Results 1 to 7 of 7
Thread: Low boost
    Nov 17 2007
    Low boost
    I've been having a boost problem ever since the car has been chipped, it will only spike and hold ~8-10 psi. I finally thought I had it figured out when I unplugged the MAF, it was boosting ~20-21 psi. Before the maf I scanned the car w/ vag-com several times (no codes), changed DV, did the boost leak test and everything seemed fine, and then I got a new MAF. With the new MAF plugged in again the boost issue is back. I have no idea what else to check for, no codes, no leaks, just unplugging the MAF makes the car boost right and as soon as I plug it back in the boost is low again. Any help is appreciated.
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    Re: Low boost
    what brand did you go with?
    Nov 17 2007
    Re: Low boost
    Speedtuning
    Veteran Member Four Rings lawnferie's Avatar
    Jul 09 2008
    86 bmw r80 airhead. bmw k1200rs
    Mish/South Bend, IN
    Re: Low boost
    what gear boosts 10psi? i think 4th and 5th get into 15psi range...
    Was uns nicht umbringt, macht uns stärker
    lots of goodies
    B5 noggy s4
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Re: Low boost
    i thought the SpeedTuning Stg2 was suppose to peak at 21psi in 5th
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Aug 09 2007
    Mount Airy, MD
    Re: Low boost
    it does, it sounds like your in limp mode. maybe its not the maf itself, could the wires to the maf be messed up, somehow triggering bad readings
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Jul 09 2008
    Mish/South Bend, IN
    Re: Low boost
    lol didnt know stg2...
    lots of goodies
    B5 noggy s4
