Results 1 to 26 of 26
Thread: VAST Meth Kit
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    VAST Meth Kit
    Not sure if this has been posted up yet, but it looks like VAST has come out with a 2.0T specific water/meth kit. Link. You can either cut into the stock throttle body inlet hosing, or have a bung welded on to a FMIC setup.
    Christmas is now looking like AWE BT + AWE FMIC + VAST Meth
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Re: VAST Meth Kit
    you would obviously want it as close to the TB as possible, remember u want taht water/meth to stay as cold as possible to cool down the intake manifold.... if u weld it to the FMIC, then it still has a chance to get hot in the travel, i have mne tapped into the TB and i felt the difference, if you want to run meth and use ti down by the FMIC, then you are better off with cryo2 since that is made to be sprayed at the intercooler
    just my 0.02
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    Re: VAST Meth Kit
    is that all your xmas present? lucky lucky.. haha
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    pitbullmommy11@gmail.com
    Re: VAST Meth Kit
    Does this kit run on WOT or is it adjustable and runs based on boost level ?
    KO
    EcoLuxuryDetail.com
    6-Speed, Neuspeed Chip, Heat Shield, 034 Intake, Euro Jet PCV, 3" Magnaflow, Test pipe, Sport Suspension, RS4 Sway, Snub mount, Apexi super ground, K&N, RS4 Pedals, Podi, Hawk HPS, Super Blue Fluid, Chrome Mirrors, Clear cornered, Laminx, Debadged, Ziza Led, Xexon Interior, Alcantara boot, Infinity 1000W 12", painted markers, VAG's 19" A8 12 Spoke, 10 & 15mm Spacers
    Veteran Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    Re: VAST Meth Kit
    Quote Originally Posted by Ih8OEM View Post
    just my 0.02
    I heard from a couple people who ran it tapped into the TB that down the road somehow the meth damaged the internals of the TB and they had 2 replace it... But that could have also been bad luck because you've had it for quite sometime already with no issues. I personally have mine tapped to the IC pipe.
    B7 A4.... 394awhp
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Re: VAST Meth Kit
    Quote Originally Posted by Geoffafa@Wolfcars View Post
    just my 0.02
    Found this vid of CryO2 in use on an Audi. http://www.youtube.com/watch?v=8GQkiB2j-FE Venting.
    Senior Member Two Rings ringofsteel's Avatar
    May 05 2008
    67 BETTLE,95 GOLF JOKER, B7 A4
    BODENSEE, GERMANY
    Re: VAST Meth Kit
    I have the VAST 2.0t kit. It is by far easy to set up, and the kit is put together well. It has a controller that steals a signal of the MAF which is the plug on the drivers side top exit of the inter cooler. You can set when you want it to to start the spray and when you want full spray. the controller also shows when there is signal from the MAF (or turbo load). Thus at idle or revving the motor it does not spray. Hooking up took 45 min. Time is dependent on how you get through the fire wall. I have a #4 and #5 nozel. I have been running a #4. Works great. I use either my 93 or 100 file. I did however place a inline power switch so I can shut the system off when I want. Not too familar with the CO2 sprayer but the meth has alot of advantages. To steal some words" take an alchol pad and wipe it on your wrist. Then blow on it. That is what meth does, super cools the air, and when it burns it burns cold. Thus lower your IAT's and with pump gas it is like running 110 octane." Now I can say dont expect a kick in the pants when running it. Just consistent pulls and a strong power pull. Just my $0.02
    APR STAGE II+ APR STOCK/91/93/100/W/M/Test Pipe File,APR Full Cat-back, ZeroThreeZero TP, 034 Motor Mount, AWE DV, BSH Catch can w/PVC bypass, RS4 plastic covers, VAST W/M, D2 V3 Coil's, Cryo Rotor, ECS Steel Brake lines, Hawk Pads, 19" OZ's Ultra's 35et, 10,000k HID, AVIC D3 up front, 15" Flip down in the back with backup cam, Valentine, AWE Vent Gauge, Kenwood 8" Sub in stock local, Memphis Audio amp, 1 Farad power cap, Audi S4 blades, Audi Front Spoiler, Audi Rack system
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: VAST Meth Kit
    Quote Originally Posted by ringofsteel View Post
    Just to correct you a little the cooling comes from the water, the methanol increases the effective octane. Nothing burns cold
    -Kris
    Veteran Member Four Rings dblock110's Avatar
    Apr 11 2009
    usa
    Re: VAST Meth Kit
    after i get a chip i will be getting this kit
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    Re: VAST Meth Kit
    just ordered!!
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    Re: VAST Meth Kit
    Quote Originally Posted by extremesport3 View Post
    just ordered!!
    Just ordered one as well
    Established Member Two Rings SDQuattroDriver's Avatar
    Aug 12 2008
    2008 A4 2.0T Quattro 6spd
    San Diego, California
    Re: VAST Meth Kit
    What are you guys using for the reservoir? I didn't see one pictured in the kit.
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    Re: VAST Meth Kit
    Quote Originally Posted by SDQuattroDriver View Post
    IIRC most kits use the washer fluid reservoir.
    -Ian
    Jul 10 2008
    Austin, TX
    Re: VAST Meth Kit
    I plan to use my washer fluid reservoir, but Ive seen a couple people fab their own reservoir.
    Apr 14 2008
    Oceanside, New York
    Re: VAST Meth Kit
    washer, especially because it comes with a built in dumby light.... need that!
    BMW M3 ZCP
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    Re: VAST Meth Kit
    Quote Originally Posted by IceMole View Post
    Dry ice sure does burn cold....
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
    Veteran Member Four Rings harryd14's Avatar
    Jun 30 2008
    Atlanta, Ga / Norwich, England
    Re: VAST Meth Kit
    i think some ppl have made their own reservoir and put it in the trunk, in the space that the cubby is on the left of the trunk...
    A4 2.0Tq 6spd - Dolphin Grey
    AWE Exhaust - V708 18x8.5 - Dynavin Navi - Carbonio CAI - Blacked Out Grill - Retrofit Bi-Xenons - Passport SRX
    Smoked Reflectors - 7500k Fogs - LED city lights - CF rear lip spoiler - Tint
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    i just purchased mine
    I bought the IC pipe from the sensor to the throttle body they offer with it pre tapped for the nozzle.
    Does anyone else have this?
    I have Revo stage 2 right now, any input on number (timeing settings etc.. I should I keep 93 Oct or up it to the 100?)
    any info helps, thanks
    Veteran Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    so if you tap into the windsheild washer fluid, you can;t use the windshield washers anymore? I know you'd be spraying meth if u did but there are some instances where I've needed my washer fluid lol
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by makav3li View Post
    yea I am with there mixture they have on the site.
    I am talking about the tap into the IC pipe, I bought the pre tapped one from there site.
    Feb 06 2009
    328d, Tacoma
    You can, and if you use the -20 wiper fluid, it would still work to clean the windshield. "My" preference is to use a separate tank and use pure methanol mixed with distilled water.
    And for placement, I chose near the throttle body: http://www.alcoholinjectionsystems.c...icle_info.html
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Oct 14 2009
    Okinawa Japan
    You can use your washers, you'll just be spraying whatever your mixture in the tank is on to the window.
    If my washer pump worked than that's what I would do.
    Shane Drake
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    Quote Originally Posted by groundround View Post
    I bought the VAST Up-pipe as well. It's a BITCH to get fitted correctly. If it had 1/2" longer silicon couplers or if the pipe was 1/2" longer, it would be much easier to install without problems.
    btw, anyone know what I can use the other tapped bung on the pipe for? It comes with 2
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Quote Originally Posted by jerseybrian View Post
    yea i went out to install mine when i got it aND THE THING DID NOT EVEN COME CLOSE TO FITTING!! and i tried it on my stock sytstem and since I have installed the ER FMIC and the sensor is on the up pipe so the pipe from vast is a paper weight. I emailed them and they said they have had no complaints about fitment LOL I find that hard to believe. You lay the stock pipe next to the one the supply and it's night and day in size.
    Jul 15 2011
    Boynton Beach, FL
    Yah, I'll send them an email lol.
    I'm going to have to find a tig welder around me since I plan on getting an ER FMIC this winter as well and I'll have to weld a plate onto the TB Up-pipe so I have drill and tap it for the meth nozzle.
    Jun 19 2009
    17 ram 1500
    Hartford CT
    yup thats what i am gonna have to do as well
