Results 1 to 15 of 15
    Senior Member Two Rings Dopefish's Avatar
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    What da heck is dis?!
    Hey guys, I'm doing a slew of work on my 2003 B6 1.8t FWD, including timing belt service, new valve cover gasket, emissions simplification and a catless downpipe. I found this silly little box that I cannot seem to discern a purpose to. It appears to be apart of the vacuum system but isn't listed in the diagrams posted here or AudiWorld.
    It appears to be bolted to the passenger side of the engine with only one line coming out of it. The single line shares a tee fitting with the bypass valve and intercooler piping. Is this component necessary or can I remove it and further simplify my engine bay?
    Please excuse the mess that my valvecover gasket has made, it'll be cleaned up once I get everything finished.
    1982 Signal Green VW Scirocco
    2004 Tornado Red Triumph Speed Triple : Barracuda CF Exhaust : Woodcraft Clip-Ons : Ermax Undertail
    Audiwissen : Coming soon
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Re: What da heck is dis?!
    you talking about the boost reservoir?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    that is the boost reservoir.
    it's just a place for the system to dump a little extra pressure so you don't spike as much.
    Dec 25 2004
    Earth
    Mine fell off my A4 several months ago, and i havent seen it since!
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    'dis' is called a Hemholtz Resonator, if you reserch it its a deviced used by the factory to reduce certain sounds the turbo can make.
    http://www.audizine.com/forum/showth...oost+reservoir
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    take that shit out
    BetaAlphaTau member #19
    Oct 29 2005
    10speed
    San Francisco, CA
    weight savings FTW
    - Clint
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    evomer
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    i had to grab my mirror for the one^^
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    in that first picture it appears that you may have a minor boost leak.
    {99.5 Avant}
    Senior Member Two Rings sinful7's Avatar
    Nov 19 2006
    1994 Schwinn
    Quote Originally Posted by vdubstreets View Post
    I always thought this crap was vented back to the air box. If you take it off do you get to hear the bypass valve release?
    Saint Cloud, Fl
    buh bye it goes
    instagram ------------> low_enforcement
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Quote Originally Posted by sinful7 View Post
    I didn't hear a sound difference when I ripped mine out when I was running my 007dv with a open air filter. I still heard the same faint whisssp sound.
    Feb 20 2007
    ct
    if you remove it you have to cap off that T as you see in this pic. When I removed mine i was in the middle of doing inner cooler piping so i just didnt drill a spot for the hose to come off so it wasn't hard at that stage.
    I didn't notice any noise difference, or any performance upgrade. The butt dyno never lies.
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    Quote Originally Posted by Jibberific View Post
    Yea, I've been chasing that boost leak for awhile now. Thanks for helping me locate it. ;)
    I'll get a male/male barb fitting and connect the DV without the T. I wasn't going to mess with any of that until I saw the mess my valvecover made.
    Thanks guys, I appreciate it. Further weight savings FTW!
