Results 1 to 9 of 9
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    weird cluster lighting problem
    So all of my center dash display lights and radio lights dim and get very bright, then dim again...i cant figure out what it is, battery is good, alternator is good anyone have any thoughts on this.
    Thanks
    Miles
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Re: weird cluster lighting problem
    Have you found any kind of trend as to when they get dim/bright? For example do they get bright when you're on the gas and dim when you're idling? Does it switch when you go over any bumps?
    My guess would be to check the connections at the fuse box. A loose connection could potentially cause that.
    DG '02 A4 1.8TQM
    My Build Thread
    Feb 25 2008
    Cape May, NJ
    i tried that to, giving it gas to see if it got brighter and it dosnt,same thing with braking, no difference, there dosnt seem to be any kind of pattern, it just gets very bright, then very dim...
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Feb 25 2008
    Cape May, NJ
    bump...
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Feb 25 2008
    Cape May, NJ
    checked all of my fuses and everything is good,im starting to think i may have a little bit of an electrical problem....
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    I thought only B5s had problems with instrument clusters going out. Are B6s now developing that problem?
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    does this issue affect all the interior lights, i.e. cluster, stereo, window switches, etc? and if it does, how are the interior lights affected when you manually adjust them? is the range of light, from being really bright to being really dimmed w/i the same range as what you can set from the manual settings? you may have a faulty connection there...
    MY2022 B9 Q5 55 TFSIe: Daytona Gray||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Aug 26 2005
    There is an ambient light level sensor that varies the brightness of the dash lights according to the amount of ambient light, so if there is some bright light shining on the sensor, then due to movement of the car the bright light varies, that will cause the dash lights levels to go up and down. Are you driving when you notice the dash lights vary, or stopped, not moving?
    Feb 25 2008
    Cape May, NJ
    yes i noticed this when i was driving, that would make perfect sense, just didnt realize it made that much of a change in light.
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
