Results 1 to 40 of 51
    Veteran Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    Pictures of my 149.9db system! and opinion pic. LOTS OF PICS
    Here are some pictures of my system that recently hit 149.9 decibels in a pre-fab box! I will be building a custom dual ported bod for it soon. Well here they are! The speakers mounted in the rear dash are two memphis 6x9's. I had to custom fab them by using a nibbler to cut holes in the thick rear dash frame. It took about a day to do. If you would like this and are in the houston area, send me a private message. I wired/installed everything myself. Check my sig for my setup.
    My sig is also suppost to say 1000.1, i hit the wrong key. I have the Kicker CVX's wired down to 1 ohm, and at 1 ohm the amp pushes 1000 watts RMS!!! The CVX's are the same as the L7's just circle. 750 watts RMS for each sub.
    Now here are some pics that I need an opinion on. It took me about 5 minutes to wire with a switch and everything!
    Looks pretty cool in day light too.
    What do you think, go or no go?
    They are HID's, pic just makes them look yellow.
    Tell me what you think!
    -Cameron
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: Pictures of my 149.9db system! and opinion pic. LOTS OF PICS
    ricer alert!!!!
    i say bass is lame. boost is an adrenaline rush!
    but to each his own
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by sean1.8t View Post
    ricer alert!!!!
    but to each his own
    Buuuuuuut when you have both, you prevail!
    Stage 2+
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    oh dear.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    You're SO gonna get pulled over with those LEDS, but hey you look like a COP.. +1
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by kwimberly View Post
    oh dear.
    So I'm guessing that's a no go on the lights huh?
    Haha I thought yall probably wouldnt like them.
    I'm probably going to take it off in the next day or so.
    -1 for me!
    Stage 2+
    Nov 05 2008
    MO
    The grille looks like its strait off the border. Door lights are sick. The subs can't sound clean. Nobody thinks ratteling plastic is ballin.
    Sep 28 2008
    Boston, MA
    quickie, did you just drill right into the back of the seat, my amp is just chillin in my trunk haha, i'm afraid to drill it in. ALso, how do I secure a 12" single box.. it's always moving around back there.
    Current: ISO RS4
    Oct 27 2008
    Montgomery TX
    I've fixed almost all the rattles in my car, took about a day and a half. I used different things ranging from patches of Dynamat to weather stripping to foam. I think the only rattle left is coming from the rear bumper, and it is not very loud.
    Stage 2+
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by Charlescrs6 View Post
    Drilled right into the seat. It's pretty thick durable wood on the back of the seat, and as long as you dont have 1 foot long screws, you will be fine.
    To secure the box I would get some L brackets from your hardware store and bold it to the side of your trunk.
    The box with the subs is 100+ lbs. so I don't need to have it bolted, it's not moving anywhere. And I have about a 1" gap inbetween the side wall of the trunk and my box.
    Stage 2+
    Sep 28 2008
    Boston, MA
    Quote Originally Posted by ConroeA4 View Post
    that's what I was thinking but I didn't want to screw into the box cause it would leak air or w.e since it's a secure box or whatever its called haha
    Current: ISO RS4
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    I have never been into loud sound systems. They are pointless and I think they sound like shit when people drive by me and all I hear is rumbling. Your system looks like you put a lot of time and money into it though and if that's what you like then .
    Oct 27 2008
    Montgomery TX
    As long as you keep the screws in there it wont let air out, and if you do decide to take the box out for some reason, you can fill the holes with epoxy and it will be good as new. I wouldnt do that for high powered systems though.
    Oh and its "sealed" haha
    Stage 2+
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by 4Rings3Liters View Post
    I think it's more for the younger crowd, not implying that you might be old. I will be bringing her to sound competitions too. It's just a hobby that once you get started, you can't stop. I've had this car for 6 months now and have had over 4 different systems in it.
    Stage 2+
    Sep 28 2008
    Boston, MA
    THAT'S the one haha that's gonna be my weekend project, along with trying to get my ashtray back in, DON'T EVER TAKE THAT OUT it doesn't go back in without removing radio, climate controls ah
    Current: ISO RS4
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    You either have a whiskey jerk or ADD... Photo skills are amazing!
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by 3.0L AUDI A4 View Post
    Sorry. haha.
    Holding flashlight and iPhone trying to press the picture button on the phone all at the same time. I will get better pics in the day light.
    Stage 2+
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    jesus..........................
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Sep 02 2005
    Montreal
    Dude, ALL the photos are blured, use a tripod or use the flash
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    That's a lot of bass my friend..I dig it though..ha..I think i'm going to get a w7 and keep it clean in the trunk..nice none the less
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    not what I would spend the money on, but a hobby is a hobby :) Looks like you're proud of what you have done and thats what really matters, good work, keep modding!
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    I wish I could see the grill LEDS in person just to see what they look like. I still say no go on them though.
    Nov 05 2008
    MO
    I approve.
    Oct 27 2008
    Montgomery TX
    Haha thanks everyone. Sorry about the blurry pics. I willg et better tomorrow in the during the day.
    Also the subs match my car perfectly!
    Stage 2+
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    keep the lights on the bottom of the doors, the look cool and unique
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    149.9??
    What equipment did you use to measure?
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by A4 Moda View Post
    149.9??
    I'm not sure what it was but I drove to the local audio shop (nice shop)
    and had it tested for $5. Device was placed at dash and on the computer the highest measurement it took was 149.9 db's. They said it was impressive especially for it being in a pre-fab box.
    Stage 2+
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Wow!!!!
    Jun 11 2005
    You can never tell with this guy.
    Did you bring the tire iron over to help him change a tire, or shove it up his ass?
    Quote Originally Posted by 400HPA4 View Post
    Wow!!!!
    2003 1.8T
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Take it however you want...his post speaks for itself, no need for me to interject.
    Jun 11 2005
    amen
    2003 1.8T
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I'd be interested to see how it would compare so the other cars I've been in that hit the ~150 mark. NTM I'd question their equipment. Not that it can't be done, but it's hard to do on 2 12's.
    The journey from 150 to 160 is hard, good luck. 160db makes it hard to breathe.
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Nice man. I'm into car audio as well(setup is in my sig). I was actually trying to find a place to get mine measured as well and I have no idea why I didn't think of going to an audio shop... As far as prefabbed boxes go, I have a sealed one I got from bestbuy(some crazy sale for only $30 for dual 12" sealed) and it is holding up suprisingly well.
    I have heard though to stay away from 6x9's. I forget where I had read this but it had something to do about the shape of the speaker and it distorting easier. If they dont have much bass going to them then I guess theres no need to worry about that but just something to think about in the future, because if there is one thing I have realized: It's never loud enough. I'm always trying to find a way to make it louder without compromising clarity.
    DG '02 A4 1.8TQM
    My Build Thread
    Oct 27 2008
    Montgomery TX
    amen
    I'm sorry I'm not following yalls last couple post. What are y'all talking about?
    Stage 2+
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by djwimbo View Post
    tub place I took it to is a legit place.
    Lakeside audio
    I think they have a website.
    It's not just a bunch of mexicans in a shop luke your traditional audio shop. (no offense to anyone)
    Stage 2+
    Veteran Member Three Rings SKIDMRK's Avatar
    Sep 14 2006
    Monroe, WA
    Then why type it?
    However, props for learning to do things yourself. I started with car audio when i was 13 and have been tinkering with it for over 18 years now. We all started somewhere and I wish you the best on your progression of the hobby.
    btw: big subs are for suckahs.
    epitome - Like McCormicks, we're seasoned
    achtuning - podi
    Jun 11 2005
    Nice Tail Lights
    2003 1.8T
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    i want to get an interior system; no sub because i have one already but i want some indoor speakers and component system that will that will be VERY loud but reasonable price range. ANY SUGGESTIONS?
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    im more of a treble man myself
    Jun 11 2005
    1st, don't threadjack.
    2nd, if you want it that loud, I would recommend Horn Speakers
    CLICK FOR ...
    Quote Originally Posted by yung turbo View Post
    2003 1.8T
