Results 1 to 28 of 28
Thread: DIY rs4 mesh
    Senior Member Three Rings TheWrightAudi.'s Avatar
    Aug 07 2008
    White Rock
    DIY rs4 mesh
    k well ive gotten a lot of email regarding my mesh that i fab'd up a while ago.
    at first i wasnt sure if it was going to work out, but i went with it, and it turned out great. So if your up to the task then listen up.
    first you'll need a large sheet of ''expanded metal mesh'' you can get this from home depot but they only sell 2' by 2' sheets, so you might have to go to a material distributor of some kind. i got lucky and found an old patio table that was made of it.
    step 1. pull out the grill, set it on a work bench and place the sheet over the insert. then mark out the outline with a sharpie, make it bigger than you need cuz you'll have to do triming later. i found that a good pair of tin snips works best for cutting and triming. then you will have to bend the metal so it matches the curve of the insert as best as possible...
    step 2. then you have to take a ''fish saw'' to the plastic and cut out the fins inside the insert.
    (its a mini hacksaw)
    -NOTE, there is a clip on the insert that you need to keep, so it holds the grill in place. so cut out all the fins and leave a ''vertical support'' in the middle.
    now do some final triming around the edges and make the mesh actually a bit smaller than the plastic edges, like 1/8'' smaller so you dont scratch your paint when you install it.
    now apoxy the crap around the edges, and if there is excess then you can trim it off later. apoxy untill you are satisfied with the strenght of the peice.
    let apoxy bond overnight in a warm place.
    (i used all purpose drys in 5 mins apoxy)
    step 3. trim off the extra apoxy, the peice should fit! if not trim, or sand off around the edges until it does fit. once it fits then prime and paint!
    -when doing the main grill, i just apoxyed the rings on with the quattro badge. then i mesured and cut out a hole for the hood realise pin.
    now more pics...
    its time consuming, and you need to be a hands on person to pull it off.
    good luck
    1999.5,1.8T,5speed,quattro.
    Understeer -is when you go off the road and see the tree that kills you
    Oversteer-is when you go off the road backwards and dont see the tree that kills you
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    Re: DIY rs4 mesh
    +1 for you sir...I can see the value/sales of Rs4 grilles going down from here on out...
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Re: DIY rs4 mesh
    Ill be doing this tomorrow, nice write up. No lower grills for me since I have an fmic just the main grill, hopefully mine will look as good as yours
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    Re: DIY rs4 mesh
    would "gutter guard" work well for this?
    Aug 07 2008
    White Rock
    Re: DIY rs4 mesh
    Quote Originally Posted by rocky.ca View Post
    no you want something that will stand up to rocks, heavy rain, snow etc. so gutter guard would be to flemsy
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    Re: DIY rs4 mesh
    Nice mod. I will prolly try this sometime this week. Cause I'm tired of having no front grills cause of my FMIC.
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Re: DIY rs4 mesh
    FYI, http://www.mcmaster.com/ is the cheapest place to get the mesh, it is aluminum so it is easy to cut, its cheap for a 2'x2' piece, and you have enough left over to sell two other sets of lower grill inserts!!
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: DIY rs4 mesh
    I think im gonna make a DIY RS4 grill for fun!
    that "fish saw" looks like an amazing tool, gonna see if they have it at home depot
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings B5Burn's Avatar
    Feb 25 2007
    1998.5 A4 2.0BT
    Winnipeg, Manitoba Canada
    Re: DIY rs4 mesh
    Quote Originally Posted by biketsai View Post
    Well? where is the DIY?
    Haha, nice write up. Like the looks a lot.
    Sep 15 2008
    home
    Re: DIY rs4 mesh
    How do you take off the small grills after you put on the mesh?
    Mar 04 2008
    West linn, Oregon
    Re: DIY rs4 mesh
    I just got done doing my grill and lower left and right grills in rs4 mesh. Pics in a little.
    1998 A4 sold
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    Re: DIY rs4 mesh
    That looks really good, been added onto my todo list.
    Mar 04 2008
    West linn, Oregon
    Re: DIY rs4 mesh
    Mine definitely didn't come out as flawless as yours did, but I still love the way it looks.
    1998 A4 sold
    Aug 07 2008
    White Rock
    Re: DIY rs4 mesh
    Quote Originally Posted by Rhinop21 View Post
    Yea they look like shit Id like take a hammer to them or something...
    agreed.
    Aug 07 2008
    White Rock
    Re: DIY rs4 mesh
    ouch!!! haha
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    Re: DIY rs4 mesh
    Nicely done!
    But what about fog lights?
    Mar 04 2008
    West linn, Oregon
    Re: DIY rs4 mesh
    No room for fogs with ic pipes.
    1998 A4 sold
    Veteran Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, 2022 Outback, 97 civic ex(blew up), 95 Toyota pickup(sold)
    Parkland,FL
    Re: DIY rs4 mesh
    i still have fogs and i have a Racetec FMIC
    99.5 A4 1.8TM AEB Fronttrak - Volcano Black Mica - AutoFlex'd Signal Green - E85 - Clutchmasters 725 series twindisk - ID1000cc - Precision 5858 cea Ball Bearing Turbo - JE Pistons/IE Rods - EurodyneMe - Coilovers - AWE DTS - 034 Mounts - Team Dynamic Wheels -Nitto INVO -Working @ DipYourCar.com - Usp Motorsports -
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: DIY rs4 mesh
    The steel grills will chip and rust especially if you live in a four season climate.
    The aluminum is much nicer to work with. It forms easily, is durable, and won't ever rust. It also weighs almost nothing.
    Jim
    I Do Werk.
    Audizine Senior Editor Four Rings Richard's Avatar
    Jun 16 2007
    Broomfield, CO
    Re: DIY rs4 mesh
    Great write up!
    I have an extra grill for sale for anyone who wants to do this.
    http://www.audizine.com/forum/showpo...9&postcount=14
    Project: 2019 Audi e tron Edition One Prestige, Daytona Grey
    Daily: 2019 Audi e tron Prestige, Glacier White Metallic
    GONE: 2002 Audi S6 | 2013 Audi A6 TDI | 2006 VW Touareg V10 Twin Turbo TDI | 2001 A4 1.8T Sport
    Established Member Two Rings goonies's Avatar
    Jun 28 2008
    oz
    Re: DIY rs4 mesh
    Quote Originally Posted by TheWrightAudi. View Post
    ouch!!! haha
    boom bip surprise....oh
    totally reminded me of that.
    Mar 09 2004
    nw michigan.
    Re: DIY rs4 mesh
    Here is a link to the aluminum mesh from mcmaster.
    Jim
    I Do Werk.
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    Re: DIY rs4 mesh
    What part number is that from mcmaster, onemoremile? Thx in advance.
    TheWrightAudi., where did u get those?
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Three Rings joeporto's Avatar
    Mar 06 2009
    MTL, QC
    Re: DIY rs4 mesh
    good job, turned out looking 100 better.
    see i lost all my lower grill parts going through pot-holes.
    and i needed something to protect from rocks so i just took whats ever i had laying around the shop.
    i used aluminium mesh, sprayed a vinyl-wash and sprayed black.
    i drilled holes with 7/32' mesh, and ti raped it.
    i did it quick and easy for now.
    for a aesthetic look i should of used black ti raps. lol sounds ghetto
    Jul 21 2009
    2001 Audi A4 Quattro 2.8L
    Ohio
    Re: DIY rs4 mesh
    Anyone who ordered from McMaster, which Perforated Metal sheet did you buy? Expanded? Diamond? Also, what dimensions? Thanks.
    Active Member One Ring marcusromo's Avatar
    Mar 11 2013
    california
    where did u get the mesh i cant find one big enough for my grill
    Jun 04 2007
    Austin/DFW, TX
    Just buy the ECS tuning RS4 grill.
    My 5-Speed Swap DIY
    - B6 USP
    Oct 02 2006
    Wadsworth,OH
    Below is the link to said grille.
    Jason
