We knocked $50 off for the winter
JHM FMIC KIT complete with the following. Full kit From $550 to $750 depending on options. Partial Kit as low as $335.
- JHM Exclusive VIDEO instructions. (35 minutes in length and a 19 page printed picture instruction packet as well)
- FMIC Core (Overall Length: 30" - Core Length: 22" - Height: 11" - Thickness: 3" - Inlet: 2.5" - Outlet: 2.5" - Air Flow Rate: less than 700Cubic Feet/Min, Rated to 600-700 Max HP - Working Pressure: 5-40PSI - Pressure Drop: 2-5psi@35psi; 0.2~0.5psi@15psi - Material: 100% Aluminum - Design: Bar and Plate - Construction: Machine Cut and Stamped, Hand Welded - Finish: Polished - Net Weight: 19lbs)
- JHM 4 piece piping kit. Pipes that connect to the Bi-pipe are 2.25" just like the stock or APR bi-pipe. Pipes that connect to the turbo outlets are 2" just like all B5 S4 outlet pipes. (Pipes are fully bent with only one of the 4 pipes having a weld)
- All Couplers and T-bolt style Clamps needed for install. (Kit only reuses the Passenger side lower hose, but elminates the restrictive Driver's side lower S-hose) Couplers are available in Blue or Black, see dropdown box below.
- JHM FMIC mounting brackets (stainless steel) w hardware and adjustment shims.
Get all the details and options here at our store (please read everything) --> http://www.jhmotorsports.com/shop/ca...products_id=43
Video of the final fitment of the product --> http://jhmtuning.com/videos/JHM_FMIC...itment_Web.wmv
PICS
Go HERE for more pics.
Pic of it fully installed and painted black for extra stealthyness.
Pic of it fully installed with the front of the Fogs reused for steathness.
A couple more examples of it installed
And a pic if it installed onto a LLTEK RSR bumper (NOT RS4 or reiger)
Finalized piping kit
Finalized piping kit installed
