Originally Posted by
pacman
do you have any more insight ?
like what size resistor i need ?
The evap pressure sensor looks for certain pressures while performing it's test so adding a diode or resistor won't work, you would need to trick the vapor pressure sensor into reading multiple values while it performs it's self readiness check to not have a check engine light on. The only way without a special program to delete the evap without a check engine light on is to remove the light.
I have been running it open in the engine bay for the last 3 years, but have plans to remove all of it at some point.
I believe that, the remote possibility of fire is from the vapors coming from the gas tank but as long as the vsv's are closed no gas vapor will escape. Removing the canister and line to the gas tank will allow those vapors to escape though (with a remote possibility of fire. Remove the lines and vsv's and connect the line from the gas tank directly to the canister will allow the vapor to be absorbed by the charcoal and not emmit combustable fumes but will release pressure but it will still cause a check engine light.
could the evap cause you to lose pressure wot?
Today 12:24 AM
No, no affects on engine performance at all.
