Results 1 to 4 of 4
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    so I got 5 good logs..
    and then I look at my laptop to see the VAG-COM "resume" button
    So I hit resume and got one last pull in... of course, the worst pull of them all.
    This would be the 6th pull in about 5 minutes. I said the other ones were better, because they were actually from 3k rpm to 7k rpm WOT.. this one I let off a little early. Anyways some additional info.
    T8 B9 (MBC set to 22psi) outside temp was 45 and sprinkling -for whatever reason it would only hold about 19 psi on that last run, the other ones held fine.. probably heat soak? I don't know how to read the intake temp, I'm assuming the second number is the one I should be concerned with? Otherwise I think I'm fudged haha.
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: so I got 5 good logs..
    pull back timing a bit. Log block 003 when you log block 020. First # is cooling temps. Second # is intake air temps in block 004. Doesn't look like heat soak from those logs...
    Jun 29 2007
    Raleigh, NC
    ^why pull back timing? he's not running anything unsafe.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 24 2007
    Burlington, Vermont
    yeah that's what I was kinda thinking haha, it's only going to get colder out here and 8 is looking just fine... sure, a couple 6's but this is the 6th pull in a row, and I'm not going to put nearly this much stress on it when I drive around town.
    - Scott
    Das Build Thread
