Originally Posted by
njm23
its effective for one of the 2 CEL you will get. I don't think you can COMPLETELY solve it with resistors just 1/2, unless i'm wrong.. And you will still fail readiness
Yea.....you would, if you just plugged the resistor in.....I had to plug a couple hoses and route two sensors under the intake manifold to themselves (can't remember the names of each sensor, but they are part of the PCV system). And after a while, you would still pass readiness.
However, if u plan on doing this urself, def do more research, since my current knowledge about this isn't as fresh as it was when I was doing this mod early this year. So I'm prob leaving some things out......but I do believe it is do-able without getting a re-flash
