Results 1 to 13 of 13
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    spark plugs and cold starts
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Feb 24 2007
    Burlington, Vermont
    Re: Cold start problems..
    bump/could this blamed on doing the evap removal and not having vacuum pressure on the valve cover?
    how I have mine set up... probably screwed up
    - Scott
    Das Build Thread
    Veteran Member Three Rings favianjanitra's Avatar
    Aug 05 2005
    A6 3.0T Quattro S-Line & VW Tiguan 1.4 TSI R-Line
    Balikpapan
    i've been having the same problem too. but Ive been procrastinating to get a hotter plug.
    Does your CEL flash on the first few seconds? until the engine warms a bit up then CEL becomes solid.
    Getting BKR6E's now!
    Feb 24 2007
    Burlington, Vermont
    nah, no codes, no CEL popping up at all... just the oil on the plugs. Those BKR6E's are 2 dollars a piece at autozone though.. good deal.
    - Scott
    Das Build Thread
    Aug 05 2005
    Balikpapan
    i got them for 3.89 each here in vancouver.
    Apparently, my old plugs have fuel (wet) residue on them except on cylinder 4, the plug is BLACK. What could be my problem?
    I dont think mine my problem is leaking valve cover gasket.
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Quote Originally Posted by favianjanitra View Post
    where did you order your plugs from? i found these sparks
    Aug 05 2005
    Balikpapan
    I went to Lordco auto parts shop here locally.
    May 28 2008
    2005 A4
    copper or platinum?
    Aug 05 2005
    Balikpapan
    Re: ...
    copper
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    you obviously running extremely rich.....hows your fuel consumption?
    -Sami-
    Registered Member Two Rings phoenixr2's Avatar
    Dec 15 2006
    03 Honda RC51 03 Audi A4 1.8TQ
    Re: ...
    so you were the first to post
    "Those BKR6E's are 2 dollars a piece at autozone though.. good deal."
    yet you started a new thread because you were upset that people were talking about spark plugs and where they got them and how much they cost
    Aug 05 2005
    Balikpapan
    Re: spark plugs and cold starts
    MPG has gone down a little bit in the past 3 months or so.
    I am currently on APR KO4 software...
    When I vagged it...it only says Random Misfires which only occurs on cold start up.
    Where should I start looking ? O2 sensor?
    Feb 24 2007
    Burlington, Vermont
    I was just telling him, didn't intend for it to keep going in that direction...
    - Scott
    Das Build Thread
