Results 1 to 14 of 14
Thread: euroswitch?
    Established Member Two Rings will665's Avatar
    Oct 20 2008
    2003 A4 3.0
    Louisville
    euroswitch?
    On my 01 jetta i had a eurowitch which enabled only fogs and parking lights without using headlights....is there anything like this for the a4s
    2003 AUDI A4 3.0 Premium, Sport, CW Pckg.
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    Re: euroswitch?
    yes if you have a 2002
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Re: euroswitch?
    adding on to Kerschera4, if you don't have an 02, you will have to use vag-com(software) to recode your ecu combined with a slight modification to your switch to have independant fogs. do a search for independant fogs and you will find tons of threads asking about this. you can shoot me a PM if you'd like as well.
    DG '02 A4 1.8TQM
    My Build Thread
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Re: euroswitch?
    ^^Not entirely correct. If you have the 2002, then you can use VAG-COM to set the code for the fog lights to come on with the parking lights. For 2003+, you have to rewire the connections to make it work.
    I've had an '02, and the VAG-COM coding did the trick. For my '04, I would need to not only do the same coding, but also do some rewiring to get the same results.
    USP CLUB MEMBER #34
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    Re: euroswitch?
    idk if anyone has done this. But i ran power to the fogs indenpently along with a relay and hooked up my own switch. That way I could run with just the fogs. If I have my headlights on and want to turn the foglights, I just use the light switch.
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Re: euroswitch?
    Sweet, i have the easy way!!! Yea, mine you pull out one click for fogs, and another click for rear fog. My friend Vag'ed my fogs to Canada so they come on with just the parking lights.
    Buncha motorcycles
    Memphis, TN
    Re: euroswitch?
    i had the ole euro switch on my jetta too! i wished it was that easy with the a4
    APR Stage 2/AWE Intake
    Jan 10 2007
    VA
    Re: euroswitch?
    all the Vagcom and oem switch wiring tricks result in your fogs always being on anytime your parking lights or headlights are on. IMO, that's not 'independent fogs'.
    If I'm incorrect, and someone has wired the OEM switch so you can turn the fogs on or off regardless of parking or headlights, please correct me and tell me how.
    Feb 09 2008
    Austin Texas
    Re: euroswitch?
    you cant pull out to the click while the parking lights are off... so it would probably be a major ordeal to try and make that work.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Re: euroswitch?
    cool now another thing for me to do thanks guys haha
    Jun 23 2008
    Re: euroswitch?
    How much work is it to re-wire since I have an 04 and cant just vag the code into my ecu. So when I pull out the light switch the first notch with the parking lights on...the fogs will come on as well.
    Anyone to a write-up on the re-wire for later models newer then the 02s? I searched but threads didn't show this...just that you needed VAGCOM.
    -Thanks.
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    Re: euroswitch?
    aren't our cars supposed to have DRL's? Cause in my 2003, in order to have my lights on i have to turn the switch. There's no DRL's. Does this mean that the person who had my car before me VAG'd the feature to off?
    Mar 20 2008
    Belmont MA
    Re: euroswitch?
    Quote Originally Posted by SeatownB6 View Post
    Nope, no DRL's. Although the Canadian setting uses the fogs/parking lights as DRL's.
    DownhillA4 -You can't just rewire the switch to make the fogs work like that. It's a combination of both Vag-com and re-wiring.
    DG '02 A4 1.8TQM
    My Build Thread
    Jun 23 2008
    Re: euroswitch?
    Quote Originally Posted by agart View Post
    Yeah, found that out just after I posted that I will need to re-wire my foglights. Thanks though.
