Results 1 to 13 of 13
    Jun 08 2008
    Calgary AB Canada
    Homelink not working.
    ive tried and tried to reset my homelink so that it will take my garage door code with no luck.
    Im starting to think theres no power going to the buttons.
    When i press a button, is the little led supposed to light up?
    The buttons themselves light up but not the LED
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    Re: Homelink not working.
    did you read the entire programing guide in the owners manual? mine didnt work either until i kept reading and there is further instructions i had to reset the garage door opener too and its good to have 2 people
    Jun 08 2008
    Calgary AB Canada
    well it says to hold the two buttons down untill the LED starts blinking to reset it, but ive held it for far longer than 30 seconds and nothing happens
    May 24 2007
    Southern California
    mine works, but not with my garage :/
    i dont know how to reset my garage door.
    Kyle
    2.0L Revo GTRS Eliminator
    Aug 26 2005
    Quote Originally Posted by A4natomical View Post
    There is a button on your opener that is associated with synchonizing the door opener rolling codes to the Home Link rolling codes. Most door openers have instructions on thier websites, so does Home Link. http://www.homelink.com/programming/programming.taf
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    Quote Originally Posted by onceover View Post
    are you sure it says hold two buttons ? i remember only holding the one being programed
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    When you press the buttons, ANy one of the 3, if it doesn't light up (red), then your homelink is
    1. not present (that makes me think the previous owner might have been involved in a traffic collision).
    2. Homelink is fried.
    The homelink unit is located inside the front bumper closer to the passenger side. If you get a chance pop open the bumper. Chances are whoever installed the homelink back into the vehicle did not plug in the wire connector harness.
    You mentioned the buttons are lit. The buttons should light up when you turn on your parking/low-beam headlights. This is part of your ambient lighting/interior lighting system. It does not reflect the functionality of the homelink unit itself. But if the LED doesn't light up in response to the buttons then read 1 and 2 above.
    GL
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Jun 08 2008
    Calgary AB Canada
    thanks for the info. I was afraid that something wasnt right that the LEDS werent lighting up
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Pretty sure there is a fuse for it too... maybe check that out as well. Also note that it only works when the key is in the accessories position.
    DG '02 A4 1.8TQM
    My Build Thread
    Senior Member Three Rings vc1492a's Avatar
    May 04 2008
    Knoxville, TN
    sometimes its your garage system. Homelink works for the gate at the front of my neighborhood but not my garage doors.
    2010 A4 2.0T S-Line Cab (CVT)
    2004 Stage 2 Mini Cooper S
    Sold: OEM+ 2005 Audi A4 USP 1.8T
    Senior Member Three Rings G-Bus's Avatar
    Aug 25 2008
    Montreal, Canada
    I have the same issue. I programmed it, it work for two weeks and now it's grilled... POS.
    Veteran Member Three Rings darkstar's Avatar
    Dec 25 2004
    1998 silverado, 1986 c10
    Folsom, CA
    if your car is lowered make sure the wires in the drivers side fender well did not get danged or shorted out i have had this happen a few times from the upper control arm hit the plastic shield..
    Jun 08 2008
    Calgary AB Canada
    what would most likley cause the LED not to light up? Power bot reaching the buttons in the visor or the unit itself being discnnected? I wild have assumed that the led would light up whether or not the unit worked
