Results 1 to 33 of 33
    Active Member Two Rings 01Audi1.8T's Avatar
    Apr 08 2008
    2011 Toyota RAV4 Sport
    New Freedom, PA
    Wheel won't come off
    I'm trying to put my winter wheels on but I can't get the others off. I've got all 5 lug nuts off but when I grab the wheel and pull, nothing. I've hit the back side with a hammer and tried tapping on the axle nut with the hammer to break it loose. Has anyone had this happen that can help? I've never come across this problem on any car I've ever owned.
    Sep 16 2008
    Tools
    Rochester, NY
    Re: Wheel won't come off
    happens all the time. next time coat your hubs with anti-seize.
    I recommend putting 3 lug nuts back on loose and dropping it off the jack. if that fails drive it 20 feet or so with them loose and it should separate from the hub.
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    pb blast the area. just don't get it on the brakes.
    Sep 02 2008
    98.5 2.8 A4 QM
    i would honestly not drive on a loosely screwed on wheel... that'll fuk up the bolts, wheels, and the hub...
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    donkey kick that bitch
    Apr 08 2008
    New Freedom, PA
    Quote Originally Posted by offroader1006 View Post
    Gave that a try too but nothing. I've got some PB blaster soaking right now. I hope that works. I'll try dropping the jack next and see what happens.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    keep hitting it all around and the vibration will eventually break it loose. put anti-seize on the hub lip so it doesnt happen again
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by 01Audi1.8T View Post
    PB blaster should work and try to hit it with a rubber malet from the back side of the rim. Be careful, duh...
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Senior Member Three Rings jlien08's Avatar
    Jun 28 2007
    98.5 A4 1.8TQT, 01 ZR2 Blazer
    Woodbury, MN
    release your e-brake
    Just kidding. I had this happen once too, it's a bitch. I let mine sit overnight, soaked in WD40.
    1998.5 Audi A4 1.8T Quattro Tiptronic - MagnaFlow - Bilstein - Neuspeed - EvoMS - 034MS - LLTek - FMIC - VDO -
    Oct 17 2004
    Columbia, SC
    i really just donley kick them.
    it takes a bit of practice to get it right.
    never had one i couldnt get off.
    that or a 32 oz ball pein to the inside sidewall
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    wd-40 or pb, then hit the crap out of them on the back side with hammer.
    If all else fails, try c-4, that should also work..... j/k
    Apr 08 2008
    New Freedom, PA
    No such luck with the PB blaster either. I might need a damn come along to get them off. What a horrible design. Audi could have made the center bore on the wheel a hundredth bigger.
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    When was the last time u changed brakes or ur tires? God damn bro. Must a been a while. You try lowering the car quick off the jack?
    Apr 08 2008
    New Freedom, PA
    Brakes were done back in May. I haven't had the wheels off since then. Try the lowering off the jack and nothing. I don't get it.
    Sep 02 2008
    98.5 2.8 A4 QM
    would it work if you screwed one of the lugs back on tight? that would skew the wheel and hopefully break the rust/whatever is holding it on. if that doesnt work - drop kick it. It might not help but at least you'll show the car who is boss.
    Apr 22 2007
    Riverbank, Ca
    unscrew the lug nuts 1 full turn, go around the block slowly, No good still? Try going up curbs relatively quick, this should provide the shock needed.
    Dec 12 2006
    Charlotte,NC
    i usally have this problem at work. My goodness some of them dont want to come off... We have lifts so i get under the car and kick the crap on the back side of the wheel... I need to buy a huge plastic deadblow hammer next time.
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    what I did is use a plastic hammer that is used for hardwood nailers (im in flooring). they are soft enough not to hurt the rim, but heavy and firm enough to deliver a good blow. they are like ~$30 at home depot. and come in handy for many other things tooo
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Why not remove all of the bolts, and slowly let the car down so the wheel moves like an inch or less. Stop and lift it back up
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Whats worked for me is kicking on opposite sides of the wheel repeatedly. Do a few kicks going left side to ride side. Then do the same put top to bottom. And by kick I mean put all your weight into it.
    DG '02 A4 1.8TQM
    My Build Thread
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    just had this happen to a friends B6... he got on one side of the wheel, me on the other. he would pull on one side, i'd then pull on the other. the repetitive pressure from each side finally broke the corrosion enough where it was wobbling. then a few kicks and it was off.
    when the wheels do come off, clean the hubs up with a stiff wire brush and then antiseize it. shouldn't happen often if you keep those hubs clean
    good luck
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    I've used a heavy rubber hammer/mallet and a 2x4
    only use very little anti-sieze but enough to make it work. you dont want it slinging around and getting on the rotors when its hot.
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    kick it on both sides, alternating, and kick it like a MAN!!!!!!
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    TRY HITTING IT WITH YOUR PURSE!!!!! hehe. j/k thats my fav joke at work when some1 cant get a wheel off. Pretty much, just as everyone else said, get a deadblow sledge and hit the back of the wheel. what works best for me is to spin the wheel as you hit it. if you cant spin then go side to side or all around. just make sure its a dead blow, and that you are hitting the back side of the wheel. some people say hit the tire, but ive seen people cause bubbles in the sidewall for this (using ball-peen). and a deadblow isnt going to damage a wheel or at least not much. my buddy at work has a 5 or 6 pound rubber sledge with a 4 foot handle. he calls it thor. ive never needed to use it, but im sure it works. he used to work in ohio, and he said even the worst wheels he's seen only took 1 swing from thor to come off.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Oct 17 2004
    Columbia, SC
    Quote Originally Posted by B5A4Kevin View Post
    i need that
    Senior Member Two Rings gsverz's Avatar
    Oct 05 2007
    North Jersey
    grab a 2 by 4...
    Sep 02 2008
    98.5 2.8 A4 QM
    u get it off yet? be careful with the 2 X 4. If you have the ground as your support, you might tip the jack over... watched a guy at autozone (one of those "freelance mechanics" do it to somebody's car).
    Senior Member Two Rings stubbs's Avatar
    Jul 29 2008
    Utah
    I had the same thing doing a brake job a while back. One came off with a good kick, but the other refused until I put all 5 lugs back in, but not quite tight, then drove a few feet and tapped the brakes at 5 mph. That was enough to break it loose.
    Dec 19 2007
    1988 Mercedes 300E, 2008 Triumph Speed Triple
    Colonie NY
    Yup, agree with all advice here. Dont know if heating it up might help. Rubber mallet side to side or top to bottom should do it.
    I used a Dremel tool to grind the rust off the hub and put anti-seize on there. Be sure to clean the rim itself too, where it meets the hub.
    Apr 08 2008
    New Freedom, PA
    Well, I went over to the in-laws this evening and we got them off. My father-in-law has a giant rubber mallet (heavier than my sissy claw hammer) that we used and they came off. He's got an air tool with a wire brush so we cleaned up my hubs and put anti-seize on them. I shouldn't have any problems but we'll see for sure when spring rolls around.
    Aug 02 2015
    San Jose
    I just had the SAME thing happen on my 2009 S5. And I'm in California, so no rust. Was so frustrating. I tried the mallet, donkey kick, etc. I gave up and ended up only being able to do my front brakes. Back will have to wait I guess. So lame. And So frustrating!! Also couldn't get the rotor off on the front so didn't change the rotors. Tried heat, air hammer, etc. WTF!!?
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Quote Originally Posted by Kemnik View Post
    put the lugs in, back them off a turn, drive around the block. Or hit it with some wood like a battering ram.
    also this is not how you use forums. You bumped a post from back in 2008. a full year before your car was born.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Grave digging much?
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
