    Deactivated Four Rings
    Apr 09 2008
    Willow Grove, PA
    A.W.E. Tuning has RS4 Engine Mounts In Stock and Ready to Ship
    Eliminate excess engine movement with genuine Audi RS4 engine mounts.
    If you would like to learn more about RS4 Engine Mounts, please call or email us.
    [email protected] or 1-888-565-2257
    You can also go to our website: RS4 Engine Mounts
    If you have any questions you would like to ask, please feel free. I will do my best to answer them.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: A.W.E. Tuning has RS4 Engine Mounts In Stock and Ready to Ship
    Just in case someone doesn't know, these fit the A6 2.7T right? Would they also be applicable to the 2.8?
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Apr 09 2008
    Willow Grove, PA
    Quote Originally Posted by oc-drop View Post
    I don't see a reason why they would not, but we haven't done a test fit so I cannot be completely sure. They work with both the A6 2.7T and A4 2.8, so they should be fine.
    Apr 18 2007
    ny
    How difficult is it to change the mounts?
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Apr 09 2008
    Willow Grove, PA
    Quote Originally Posted by A62TURBO View Post
    You have to loosen things up in the engine bay and lift the motor itself with a jack to give you room to remove the stock mounts and get the RS4 engine mounts in place. Once you have them installed, reverse the process.
    The factory service manual should outline everything you need to do to access the mounts.
