Results 1 to 17 of 17
    Veteran Member Three Rings jukesandz's Avatar
    Oct 10 2008
    '00 Audi S4
    NE
    I'm stumped. Clunking from front end.
    More specifically from the front driver's side.
    I searched, and everywhere everyone said, "control arms! control arms!" So, I checked all the bushings...
    Upper:
    Tie rod:
    Lower:
    Metal stuff and other bushings and stuff:
    And they all seem to be fine. I jacked the car up and ran my finger along all the bushings I could find and I didn't get any oil. Also, I torqued the wheel bolts as much as I possibly could.
    I only notice the clunking noise when I'm driving at 10 mph down my crappy unpaved road and I go over a little bump. It's only on the left side. I think the car drives fine, and I never notice it while cruising or on the highway.
    I'm not a suspension expert. Any help is super super appreciated. What's your take?
    - Joe
    Oh yeah, and the car has <50,000 miles, so it seemed weird that I could be having CA problems already.
    Established Member Two Rings ewuzh's Avatar
    Jan 02 2008
    CA
    Re: I'm stumped. Clunking from front end.
    In that first picture, you are looking at the ball joints on the control arms. Follow those arms all way back and you will see the control arm bushings that hold the arm to the upper suspension bracket. Those are the ones that are most likely dead.
    Oct 10 2008
    '00 Audi S4
    NE
    OK I'll check right now.
    And WOW! That was a fast reply haha.
    Oct 10 2008
    '00 Audi S4
    NE
    They seem to be OK too. No oily residue or anything.
    Senior Member Two Rings badbiturbo's Avatar
    Jul 08 2008
    Porsche 996 GT3
    i kinda got the same problem, its a battle between it being the comtrol arms or the motor mounts. Does it makes noise when you accelerate, shift?
    Sold
    ‘00 S4 // Silver // Alcantara Sport Package // 6mt
    ‘03 996tt // Arctic Silver // Metropol Blue // 6mt
    Current
    ‘04 996 GT3 // Guards Red // Natural Grey
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    I had the exact same noises for almost 2 years before I had someone look at it, I had a broken ball joint and junk bushings. Those control arms looked like mine when they were completely shot and it was metal rubbing on metal. Also, you can't tell just by looking at the ball joint if it's ok, you need to get a long wrench and put a lot of lateral pressure on the ball joint and look for metal pieces from the inside poking out into the rubber housing.
    My car is fast
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    tie rod end or balljoint. control arms are usually more of a crunching sound
    Established Member Two Rings stevea6/z28's Avatar
    Jul 29 2007
    01a62.7t,2z28's,71exercisebike
    conn
    check sway bar bushings
    Oct 10 2008
    '00 Audi S4
    NE
    Quote Originally Posted by badbiturbo View Post
    Nope. Only when going over little bumps really slowly. I've broken some motor mounts on my chipped Passat. I don't think it's that.
    Quote Originally Posted by IamEzraM View Post
    OK Soo just like push on it? LOL I'm a suspension newb. What exactly am I looking for when I push?
    Jul 21 2005
    Bedford/MA
    can't hear anything in the video, but yeah you put a lot of pressure sideways on the ball joint, and either look for, or feel with your finger, metal moving around inside the rubber seal. Everything on my car looked fine too, you should just take it somewhere, because if one of your ball joints are broken, that pressure goes to some other part of your suspension
    My car is fast
    md
    umm, is that a split in your upper control arm bushing in your last pic ?
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    if its only on one side and only happens over bumps then you could have a blown shock
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Oct 10 2008
    '00 Audi S4
    NE
    Ugh yeah, it's hard to hear in the video. It's really quiet. I'll try your test tomorrow in the daylight.
    Quote Originally Posted by md s4 View Post
    I don't think so. You had me for a second, but then I looked at the other pics and they all have that little black line. Maybe??
    Quote Originally Posted by BlkdoutA4 View Post
    Really? With <50,000 miles? Gonna STFA for blown shocks now.
    Established Member Two Rings Diavan's Avatar
    Sep 16 2005
    Bartlett, IL
    You may check your 18mm subframe bushing bolts. See if u can tighten them a bit.
    Conway's Law:
    In any organization there will always be one person who knows what is going on. This person must be fired.
    Jan 02 2008
    CA
    Quote Originally Posted by jukesandz View Post
    They don't look nearly as bad as mine when I changed mine, but they do look like they are worn/torn.
    All four:
    Oct 30 2006
    B8 A4 Avant 6spd
    I see cracking.
    -18 718 GTS
    May 06 2004
    W124s
    PA
    That cracking on the bushing is normal, bet all of your cars are doing that. Get a large set of slip joint pliers and compress the upper arm ball joints. I'd place a bet on the upper rear. Check the bottom ones in the same way. Once they get bad enough you can shake the wheel from top to bottom and feel movement/ watch the joint play. Chances are yours aren't that bad yet. Just be sure once you replace your arms to tighten the bushing pinch bolt with the arm at loaded resting position or your bushings will end up like the pic above. Not a bad idea to loosen/ tighten them if you lower your car too.
    Keep right pass left, it's the law!!
