Results 1 to 12 of 12
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    for those dumping crankcase breather and pcv vent
    to the ground, you ever find anything coming out? I took my hose off and stuck my finger in it, there's absolutely no residue.... I just feel like this setup doesn't cut it. DEBATE!
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: for those dumping crankcase breather and pcv vent
    That's good. I noticed when my motor was stock I had absolutly no oil come from the breather on the valve cover. Your "issue" is a good thing. You don't want anything coming out if there.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    No residue either
    -Sami-
    Feb 24 2007
    Burlington, Vermont
    just surprised me I guess... think there would be different results with it hooked to a charcoal canister under vac?
    - Scott
    Das Build Thread
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Definitely good that there is no noticeable residue. Think about it, if there was, it would all be going back through the turbo/engine on a stock setup which is why you vent it to atmosphere in the first place.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    I vent to atmosphere and I have no residue. Loving it. Don't even need the catch can setup that I got. I will install it sooner or later though.
    Feb 17 2005
    Sarasota, FL
    Mine definitely doesnt "drip" but it does typically have some oil residue up in it
    Mar 21 2006
    Lakeland, FL.
    Thats due to you've been on your eng. We just can't seal them the way they come from the factory.
    I'm back bitches!
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Speaking of this, do you guys have a bit of "breeze" coming out of the dump tube when you're idling? I'm assuming this is normal, but just want to check to make sure.
    -Darrick
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Capt. Obvious View Post
    Of course, thats the positive pressure you have to vent from the crank
    Nov 14 2006
    Gig Harbor, WA
    Quote Originally Posted by A4ringedONE8T View Post
    That's what I thought.
    Hey Shawn, while you're on here, check my question in the How-To thread...
    -Darrick
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    i got nothing either, but i've been running it for only a week
