I couldn't edit my old thread, and alot changed, so I'll just start a new one...
Car started as an 04.5 USP with Symph II & Bose.
First thing was a retro-fit to RNS-E & I used the OEM sharkfin antenna:
I used the low-level outputs of the RNS-E to a custom rca pigtail to an AudioControl overdrive mounted behind the glove box. I also mounted one of the xovers for the a/d/s 344is components back there too:
Up front, I'm running an a/d/s 344is component set in the kick panels, and a/d/s 346is midbass drivers in the doors. The kicks aren't done yet, as I still need to fad/mold them into the plastic rocker panel covers:
In the trunk, I have (3) 0.5 farad caps in the passenger side lower trunk area:
On the driver's side, I fab'd a fiberglass box to hold a single 12" Image Dynamics IDQ12 covered in grille cloth and I removed the door on that side:
Also behind the driver's side panel is the AudioControl DQT and the Sirius satellite receiver. I have the AudioControl DDC as well, but haven't decided where to mount it yet...
Now for the amp, I mounted it on the rear deck, and re-molded the rear shelf cover to contour flush with the amp. I was a little worried about heat dissipation at first, but haven't had any problems during 5hr 110 deg trips. The tint helps quite a bit too. Plans are in place to add a fan for thermal stability. The amp is a Precision Power Pro6800:
A few more pics of the build-up are in my profile. If you have any questions, or want to see more pics of the build-up, just ask. If you're in Orange cty and want to see/hear, be my guest.
