Results 1 to 12 of 12
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    PureMS.Com - Stern Adj. Control Arm Sneak Peek
    Just a couple production parts to show off some of the details. Still haven't finalized production, but we're getting there!
    Ball joint is completely covered on top. Ball joint is still completely serviceable. There will be an optional seal to cover the bottom half as well. Standard will be stock OEM rubber bushings. Optional will be hard sphericals, for those that won't mind some noise.
    Full kits are still being worked on, but we should have more details soon!
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Re: PureMS.Com - Stern Adj. Control Arm Sneak Peek
    looks like a quality piece....what's the purpose of this part...well let me rephase that. How would i benefit from this part on my car if i dont track it?
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Jul 19 2007
    San Diego, CA
    Adjustable control arms are used for adjusting camber and caster. Now, a lowered vehicle can exhibit camber that is outside of the OEM spec. The factory allows for no adjustment to the camber, so if you're lowered, you're pretty much stuck with facing the real possibility of having premature tire wear. By using adjustable control arms you can correct the camber settings and put the camber back to spec to increase the tire life.
    These aren't only used for track enthusiasts who want to increase camber for better handling. These can be used by everyday drivers who need camber correction to retain tire life.
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    What kind of noise are you referring to in regard to the spherical version?
    Buncha motorcycles
    Memphis, TN
    finally mike! they look really great! do we have a release date/price?
    most people will want them to correct their front end negative camber from lowering on coilovers. if i get good tires, i go through them way too quick. not to mention i would think handling would be improved since i would have a better patch of tire on the ground instead of just the inside edge
    APR Stage 2/AWE Intake
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    those look very nice. Can't wait to see a price.
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    more details and price im interested
    Senior Member Two Rings genecan's Avatar
    Apr 29 2007
    Bulgaria
    Their site says $525. Expected shipping date - November 24th, they are taking pre-orders.
    http://www.purems.com/products/product.php/II=2681
    http://www.purems.com/products/STCAK...stallation.pdf
    1999.5 A4 B5 1.8TQ (ANB) -> 2.0L AEB EFR 7163 - http://www.audizine.com/forum/showth...ight=evolution
    Jul 19 2007
    San Diego, CA
    Lots of clicking and clunking. Sphericals will transmit noise and vibration into the cabin.
    Expected release is near the end of November. Retail on a set of the uppers is $599. We do have a pre-order special going on. However we will also be offering full upper and lower sets as well. Pricing for these haven't yet been determined, which is why there hasn't really been a full announcement yet.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Quote Originally Posted by Mike@PureMS View Post
    Well guess its time to let one of the girls go before christmas..... Because lord knows I need this more than anything... I have been waiting through a whole set of tires for this to come out....
    Veteran Member Three Rings Spongebob05's Avatar
    Jan 23 2007
    06 S4 - 95 R1 Raven -
    Austin
    Are these available for all Audi models and year ??
    Jul 19 2007
    San Diego, CA
    Quote Originally Posted by Spongebob05 View Post
    These will fit B5A4/S4, B6A4/S4, B7A4/S4, C5A6, C5Allroad, B5Passat.
    Still testing B8 and C6 chassis.. Should have updates soon.
