Results 1 to 7 of 7
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Blitz Turbo Timer Install
    Would I be able to follow this to instal it, even thought this DIY is for an Apexi Turo Timer?
    http://www.a4mods.com/#index.php?pag...urbotimer.html
    Thanks
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Nov 04 2007
    Minnesota
    Re: Blitz Turbo Timer Install
    Bump, anyone know?
    Current:
    Nov 04 2007
    Minnesota
    Someone has to know
    Current:
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    That link brings me to the short shifter install... I found the turbo timer one but can't get a link for it. Anyways I looked it over and assuming that your turbo timer's connections have the same functions(12v constant, ground, e-brake, and 12v for the ignition) it should work. They all work off the same basis which as the write up says is to provide power if the turbo timer sees a voltage drop from the ignition.
    DG '02 A4 1.8TQM
    My Build Thread
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    yes, they are all the same, except you have to know what your turbo timer's wires do. the turbo timer has wires corresponding to the author's
    edit: i used his guide to install my greddy tt
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Veteran Member Four Rings Sablea4's Avatar
    2018 Suburban, Husqvarna riding mower :P
    Charlotte, NC
    i installed my blitz 2 years ago and if i remember correctly it was a piece of cake. you do need to splice into the diagnostic port in your car for the functions to work properly.
    Current: 2017 Audi Q7 Premium Plus. Carrara White with Nougat Brown interior. APR Stage 2, RocEuro intake, BMC filter
    Sold: 2005 Audi A4 Ultrasport Avant red with manual transmission USP CLUB MEMBER #6
    Sold: 2004 VW R32 Deep Blue Pearl
    Sold: 2010 VW CC Shadow Blue Metallic manual transmission
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by gotboost View Post
    http://www.a4mods.com/index.php?page...urbotimer.html
    Thanks
    fixed the link...
    i have to re-do the links on the page because i am now using AJAX for page loads, you get the # in the URL.. .which IE wont recognize... however mozilla handles it just fine
    if you copy and paste the url, you should just leave out the #
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
