the "BRAKE" on my dash was blinking and beeping. so i took the advice from members of this board and add some more brake fluid. It fixed the problem. I planon changing in brake pads but after taking off the tire and checking the pad which is in mid life stage. i decided not to change it.. but added more brake fluid (i had my E brake on).. After that, the pads feels as if it's rubbing on the disc. i try going over 60 and it feels as if the pads are stuck.. also, when ever i hit the brake i can hear a "tap" sound, i think it's coming from the brake pads..
could it be that i add too much brake fluid? how can i fix this??
