rollers (ball bearings/needles) and the carrier (outer piece) which contains the rollers. They usually are designed with space in them to hold a lubricant, such as grease. There are also flat bearings, made of a softer metal for use in engines for main and cam bearings. These are lubricated by the engine oil via the oil pump.
    May 27 2008
    Arvada, Colorado
    Ok your correct im sorry, it can be refered as either, but the correct term is a bearing.
    Kit, Service KO3
    Turbo Intl Part Number: 7-D-2557
    Login and See Prices
    Component Name Quantity per Set Key Number
    Washer, water port, copper - 8-D-2555 1
    Journal bearing,dual oil feed - 1 1
    Retaining ring/circlip - 8-D-0919 1 2
    Piston ring, t/end - 1 3
    Locking clip, jnl/brg. - 8-D-1963 1 4
    Retaining ring, circlip, t/brg. - 8-D-2417 1 5
    Flinger sleeve,0.181 - 8-D-2283 1 6
    Thrust bearing - 8-D-1961 1 7
    Oil deflector - 8-D-2472 1 8
    Thrust collar,0.181"/4.60mm bore - 8-D-2285 1 9
    Piston ring, c/end - 8-D-1782 1 10
    O ring, brg/hsg. - 8-D-1818 1 11
    Locknut,M4.5x0.5-6H LH - 8-D-2288 1 12
    Bolt,c/e,hex.head M6x1.0-6Hx12mm - 8-D-0917 4 13
    Washer, hose, aluminum - 8-D-2556 2 14
    Bolt,t/e,hex.head M6x1.0-6Hx10mm - 8-D-0918 4 15
    Locknut, hex head M6x1.0 - 8-D-1319 2 16
    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    0w40 synthetic for me
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
